Oct 25, 2008, 02:45 PM
#526
Personal Sales Rating: ( 0)
Drives: 2007 EVO IX GT
Yeah I hear what you're saying as far as being quicker without sliding...I don't use handbrakes myself.
The courses here are tight though, and the fast guys here do use their hydraulic e brakes to pretty good effect!
Guy in this vid manages a 43 second run here - on the same course my best is a 46 second run (granted, I'd be considered a medium level SM car whereas these guys are more equivalent to F prepared). Still...prime example of the course layout we use here (note 180 turn and a 360 turn in there)...
http://www.youtube.com/watch?v=Es_TUkFSYt4
Just curious if anyone else has experience - toying with the idea of installing a hydrauic e brake to compete closer but let's see.
__________________
my ride
.:Powered by CBRD - at the Speed of BBK Lite:.
Offline
Oct 25, 2008, 06:22 PM
#527
Personal Sales Rating: ( 16)
Drives: '04 EVO VIII, '06 EVO IX RS, '90 1JZ-TT Supra
Wow, now I see what you're talking about. I would call that a gymkhana. Very different than the SCCA Solo2 we do here.
Looks like handbrake turns are almost mandatory there. . .
If I were setting up a car for this I would run the EVO 9 1st gear with TRE's 3.83 final drive gear - that would get you 56mph in 1st gear @ 8000 rpm. You'd never have to shift . . .
__________________
Many thanks to:
Andy @ Showcase Mitsubishi
Keith @ Pure Tuning
David @ DHP Composites
Jon @ TRE
Wayne @ Paradigm Performance
Evan @Exedy Clutch
for your contributions to the EVOlutionary EVO9 Project:
2008 - one car - 20+ wins
2008 - Solo2 XPL National Champ
2008 - Solo2 SM National Champ
2009 - the sky's the limit!
Offline
Oct 25, 2008, 06:51 PM
#528
Personal Sales Rating: ( 15)
Drives: 97GSX<GGIXMR
that is def. bad*ss i would love to run an autox course like that...autox & drifting combined....niceee....
__________________
12.05 @ 116.5mph....93 oct., Stock turbo, Stock motor (Stock cams), Stock Intake Manifold & TB, crappy 6 spd tranny, a bunch of bolt-ons, SPARKTECH nonCDi COP, 25 psi, Tuned by Kasey @ MAP (2009)
For the Fastest/Quickest Stock Appearing Turbo Times of 2009 Click Below
For all your Ignition NEEDS & WANTS, CLICK BELOW!!
Online
Oct 26, 2008, 04:04 AM
#529
Yeah the format we use is a little weird. Bacially the call AUtoX here the Redline Challenge and it's composed of two courses for each event - a longer, more open one similar to a Solo2 course and a tighter gymkhana style one. They add up your best time in each Test to determine the overall/class winners. The basic idea is to even things out between different types of cars (and we get more variety + more runs in a day as well).
Those tight courses look like fun when the guys are drifting all over like that but I can't get the stock e-brake to work on my car and on those short ones you're in first gear allll the time which is a little frustrating in an Evo.
Sure tests out the reflexes though
TRE gears etc. is something I'll consider for sure if and when I blow my diff or tranny. No rush though I assure you!
Might have to check the Rally forums for hydraulic handbrake info then. Thanks guys....
__________________
my ride
Offline
Oct 29, 2008, 02:59 PM
#530
Personal Sales Rating: ( 3)
Drives: 05 WW Evo 8
useful info here!
__________________
[Why ask when you know what the results are going to be
Offline
Oct 30, 2008, 02:51 PM
#531
Drives: Better than you!
Quote:
Originally Posted by theshadow
Cross posting this into the SM thread....where it probably belongs!
Rubbing issues are totally solvable - at least with 18s and 285/30/18s.
I think my Corsas are as big and fat as the Hoosiers but even if they're not you can get everythign to fit with the right spacers.
I finally put on some 15MM H&R jobbies, did a little extra fender modding and now - BINGO!
Here's what I did - same as EVOlutionary's pic but I also did some work on the rocker panels too since the inner edges tend to rub at full lock.
Everything's covered here:
End result is that the front wheels do stick out a little but I've acid tested this setup and I get NO rubbing on the fenders bumps or in corners, NO rubbining on the fenders or the inner fender bodywork (as a result of all the hammering and cutting, particularly the rocker panel mods) and NO problems rubbing the frame in front of the shocks thanks to the spacers - I now get full, clean, lock to lock steering.
Better front traction too - in short - sweeeeeeet!
I think that biger/taller tires (such as 275/40/17s) could also be accommodated by using the same hammering/cutting methods and adding spacers to fit your setup - you may just need a little more or a little less.
I also did a little research on the best spacers to use - apparently the bolt on spacers are better since they don't but any extra stress on your studs like running a slip on spacer + extended lugs would do. The bolt-ons are also supposed to vibrate less than slip ons which I think is important (I added 72.6MM hub centric spacers to fit my particular rims and the car rolls perectly smooth at all speeds now).
Now hopefully this setup will do the trick until I can afford to get some ultralightweight wheels (thinking of Enkei RCT4s since there's a decent local supply).
You guys with the lightweight rims = lucky!!!!!! I tried lifting up an 18.10 inch Enkei RCT4 with a racing slick on it and it seems to weight HALF of what my Rotas do. I can only imagine how nice they'd feel...
Yes, I'm jealous!
I'm not totally up to date on SM rules. But are you allowed to hammer the fender seems like you did for clearance? I might be thinking about the SP rules. But I vaguley remember something about having modifications outside the hub centerline...
__________________
2001 Subaru 2.5RS Retired G-Stock Autocross Beast - SOLD!
2003 Evo 8 Lightly Modded Daily Driver - Crashed!
2004 RX-8 Current Borrowed B-Stock Killer - Too slow!
2008 Z06 Super Stock Slayer!
Jeremy Foley
Offline
Oct 30, 2008, 08:56 PM
#532
Personal Sales Rating: ( 1)
there is no specific SM allowance to bend over the body seams but there is an allowance to do minor things not in the rules that don't by themselves give a performance benefit or reduce weight.
so yes it's legal in SM.
Offline
Nov 24, 2008, 03:49 PM
#533
Personal Sales Rating: ( 2)
Drives: 2003 blue EVO
well, to end up the 2008 season....
the latest fasttrack was released...
all of you who were dreaming of getting one of those bad arse aero-motion wings that Vic Sias was running on his BMW.... can look somewhere else.
movable wing elements have been banned.
see ya next year I hope...
__________________
autocross nut SFR SCCA #52 SM
Offline
Nov 24, 2008, 04:11 PM
#534
Drives: 2003 Evo, 2009 Solstice GXP
That's only a "proposal, published here for member review and feedback" ...
Unless of course, you've seen or heard something else...
__________________
Evos rock.
With great power comes great responsibility.
Good luck, godspeed, and may all of your acceleration be lateral...
Offline
Nov 24, 2008, 04:43 PM
#535
Dang it, guess I'll have to scrap the active aero front splitter idea . . .
Offline
Nov 24, 2008, 05:47 PM
#536
man you guys go down easy. Try sending in some feedback if you want to keep active aero...
Offline
Nov 24, 2008, 05:55 PM
#537
Drives: 03 Silver Evo
but I can't get the stock e-brake to work on my car ....
isnt the stock ebrake just a small set up inside the rear rotors?
Offline
Nov 24, 2008, 07:57 PM
#538
The only reason I'd want active aero is so that later down the road when they are trying to ban something I want in SM I could pull out - "Hey, come on now. You allow freakin' active aero, but you want to limit XXX?!?!"
__________________
Many thanks to:
Keith @ Pure Tuning
Jon @ TRE
Evan @Exedy Clutch
Offline
Nov 25, 2008, 07:26 PM
#539
Drives: 06 Evo MR
Quote:
Really wanna piss some people off? Build a fully automatic ProSolo launch control system. Put a valve in the clutch line, have a camera watch the lights, and open the valve at the right time. Complicated, but watch people start *****ing when you cut .505 lights every time.
__________________
2009 AS Car
[X] Co-drive in a Z0K Solstice
[X] Not spending all my money on racing
Offline
Tags
10x10, 38, altima, berry, bsp, cubby, daddio, evo, grice, mark, mod, mods, rpf1, sti, street, tires  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
