Dodson Replaceable Stock Filter
Anyone going to try this? http://dodsonmotorsport.com/index.ph...mart&Itemid=30
They are about $175 not including shipping. I will be doing a change soon and I am thinking about going this route.
Two concerns: How good is the filtration? If the tranny dies, will Mistu deny warranty for using an aftermarket oil filter?
You'd have better luck with the warranty on the filter - the "different color" fluid is not the same specification as the SST-FI that is explicitly called for; as such they have decent footing to deny your warranty if the transmission takes a dive running aftermarket fluid. I don't think the argument on an after market filter would be nearly so strong.
"Thank you for your enquiry.
This filter is the secondary filter in the SST and the DMS filter is a reusable fine stainless steel mesh that is close to the OEM paper tolerance.
The strong high temp magnets also improve the filtering properties by collecting metal particles above and below 30 microns. The bypass valve allows the transmission to still operate if the filter is restricted, also when thicker fluids are used cold it will allow fluid to flow on warm up and close when the fluid has thinned out. An audible noise can be heard when this is operating.
There are 2 filters available, one is the standard size replacement and the other is the larger filter kit which comes with an alloy extension housing, filter element and new O ring seals, both have the high temp magnets."
Being someone that already went through hell and back with a warranty claim on my old MR (bad ACD pump); Mitsu can/will void your warranty for whatever they want. Fluids, aftermarket parts, user abuse, anything they can come up with.
I'd keep the stocker around and change back if your going to the dealership and think they will be looking closely at the trans. Also depends if your dealer is a stickler or if they r cool.
Honestly though, last time I went to the dealership they tried to call me dumb for saying the trans had a filter..... hence my sig....
paid $180+ship at sheptrans.com ...
Has anyone installed one yet?
I picked up one last week, but haven't installed it yet. I had read there were concerns it does not filter to the same granularity that the OEM paper filter does.
Any comments?
Any comments?
Which would you prefer? A slightly less fine filter that fluid is changed more often or a gunked up paper filter that might get bypassed anyway?
Put the money you save in filters towards more fluid and I think it will be an improvement.
One could argue it could be just as effective. If filters are close and fluid changes are done much more frequently(5k miles), likely it all balances out.
