Jan 14, 2008, 06:11 PM
Personal Sales Rating: ( 16)
Drives: '04 EVO VIII, '06 EVO IX RS, '90 1JZ-TT Supra
2008 Street Mod Discussion
Welcome to the 2008 Street Modified autocross discussion. This thread will be a place all SM competitors can share our exploits throughout the year, and also will serve as a resource for competitors thinking about campaigning an EVO in Street Modified class.
The last Street Mod thread has really grown! There is a huge amount of information contained in there and I would highly recommend any folks new to SM take the time to read through the 800+ posts before starting in the 2008 discussion. You can access the 2007 Street Mod thread here:
Autocross EVO - Street Modified Build
One question I had asked in the old thread I think is worth bringing up again -- What part or technology that is not currently used on the EVO do you think would improve your SM EVO's performance??
EVOlutionary
__________________
Many thanks to:
Andy @ Showcase Mitsubishi
Keith @ Pure Tuning
David @ DHP Composites
Jon @ TRE
Wayne @ Paradigm Performance
Evan @Exedy Clutch
for your contributions to the EVOlutionary EVO9 Project:
2008 - one car - 20+ wins
2008 - Solo2 XPL National Champ
2008 - Solo2 SM National Champ
2009 - the sky's the limit!
Offline
Jan 14, 2008, 06:44 PM
Here is an update on what I think it takes to build a nationally competitive Street Mod EVO based on what I've learned the thoughout the past year. . .
WHEELS AND TIRES
The standard is 285/30/18 Hoosiers A6's on an 18x9.5-10 inch rim. Wider is probably better. If you can cut the fenders and/or install a widebody and run 315 or 335 tires, I think that would be best. Of course go with the lightest, strongest wheels possible for your budget. FN01R-C's are popular because they are inexpensive and average weight. It seems that running staggered width rims (1/2-1" wider in front) has gotten more popular. I am not convinced that it is necessary, although some may do it more for convenience than performance. It is not easy to fit a 10-10.5" rim under the rear fenders. . .
SUSPENSION
It's quality, not quantity. You can have a big $$ set of shocks, but if they are not optimized you will get whooped by someone with perfectly tuned JICs. Unfortunately, at the National level, there are not alot of guys who will just give you the setup they are running because they have hundreds of hours and lots of $$ of testing invested into it. All I can recommend is to become friends with someone who knows alot about suspension and work with them/learn from them. Trial and error. Run your shocks full soft. See how the car feels. Run them full hard. See how the car feels. Then work in from the extremes. Most folks run a rear sway bar, some a front sway bar. Some crazy guys run no sway bar and super stiff spring. The combinations are limitless. You want your car as low as possible to lower the CG, but you need to me mindfull of roll centers. The Whiteline Roll Center kit seems to have been a popular item this past year. . . My suggestion - talk with Navid, Andy, John, Mark, Eric, Robi, Paul G, Marshall, etc. and learn as much as you can as far as what it takes to make the EVO stick.
POWER
MY FAVORITE! It is my opinion that you will need between 400 and 450WHP to win Nationals in an EVO. Some guys run less, some guys run more. I, personally am in the middle of that range. Too much low end torque is not always good. If you have really hard hitting power coming out of corners you will spin tires, as the EVO is very prone to lifting wheels and getting light on the inside tires. Too much torque can also cause too much oversteer. A 2.3L stroker with a TME turbo is probably not the best way - too much TQ and not enough top end. A 2.0L with a 20G variant, or possibly a 2.0 or 2.3 with a 50 trim I feel will be optimal. I recommend a built motor that can rev to over 8000rpms. Instead of riding the rev limiter in 2nd gear (or *gasp* shifting to 3rd) and losing time and accelleration, get a built motor and take it all the way to 9000 in 2nd gear. With the 285's that should get you to about 75mph. Alternatively, you could get the HKS 4.11 final drive gear so that you can go faster for the same RPM. Smooth power is key. You don't want compressor surge, BOV stuttering, or anything like that at part throttle. The throttle input should feel as though it is directly liked to boost pressure (just how a stock EVO feels).
WEIGHT SAVINGS
There really isn't a WHOLE lot you can do. Start with an RS so you have the aluminum roof and no ABS crap. (many people swear ABS is faster, but I am not convinced, yet. . . ) Lose the back seats and rear seat belt stuff. Get light weight racing seats. Get harnesses that attach to the rear seat mounting points rather than a harness bar. Harness bars are pretty heavy, and high up in the car. Get rid of AC and stereo stuff. Light weight clutch, driveshaft, brake rotors, wheels, etc. to save rotating weight. Consider keeping the stock FMIC - those big aftermarket ones weigh a ton. Consider a small radiator - you will save weight on the radiator itself, plus water weighs like 9 pounds per gallon or something.
AERODYNAMICS
To be the fastest in a big heavy car like the EVO you need every advantage you can get. Run as big of front splitter as you can. Splitters make downforce. Downforce gives you more grip. Some people set up the car to be loose in slow corners to help rotation, then use a big rear wing to stabilize it in high speed corners. But, having too much rear downforce without matching traction in the front is not going to be good. Make sure your car is balanced. Once again, run as big of a front splitter as possible, and one that is properly designed. Just a flat piece of FRP or carbon bolted under your front end may give you some benefit, but is not optimal. Take a look at the Voltex big splitter on the Cyber EVO for one that looks like a well thought out design.
As a side note, I hope that the SCCA "keeps up with the times" and does not continue to shy away from aero modifications, especially in Mod and Prepared classes (including SMod). Looking at Japanese Time Attack cars and German DTM cars shows just how prevelent aero is in other parts of the world. I think America is playing catch-up a little bit in the tuner car aero field. . . (Heck, it took NASCAR 40 years to learn what a wing and splitter are!  )
DRIVETRAIN
There is a lot of variation here. You may be able to get away with a VCU center diff and stock F+R LSDs. You will see some folks trying the GSC 40/60 center diff. Right now my car is tail happy enough, don't think I want to experiment with MORE rear power! Currently I run a stock front LSD, stock center ACD, and TRE reworked rear LSD. Stock tranny is fine. Probably won't break one at the power we will be running. I would recommend you have your transfercase built if you own an '03-'05 EVO. Lightweight clutch, flywheel, and driveshaft will all get you from corner to corner quicker. The Exedy Twin is the gold standard clutch.
Of course how much of this stuff you need is all dependent on your driving ability and how competitive you want to be. A great driver can win with less modifications. A more mediocre driver will need a more capable car to be as fast. The cheapest modification one can make that will yield the largest gains on the race track is to attend an autocross school. This can be simply one put on by your local region all the way up to the full EVO School program.
Please feel free to add to or argue with these opinions - that's what this forum is for!
EVOlutionary
__________________
Many thanks to:
Keith @ Pure Tuning
Jon @ TRE
Evan @Exedy Clutch
Offline
Jan 15, 2008, 07:20 PM
Personal Sales Rating: ( 4)
Drives: '05 EVO MR
__________________
My Garage:
2005 Silver EVO MR SM/BSP, Now the wife's daily driver. Elementary school kids love it.
94 Miata - ES
Cycling Season has started again. When you're out hauling ass, PLEASE be aware of others on the road.
Offline
Jan 15, 2008, 07:41 PM
Personal Sales Rating: ( 7)
Drives: 2005 silver mitsubishi lancer evolution VIII
the sias bmw was really ghetto, all the body parts are like falling off and are taped on...
__________________
AMS:
TBE
FMIC
LICP
Moustache bar
BUSCHUR:
Mini Batt
UICP
O2
OTHER:
Ohlins coilovers
cusco rear sway
18x10.5 nt03
garage hrs fenders
forge mbc
ix dv
sun auto hyperforce
tt tuned
inovative wb
GSC S1's
ix rear bumper
ix front bumper
cf trunk
2995lbs
350whp pump gas
Up next:
fp green 73hta
injectors
ported exhst mani
external dump o2 housing
Offline
Jan 15, 2008, 08:08 PM
Sponsored By EvoM Vendors
Personal Sales Rating: ( 6)
Drives: 05 GG MR
Oh, come on, yours was ghetto. The Sias-mobile was pretty sharp.
__________________
Sponsors:
Revolutions Performance || Shepherd Racing || Exedy
VIP Garage || Tobz Performance Tuning
11.51 @ 117.7 - IX Turbo, E-85, Cams, Tobz Flash, 5000' elevation
335whp/352wtq - DynoDynamics
Offline
Jan 15, 2008, 08:25 PM
So if Daddio sells his car and Sias sells his, then can we just proclaim me the 2008 champ now??? Or are you all going to make me WORK for it?? I HATE work!!
Dang, it was worth a try!
Offline
Jan 15, 2008, 08:29 PM
Wow!! I just looked as Sias' specs and I'm surprized - I'm makin over 80HP and 200TQ more than his BMW. That beast revs out to 8800rpms, though! It sure does sound wicked in person . . .
Offline
Jan 16, 2008, 08:02 AM
Personal Sales Rating: ( 9)
Drives: 2008 Volvo XC90 2003 EVO 8 2008 A4 Quattro 2.0T
Subscribed!!!
__________________
ROBISPEC///
Offline
Jan 16, 2008, 12:07 PM
w/e clayton, i was on like a $4k budget, my car is going to be legit this year haha.
what was the most ghetto part to mine in your opinion? the badly vynled side skirts, or the lip that was falling off or the blue masking tape?? jk
my co-driver will make you work for it lol, also what if really good drivers buy mark's and vic's cars?
__________________
AMS:
TBE
FMIC
LICP
Moustache bar
BUSCHUR:
Mini Batt
UICP
O2
OTHER:
Ohlins coilovers
cusco rear sway
18x10.5 nt03
garage hrs fenders
forge mbc
ix dv
sun auto hyperforce
tt tuned
inovative wb
GSC S1's
ix rear bumper
ix front bumper
cf trunk
2995lbs
350whp pump gas
Up next:
fp green 73hta
injectors
ported exhst mani
Offline
Jan 16, 2008, 02:48 PM
Personal Sales Rating: ( 2)
Drives: 2003 blue EVO
that and sia's mutant driving ability combine to make a formitable combination.
It will be interesting to see what he drives next year.
__________________
autocross nut SFR SCCA #52 SM
Offline
Jan 16, 2008, 03:20 PM
Oh, I didn't even think about that! What if he builds a new car for '08???
Offline
Jan 16, 2008, 05:04 PM
Personal Sales Rating: ( 10)
Drives: '96 Ford Taurus Wagon
He mentioned an evo over on sccaforums
Offline
Jan 16, 2008, 06:16 PM
Quote:
NOOOOOO!!!!
haha that would actually be sick, i would love to see what he came up with.
__________________
AMS:
TBE
FMIC
LICP
Moustache bar
BUSCHUR:
Mini Batt
UICP
O2
OTHER:
Ohlins coilovers
cusco rear sway
18x10.5 nt03
garage hrs fenders
forge mbc
ix dv
sun auto hyperforce
tt tuned
inovative wb
GSC S1's
ix rear bumper
ix front bumper
cf trunk
2995lbs
350whp pump gas
Up next:
fp green 73hta
injectors
ported exhst mani
Offline
Jan 16, 2008, 06:48 PM
I have a good one for sale for $19K!! Already has all the basics like poly bushings, roll center kit, bump steer kit, poly motor mounts, TRE tranfer case, Quaife LSD . . .
Dude, how bad would it suck to get beat by my own car!!
Offline
Jan 17, 2008, 03:59 PM
Quote:
Originally Posted by evobeatsti
NOOOOOO!!!!
I'll let you know in 2 weeks after the first unnofical event of the season.
Vic has driven EVO's before and knows what they are capable of. I wouldn't be surprized if he picked on up.
__________________
Offline
Tags
10x10, 38, altima, berry, bsp, cubby, daddio, evo, grice, mark, mod, mods, rpf1, sti, street, tires  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
