May 17, 2009, 02:25 PM
Personal Sales Rating: ( 0)
2003 Mitsubishi Lancer
Drives: 2003 Mitsubishi Lancer OZ Rally
Alright. So instead of making a new thread. My ac works great, but when i turn my knob from cold to hot, for one, the knob'll fling back about 90 degrees. I've tried all sorts of ways to get it to switch, but my heat will not turn on. I changed my thermostat thinking that was the problem, and noticed the heater knob acting funny. As well as that, its clear that the vent is not moving from cold to hot because you cant hear it like i used to be able to. Is this pretty much in the same category as the TSB 05-55-003?
Offline
May 17, 2009, 03:32 PM
Personal Sales Rating: ( 10)
Drives: 2003 evo 8
think you could shoot me a PM with price shipped to 21849
I've had this problem, got it "fixed" and low and behold its back. I'm going to do it this time.
thanks, nice post.
Buddy
Offline
May 18, 2009, 11:47 PM
Personal Sales Rating: ( 4)
Quote:
Originally Posted by mitsuorder
This is literally a 5 minute fix. The tension is really relieved a lot just by doing the gears.
Seems like it would take longer than 5 minutes! So are you saying you can just pop off the gears and put new ones on without doing anything eles listed in the TSB?
The part about discharging my AC system makes me not want to do this. But my temp dial can be a PITA, esp when passengers try to adjust it and don't know how to do it right since it binds
Offline
Jun 4, 2009, 07:14 PM
Personal Sales Rating: ( 2)
Drives: 2003 CT9A 4G63
I too would like to know this as I've been living with this problem for quite some time now. Luckily I live in an area where it doesn't really get too cold.
Offline
Jun 8, 2009, 12:37 PM
Personal Sales Rating: ( 90)
Exactly what I'm saying. By replacing the gears you change the fulcrum point of the linkage therefor alleviating the binding problem.
__________________
"If ye love wealth better than liberty, the tranquility of servitude than the animated contest of freedom, go from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains sit lightly upon you, and may posterity forget that you were our countrymen!”
Samuel Adams
Forum Rules & Regulations
Online
Jun 8, 2009, 02:21 PM
Personal Sales Rating: ( 9)
Drives: 2003 TB Evo 8
Russell, price shipped to 99577 please.
Thanks!
Offline
Jun 17, 2009, 10:47 AM
Ok, I just did this on my 2003 Evo 8 and it's definitely possible to change the gears just by climbing underneath your steering wheel column.
Be warned though, it requires a fair amount of being nimble, agile & patience.
I had to squeeze myself under my steering wheel UPSIDE DOWN. Make sure you get a short (length-wise) Philips screwdriver cause if not regular length ones will hit on your steering wheel column.
But other than that, it's possible.
UNFORTUNATELY, that didn't fix my problem. My problem it turns out, is the cable that pushes & pulls the gears forwards & backwards, which is connected to the heater control knob itself.
I guess over the years & usage, the cable itself has become "loose" so to speak, whereas it should be taut.
So what happens is when you turn the heater knob one way (say to max A/C) & want to turn it back to max heat, the cable flexes and refuses to push the gears back into position fully.
I believe my next step now is to replace my cable itself
Offline
Jun 20, 2009, 01:38 PM
2002 Mitsubishi Lancer
Drives: Mitsubishi Lancer 2002
my a/c knob has been broken for quite a while i posted a thread in lancer forums and someone directed me here. Im new to all of this so i have no idea how to fix it. i been told to find the part at a junk yard but i cannot install it...
Offline
Jun 20, 2009, 02:49 PM
Personal Sales Rating: ( 15)
2003 Mitsubishi Lancer Evolution
Drives: blue shopping cart
I never knew there was a TSB on this. I just called DOn herring plano mitsubishi and they quoted me 2500 for the job. I was never notified there was a TSB.
Offline
Sep 21, 2009, 03:29 PM
Personal Sales Rating: ( 1)
Drives: 2003 TB Evo VIII, 1991 CRX Si B16 Turbo
You have PM
__________________
~ 2003 TB Evo 100% stock, for now : P ~
Offline
Oct 13, 2009, 10:11 PM
Personal Sales Rating: ( 14)
Drives: 03 EVO8, 05 R6
How much for these parts along with the cable that goes from the temperature cable to the adjustment on the heater core shipped to 81652? mine has a kink in it.
__________________
03 Apex silver EVO VIII 12.25@113 1.83 60' @ 4800 ft
stock 9 turbo, stock ecu, stock block e-85
www.rcm-awd.com Colorado car club
Offline
Oct 14, 2009, 12:03 PM
Drives: Lightning Yellow 2004 Lancer Ralliart Sportback (the short bus)
xxxxx
Offline
Oct 14, 2009, 12:17 PM
Drives: 03 Evo VIII
AC temp control cable pn:MR979515 its about $5
__________________
03 WW Evo VIII
Offline
Tags
003, 05, 0555003, 55, broken, core, dial, hard, heater, lancer, tsb, tsb0555003, turn, vn, volvo  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
