Quote:
Originally Posted by 07outty
right after start up. ( you have not moved yet ).
you hear "click- clack"... that is the sst checking / settting posistions. normal
Incorrect. Read below
Quote:
Originally Posted by Marcel71
Anyone experience these?
1. Right after starting the car there are two clamping sounds coming from the engine.
If you read the manual, or the TSB on the TC-SST, you would find the answer to this question.
As for the two noises you hear, this is 1st and 2nd gear being engaged.
When you turn the car off, there's a 2 second delay. This is ONLY in TC-SST equipped vehicles because it is disengaging 1st and 2nd gear.
When the car is running, even when in park, the gears are engaged.
Educate yourselves:
TSB-08-22-002 W6DGA TC-SST Characteristics
