Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain > Mitsubishi TC-SST Discussion (All Equipped Models)
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 6, 2009, 09:59 AM   #211
Personal Sales Rating: (0)
Mendo's Avatar
Drives: GSXR-600, Evo X MR
were are you finding this on their site?? I'm looking for it and can't seam to find it lol
__________________
05 Mazda 6i |Injen CAI, MagnaFlow Cat back, strut bars [Sold]
06 MazdaSpeed 6 GT | Stock Our time was short lived but definitely remembered. [R.I.P]
06 GSX-R600 | Puig DBubble screen, 2 Bros Slippon
08 Evo X MR | Cobb Ap (Stg 1), HKS Panel Filter, Perrin Shorty Antenna, AMS UICP, RallyArmor UR Flaps
Offline
Old Nov 6, 2009, 10:05 AM   #212
EvoM Moderator
Personal Sales Rating: (26)
joedr's Avatar
Drives: 09 RalliArt; Lancer Evo IX MR; 1999 Honda Civic
Send a message via AIM to joedr Send a message via MSN to joedr
Kris should be able to answer some of those questions.
I used the contact form on their website and they responded right away. Try that as an option.
__________________
Thanks!
-Joed
EVO MR 2006 - 403.08 WHP / 356.68 TQ - FPGreen // BR Stages 1, 2 & Race I/C // Nisei LICP // PTE 780CCs // Walbro 255 hp pump // Blitz iColor @ 25 PSI // LC-1 WB // GSC S2 // Defi BF w Gruppe-S Panel
Offline
Old Nov 6, 2009, 11:09 AM   #213
Personal Sales Rating: (3)
2008 Mitsubishi Lancer Evolution
TheSin's Avatar
Drives: Phantom Black Evo X MR
The website isn't done yet none of the Evo parts are listed he is working on it though.
__________________
Too much to list, or so it tells me
Offline
Old Nov 7, 2009, 11:07 AM   #214
My Garage
kozmic27's Avatar
Drives: 2008 Evo MR
Quote:
Originally Posted by Fourdoor View Post
Hmmm, some questions since there is zero written explanations of their packages on the site:
Front mount cooler: Shows a bunch of parts, no explanation of what is included... looks like it is mounted above the bumper on the drivers side. Apears to have one fan.
Rear transmission mount package: Shows a bunch of parts, no explanation of what is included... appears to have an aluminum transmission oil pan, but no explanation if it is their shallow pan or deep pan, much more expensive than front mounted kit, appears to have two fans, and no clue at all where they have it mounted from the pictures.
Keith
I installed the front mount kit on my MR about a month ago. The kit came with very good instructions, including photos, and a template for mounting the kit on the drivers side front bumper. The install was very strait forward and per the instructions. The only instructions not included were for wiring the fan and motor. As was stated in the kit, this was because there are a few different ways to wire it, depending on personaly preference. I used a relay (not required or included), and mounted the included the control switch inside the car on the left side of the dash, below the steering wheel, somewhat out of sight. I put the switch on the ground side of the relay circuit, though the switch supplied with the kit is high enough amp rating to run it on the power side without a relay if you so choose. The fuse wire included with the kit was perfect for picking up power off of the jumper block in the engine bay (under the red plastic cover). I also had them ship me the inline (cleanable) filter, and installed it in line with the original oil cooler, and removed the factory filter completely. I originally was planning on removing the factory cooler, but decided against it, and run both coolers.
The kit came with the cooler/fan assy, pump, wires, switch, hoses, AN hose fittings, hose clamps, banjo fittings for top of cooler, fuse, mount bolts for cooler, self tapping screws (that actually work!) for mounting the pump, and zip ties.
Additional supplies I used were about 20 zip ties for wiring (because I'm anal like that), teflon wrap for where hoses contact structure, terminal connectors, and a 40 amp weather proof relay (over kill). For those that care, the relay I used is a start relay for an 81 Harley.
Here are some photos of my installation that aren't exactly the same as the photo's Kris has already posted.
This is where I mounted the fuse wire and picked up power:
An example of me using teflon wrap where the hose contacts structure:
Here is where I put the switch. I was careful to make sure there is nothing behind it, and it is NOT possible to knee it getting in and out of the car.
__________________
1/4 12.599@ 106.99 60' 1.715
HKS drop in; Cobb Inlet tube; Ultimate Racing TB; Cobb AP stage 2; Rally Armor; AMS uicp; Xmr catch can; AEM afr guage;
ETS 4" fmic; Mishimoto radiator & hoses; SSP frontmount cooler; Boomba engine mounts
Dry carbon hood (body color), Aero Catch latches
Offline
Old Nov 11, 2009, 11:59 AM   #215
jsr426's Avatar
Drives: Quickest Evo X MR - 12.27 1/4 mile
Quote:
Web sites been updated guys.
__________________
__________________
SSP PERFORMANCE
Offline
Old Today, 05:35 PM   #216
Personal Sales Rating: (1)
Drives: 09 Ralliart Fp Red Ordered
So anyone hit a track yet to produce some numbers?
Offline
Tags
20, ap, clutches, cobb, evo, evolution, lancer, pinout, reflash, rocket, ssp, sst, ssttc, swap, tcu, transmission, upgraded
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
