Sep 22, 2009, 08:38 PM
Personal Sales Rating: ( 0)
Drives: Evo x Mr PB
MR TCU Flash?
is there anybody on the forum who has looked into TCU flashing. any info on if it would let us go over 350 wtq on stock clutches? would it be possible to flash the tcu with cobb ap?
Offline
Sep 22, 2009, 09:25 PM
Drives: 2006 Jetta TDI DSG
Would be nice if the SST mode selector could be used as an ECU map selector similar to how the SI-Drive is used on the subarus.
Offline
Sep 24, 2009, 07:58 AM
Personal Sales Rating: ( 11)
Drives: AS EVO X MR
For those of you who don't have accounts here- you must have one and have at least one post to view the boards... This was made by a chap with a 400 awhp SST Evo X (w/o upgraded clutchpacks)...
Quote:
Originally Posted by evolutionoz.net
A few other points about the SST because I'm sure that's what most of you are interested in. Ryan through his various contacts in the Yakuza/Tuning houses of Japan was able to get a hold of a spare SST box that had been opened up and stripped down. the good news is that the box is completely serviceable. I can only assume that Mitsu don't list the SST as a serviceable item at the moment due to some embargo / deal they have with Getrag. obviously there are people on here that would know more about that sort of thing than I do but the point is that the SST is similar to a normal transmission in so far as it can be opened, repaired and serviced. next point. there is now a ROM out that allows for full customisation/ tunning of the SST. initially we were experiencing problems with shift points not being quite right and the box going into something a kin to limp mode when we turned up the power. thanks to this new ROM all of that has been fixed. the gear changes have been smoothed out along with a problem we were having of the car not wanting to change gears at all. the torque/power cut has been disabled to allow for the extra power that the car is now running.
Any more questions on the SST especially to do with the new ROM are probably best directed to Ryan because he knows more about this sort of thing than I do and will be much better able to answer any technical questions I'm sure some of you have. Sorry Ryan I realise you're going to get flooded with pm's now but you are the guru.
__________________
Are you in the North Texas area? Check out NTEC!
Offline
Sep 24, 2009, 08:53 AM
Drives: Evo x Mr PB
the rom eliminates whp/wtq limits? WHAT THE EFFFFF
"the torque/power cut has been disabled to allow for the extra power that the car is now running. "
someone care to explain?
Offline
Sep 24, 2009, 09:08 AM
Hopefully this rom becomes public soon..
Offline
Sep 24, 2009, 09:10 AM
Drives: Evo x Mr PB
combine this rom with removing the limiter in 1st gear and you have the perfect evo
Offline
Sep 25, 2009, 09:26 AM
Drives: GRAPHITE EVO X MR
I would be happy with the FQ330 software:
http://www.autocar.co.uk/CarReviews/...30-GSR/240293/
'In addition to this they have removed the limiter from first gear, and the car feels so eager and responsive. From a standstill the X will reach 62mph in a supercar rivalling 4.4 seconds. The acceleration is fierce, but with the gears swapping themselves, you have more time for keeping your hands on the wheel and your eyes on the road.'
We should wage a war to get it!
Offline
Sep 25, 2009, 11:34 AM
2008 Mitsubishi Lancer Evolution My Garage
Drives: 2008 Evo MR
This has potential
__________________
1/4 12.599@ 106.99 60' 1.715
HKS drop in; Cobb Inlet tube; Ultimate Racing TB; Cobb AP stage 2; Rally Armor; AMS uicp; Xmr catch can; AEM afr guage;
ETS 4" fmic; Mishimoto radiator & hoses; SSP frontmount cooler; Boomba engine mounts
Dry carbon hood (body color), Aero Catch latches
Offline
Sep 25, 2009, 12:36 PM
Drives: evo VIII (traded in), OB evo x MR
now the only question remains... how to we get said software?!?!
Offline
Sep 25, 2009, 01:33 PM
Drives: Evo x Mr PB
i bet you ryan knows
Offline
Sep 25, 2009, 01:44 PM
Personal Sales Rating: ( 2)
Drives: Evo X MR
subscribed...this thread has epic win potential
Offline
Sep 25, 2009, 01:50 PM
Drives: 2008 Lancer Evolution MR
Quote:
Agreed. Subscribed!
__________________
Hard Right 2 Lift...
Powered By:
GSTMotorsports
Offline
Sep 25, 2009, 01:54 PM
Personal Sales Rating: ( 24)
Drives: Evo X - GSR
Sounds similar to VW's DSG. Probably about 1 year ago, flashes for the DSG's TCU were introduced. HPA, GIAC and C2 Motorsports all came out with flashes. And with those flashes, it was possible to remove the torque limits so the stock transmission could run higher power levels. There is still a mechanical limit that needs to be observed before you need to replace the clutch plates, but at least you can get the software limitations out of the way.
The DSG's TCU reflash also helped to increase the speed of shifts (both up and down). Could also increase the rev limiter. Could also eliminate the auto-upshift at redline (for manual mode). If you don't shift via paddles (or gear shift), the car will bounce off the redline. If I remember correctly, they were also able to eliminate some of the "clunky" shifting common with dual clutch trannys. I'm sure if you have an MR you've experienced the "clunk" that happens when coming to a stop. It's annoying. Had the same exact thing in my R32 w/DSG.
Just Google "dsg reflash" and you'll get a ton of results and links to some VW forums. http://lmgtfy.com/?q=dsg+reflash There's some good stuff in there to read if you want.
It will only be a matter of time before similar TCU flashing is available for the TC-SST.
Offline
Sep 25, 2009, 11:17 PM
perfect^^ guess its the waiting game then
Offline
Tags
c2, computer, control, dsg, evo, evolutionoz, flash, giac, hpa, problems, shifting, sst, tcu, transmission, unit, vw  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
