Oct 28, 2009, 11:03 AM
Personal Sales Rating: ( 0)
Drives: 08 Evo X MR
Evo X MR problems continue
The code that displays this "Communication error with ecm/pcm" is pending according to my tuner when he checked up on my ECU .My tuner says he has never seen this and could be a big issue.
I just bought an Evo X MR with 250 miles about 3 months ago. I got it tuned at 1000 miles. Now it has approximately 1700 miles now. And i had 3 problems within the last 5 weeks after the tune coincidentally, which most of them are fixed.
I've had problems the last few weeks:
(1) After activating fast key, car would Completely just die when i go into the car.
Battery was replaced because it was bad. Needless to say, the car still died once afterward. I think it was because of my fast key in the same pocket as my cellphone and a metal key chain attached to that. I think the dying problem has been fixed hopefully cause it has not happened again.
(2) Idle was stuttering upon starting the car and then it dies. Had to restart car. Id have to put a little gas or change gears. Tuner fixed that, forgot to disable limp mode. Has not happened again.
(3) Tuner says a very rare code popped up or is pending. He forgot to write it down but it said "Failure to communication with ECM/PCM" Note when i drive around sometimes. Randomly at times, all the icons just appear and the navi starts to reset. Its like the car is rebooting itself or something while DRIVING.
I'm thinking this is serious and i just filed a case. Cause i have a one year warranty.
Any suggestions on what this code is? Some feedback and the correct way to approach the Mitsu dealership on fixing this problem.
Offline
Oct 28, 2009, 11:45 AM
Personal Sales Rating: ( 11)
Drives: AS EVO X MR
Make a copy of your tune and revert back to the stock flash.
If you problem goes away and stays, you know where the problem is. If not, take it just like that to the dealer and make use of that legendary MMNA warranty.
__________________
Are you in the North Texas area? Check out NTEC!
Offline
Oct 28, 2009, 04:17 PM
Personal Sales Rating: ( 13)
Drives: cheetahs crazy with his Evo X MR
+1. Go back to stock and have  look at it. Something isn't right.
__________________
2008 Evo X MR GG -- New
2003 Evo VIII RR -- Sold
2004 Lancer Ralliart LB -- Sold
English Racing -- MidgetSpec -- ETS -- Ralli ////Art -- Blitz
Quote:
Originally Posted by EvosnatcH
Welcome to your new addiction, its kind of like crack with out all the side effects minus the burning hole in your wallet
Offline
Oct 28, 2009, 04:25 PM
Personal Sales Rating: ( 1)
If I were to hazard a guess, it sounds like an ignition switch problem to me. Something is causing the ECU to reset and since the NAV system resets also, that sounds like an ignition circuit issue.
So what happened to the 3 year warranty??
Offline
Oct 28, 2009, 04:42 PM
Drives: 08 Evo X MR
Yea my car is tuned though lol. I don't have the necessary equipment to log in and turn it back to stock. But i will let Mitsu take a look at it and the see the ignition circuit.
Offline
Oct 28, 2009, 07:58 PM
Personal Sales Rating: ( 2)
Drives: Lancer Evolution SST
Quote:
MR
I'll hazard a guess .. it happens after the tune ??
Its not the ignition ..
Offline
Oct 28, 2009, 08:28 PM
Drives: AS EVO X MR
Damnit Gunzo, don't keep us in suspense.  We know it's not the hardware, but you know what is causing the software problem. Do tell!
__________________
Offline
Oct 28, 2009, 08:41 PM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
On the SST cars if you pull or write to the ECU it will throw that code. You need to clear the code after each time...
If the tuner has never seen this, you are the first SST car he has seen.
- Bryan
Offline
Oct 29, 2009, 07:44 AM
- Bryan
ooh .. and goodluck too eh ??
Offline
Oct 29, 2009, 07:05 PM
Drives: 08 Evo X MR
- Bryan
My tuner has tuned many MRs. And i don't want this to be a flame fest against them. If you look in my older posts, you can easily find out my tuner.
They took off the code and said it was "Pending". BUT they said they have never seen that code in any of the MR's and GSR they tuned for the last few years. Its not one of those P codes but a different letter. Sorry he said because he forgot to write down the code and just cleared it.
But is #3 a problem? It happens very randomly and probably once in a while. It hasn't happened since i visited my tuner recently but like i said "MY tuner says the code is Pending"
Offline
Oct 30, 2009, 11:15 AM
Silver Sponsor
Drives: EVO, STI
I'm not flaming them.  Yours must be the first SST MR if that is the first time they have seen that code happen. It's not a flame, it's a fact.
That is because it is SST equipped cars only, which are only avail 2008 +. You can clear it in EcuFlash fully without it "pending"
Offline
Oct 30, 2009, 02:23 PM
Drives: 08 Evo X MR
Thank you for the response. I guess it has not happened to me (knock on wood) since i visited my tuner recently. Thank you Gunzo and GST Motorsports.
Offline
Tags
2003, 2009, car, dying, evo, evolution, ignition, mr, problems, starting, tcsst  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
