Quote:
Originally Posted by jrsimon27
thanks for the info gunzo,did you change the oil filter for the gearbox also?
at what mileage did you change the gearvox oil?
thanks
.. I didn't change mine .. I changed a friend's
That was done around 20k miles .. if you track often .. change the filter too .. that filter medium is a piece of crap .. and at $130 a filter .. and expensive crap ..
Mine had an oil analysis done at 15k miles and was told everything good .. and continue to use the oil until 30k miles ..then do another test .. I had 2 track days when the oil was tested ..
