Go Back   evolutionm.net > Lancer Evolution X Forums > Evo X Engine / Turbo / Drivetrain > Mitsubishi TC-SST Discussion (All Equipped Models)
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 30, 2009, 10:18 PM   #1
Personal Sales Rating: (3)
Drives: Evo X MR
Blitz SST cooler kit
Good news for SST owners :
http://www.blitz.co.jp/products/cool.../atfcooler.htm
__________________
Advan RZ
ARC IC/OC/titan & bov pipe/duct/r-cap/knob
Billion r-hose
Blitz S-tank/NurSpec DT/TC/inlet/stopper
Chargespeed f-ducts
Coltspeed GT shifter
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
HKS cat/strut bars/grill
JUN lip/skirts/mirrors/manifold/TB/thermo/wga
NGK race plugs
OEM CF eng cover/camera/h-brake/brake guide
Okada Plasma coils
Project Kics R40
Ralliart taillights/ac & shift panel/pedals/oil cap
Swift springs
Varis diffuser
Walbro 255
Offline
Old May 31, 2009, 01:06 PM   #2
Personal Sales Rating: (0)
Drives: Wicked White Evo X MR
Awesome find! Another option for us SST owners, although i haven't once overheated my tranny nor had I had any warnings about the tranny at all and I drive aggresively
Offline
Old May 31, 2009, 11:14 PM   #3
Personal Sales Rating: (1)
Drives: Evo X MR
Where do they suggest mounting it? A replacement for the stock cooler? Mount in front of the stock cooler (will block some flow to the stock cooler)? Mount in front of the oil cooler at an angle on the other side (remove fog lights), or mount in upper opening of front facia (blocking top side of radiator?
Offline
Old Jun 1, 2009, 11:43 AM   #4
Personal Sales Rating: (2)
blk-majik's Avatar
Drives: 08 RR Evo X GSR
Anyone care to translate what any of that says?
Offline
Old Jun 1, 2009, 01:34 PM   #5
Personal Sales Rating: (11)
Drives: AS EVO X MR
You won't overheat your transmission unless you're doing very aggressive driving with the selector in S-Sport. I did a couple sessions at the track in Sport mode and had no issues. Ten minutes into my session in S-Sport, I hit the "Slow Down" screen...
Quote:
__________________
Are you in the North Texas area? Check out NTEC!
Offline
Old Jun 1, 2009, 07:47 PM   #6
Personal Sales Rating: (17)
2008 Mitsubishi Lancer Evolution
Red Dragon's Avatar
Drives: PB Mitsubishi Lancer Evolution X MR
More info?
Offline
Old Jun 1, 2009, 08:50 PM   #7
Drives: Evo X MR
Babelfish translation:
1. Standard adopting the drawn cup type core. (Only SST cooler for run sir evolution X, adoption side tank type core)
2. Actualizing high reliability with the fitting of new development.
3. The fitting of BLUE+SILVER is superior even in fashion characteristic.
4. As for the SST cooler for run sir evolution X, the twin core specification which jointly uses the genuine SST cooler. The private air guide it belongs, it leads the travelling wind which is adopted to two cores without wastefulness.
*In order to prevent the temperature rise of the ATF where the coordinating point is lower than the motor oil, adopting the core of drawn cup type. In the vehicle which is tuned, it becomes easy to be connected to the temperature rise of the ATF, the slippage of the result clutch and the damage with the speed change malfunction and the oil film being cut off easy to occur. In addition, the thin inner fin (offset type) you adopt for the tube of the core, take heat securely from the ATF, you show the cooling efficiency which is superior. Furthermore the vivid blue of new development and the fitting of the silver were adopted, high reliability and preeminent fashion characteristic were actualized. * The SST cooler kit for run sir evolution X has adopted the side tank type core. In addition, it becomes the twin core specification which jointly uses the genuine SST cooler.*
Everyone should understand by now? lol
__________________
Advan RZ
Billion r-hose
Chargespeed f-ducts
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
NGK race plugs
Okada Plasma coils
Project Kics R40
Swift springs
Varis diffuser
Walbro 255
Offline
Old Jun 2, 2009, 12:24 AM   #8
gunzo's Avatar
Drives: Lancer Evolution SST
Send a message via ICQ to gunzo
Standard air cooled cooler
It runs as a twin oil cooler design using designed airducts (note not useable with foglights)
Offline
Old Jun 3, 2009, 06:06 PM   #9
MACH3EVO's Avatar
Drives: evo x
as the previous post this runs as a dual core setup.
Meaning- that the facotry core runs as a secondry setup
the Blitz unit is the primary
Instaltion requires removal of fog lamp assembly
__________________
Q: What is a Three Letter Word For FAST??
A: EVO
Offline
Old Jun 3, 2009, 10:47 PM   #10
Drives: Evo X MR
do you guys think adding a fan to the stock cooler would be more or less effective compared to this?
__________________
Advan RZ
Billion r-hose
Chargespeed f-ducts
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
NGK race plugs
Okada Plasma coils
Project Kics R40
Swift springs
Varis diffuser
Walbro 255
Offline
Old Jun 6, 2009, 08:12 AM   #11
MACH3EVO's Avatar
Drives: evo x
adding a fan is apreety cheap way to do things but really you are doing a 1/2 ass job, put the right gear in first time
__________________
A: EVO
Offline
Old Jun 6, 2009, 09:13 AM   #12
Drives: Evo X MR
Found a picture of how the Blitz SST cooler is mounted:
__________________
Advan RZ
Billion r-hose
Chargespeed f-ducts
C West h-ducts
ETS dp
ESPRIT GT 052
FP Green
Gruppe M intake
NGK race plugs
Okada Plasma coils
Project Kics R40
Swift springs
Varis diffuser
Walbro 255
Offline
Old Jun 8, 2009, 11:52 PM   #13
Drives: Evo X MR
i wonder which one is better, this one or the ssp one..
Offline
Old Jun 9, 2009, 10:02 PM   #14
When is this available / how do I buy it?
Offline
Old Jun 9, 2009, 10:53 PM   #15
evox44's Avatar
How much HP can this handle? The SSP+clutch pack is rated at 550whp or so?
__________________
FS: HKS Legamax
Offline
Tags
atf, blitz, cooler, evo, evolution, hks, lancer, mr, oil, photo, pipe, ssp, sst, trans, transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
