View Full Version : AEM EMS
Pages : [1] 2 3 4 5
  1. Going lean at 3500 rpm
  2. Lost evo 8 base map-help
  3. Launching with Retard Rev Only?
  4. just curiouse how everyone mounted there aem ems
  5. AEM EMS 1313. how to setup timing and TPS?
  6. Need help with boost value on aem ems
  7. Wot tuning
  8. Need opinions on my rev limits
  9. how to change maps on my ems with a switch
  10. AEM help reviewing log file.
  11. AEM UEGO sensor get hot w/o engine running
  12. base map
  13. ECU Possibly going bad?
  14. Need help car wont start
  15. WOT issue? Can't tell if it's the tune or mechanical
  16. Need some help, starting issue (not the normal)
  17. Need base map to tune evo VIII 2.5L GT37R 1200cc injectors
  18. wideband to AEM EMS
  19. AEM lost rpm signal?
  20. UEGO Wideband Problems
  21. help: need factory map sensor plug/pigtail
  22. How to properly setup non-cdi COP????
  23. Anyone Know a Good Tuner
  24. 50 trim 2 step question
  25. What is your Throttle Position on WOT ? ? ?
  26. Anybody not running a MAF anymore please read
  27. Question about tunes and different fuels...
  28. tuning in pa
  29. AEM Boost solenoid vs Standalone EBC?
  30. Please Help AEM EMS installing new wideband question
  31. tuning issue messed up piston?
  32. Sensors I can take off when using aem ems
  33. driving car just turns off
  34. questions??
  35. getting rid of AEM
  36. AEM 1313 x 1313-u
  37. aem and wideband problem?
  38. AEM EMS hiccup at after 5k
  39. Here's how I pass inspection with my AEM EMS ~500 AWHP EVO 8
  40. Any way to troubleshoot AEM without sending it out?
  41. A/C idle issues
  42. Drag cars using AEM EMS chime in please!?
  43. mivec error
  44. dragster
  45. Knock??
  46. Aem help!!!
  47. External switch for internal logging
  48. aem ems
  49. EMS with stock turbo
  50. aem 1313u and external wideband?
  51. AEM EMS and fuel level reading..
  52. Coolant or oil temperature-dependent rev limiter..
  53. What's your 2-step at, and how much boost do you build??
  54. Inspection
  55. AIT ~140 Degrees....What's yours? Im thinking about putting Water Injection
  56. questions
  57. Aem ems antilag
  58. Lean at cold, rich at hot..!!!??
  59. 1600 cc injectors? Stock Block
  60. AEM EMS crash during firmware upgrade
  61. 35R cars and timing maps?
  62. AEM EMS hard start
  63. AEM timing #s Vs ECU Flash timing #s?
  64. Which meth kit wires into AEM EMS easily?
  65. Blue Screen/Physical Memory Dump
  66. No lift to Shift
  67. AEM EMS second opinion
  68. AEM EMS and turbo timer
  69. Boost Control By Gear?
  70. Konck sensor tuning?
  71. Immobilizer
  72. Boost problem. Cuts out around 15-17psi.
  73. Mivec and triggerdisc
  74. need information (map) for tuning MIVEC on Evo IX
  75. help with UEGO
  76. TPS Unplugged? Why?
  77. Anti-theft
  78. Looking for assistance- Epic Lulz for stupidity.
  79. WTB: Sotck ecu and stock maf
  80. A/C Clutch (compressor) not turning on
  81. Inconsistent Logs
  82. FIC Bluemax Injectors + EMS
  83. In theory
  84. o2 disconneted, but still running fine?
  85. Any one use a buzzer or a horn for shift indicator?
  86. I need help asap!
  87. Symptoms of a dying AEM wideband 02 sensor?
  88. Email tunes?
  89. Cal file?
  90. aem issue after i washed motor
  91. Logging Options
  92. AIM dash reading AEM
  93. AEM EMS how does it affect the OEM gauge cluster.
  94. where to get aem ems the cheapest!
  95. A/C relay turning on/off...any ideas?
  96. FYI: ACD error code and EMS
  97. How to setup NLS
  98. db9 serial connector pin location
  99. Jumping car on AEM
  100. AEM of stock ecu..?
  101. View my first AEM log
  102. Passing smog question..
  103. AEM EMS Tutorial Resources
  104. AEM Series 2
  105. push-starting an AEM-equipped car??
  106. Aem in Ny
  107. Which way to set up
  108. Trouble on first start of the day
  109. Idle "Hang"
  110. Need Help with 35r evo
  111. EMS connection problem
  112. Look at this log
  113. AEM EMS First time install
  114. Few AEM issues
  115. Boost control..what is current?
  116. Lean Spool.........what A/F?
  117. Compatible USB to serial adapters
  118. Coil Dwell Settings Help
  119. Cold start and E85 calibration!
  120. FullBlown/Double pumper wiring question
  121. Aem Ems Start Up map
  122. Lean idle/cruise AFR's after hard pulls.
  123. CEL shift light?
  124. Backfire then No start!
  125. A series of questions re: AEM EMS
  126. Problem with Evo 9 EMS - Burned 3 times already - Pics & LONG
  127. Passing emissions in VA
  128. AEM EMS+NYS inspection...... solution???
  129. aem start up map
  130. Fuel Injector recommendations
  131. aem ems question plz help
  132. Anyone using the AEM Serial Guage to read Fuel or Oil Pressrure?
  133. Aem Pencil Coil
  134. Car Sputtering, Due to weather?
  135. Starting problems... HELP!!
  136. David Buschur in Vegas tuning AEM's in December.
  137. Peak & Hold Injector Driver recommendations....
  138. Idle problem - advice needed
  139. Aem ems tuner??
  140. AEM EMS drivability?
  141. Fuel Pump problem
  142. AEM computer problems
  143. to much knock WTF
  144. Precision 1600cc injectors Battery offset?
  145. Buschur in Alabama?
  146. User Defined PW output setup
  147. Leaning A/R ratio?
  148. AEM EMS &small battery kit problems
  149. Battery dead? Do you need to sync again?
  150. idle death!
  151. fuel cut load with 3.5map
  152. AEM Startup map for 35R
  153. Need opinion
  154. boost control vss & hi/lo sw
  155. boost control map
  156. Too rich for a poor man’s evo 9
  157. ems vs wideband a/f
  158. AEM Serial Gauge Users Please Chime in!!!
  159. No Start
  160. Aem ems and Uego install
  161. Wide band compatability question
  162. Idle control not working
  163. How to properly set up NLTS with EMS?
  164. AEM EMS to Stock?
  165. Timing, Timing, and more Timing...
  166. Boost gauge is off 3psi than what AEM EMS says???
  167. AEM EMS Street ability
  168. David Buschur tuning in Vegas Nov 4-5-6th
  169. Coil Dwell, I don't think its right causing weak spark.
  170. ecu afr vs. W.B. gauge reading different
  171. Hard start ups when warm
  172. 4 coils setup
  173. Installing external switch for different maps for different fuel.H E L P!
  174. Another 2 Step thread
  175. little help here please!!!!
  176. 2 Step rev limiter
  177. Stock Solenoid Duty Cycle
  178. HOuston wa tuners
  179. Need a base map..any vendor would sell me one?
  180. Tuning E85?
  181. Problem With Knock Sensor feedback
  182. EMS sensor question
  183. Benefit From AEM EMS?
  184. AEM 3.5bar map vs. stock maf???
  185. WB o2 Sensor
  186. EMS timing values- 20 psi ,7k rpm's
  187. Pruven Performance AEM Install
  188. Colorado or Utah Tuner?
  189. Start up map. 35R stock block hks 272
  190. Tach
  191. Seattle Wa TUNERS
  192. Part Throttle AFR in boost
  193. Miss fire @ idle and running rich?
  194. Sensors on Aem ems for evo 8 and 9 interchangable?
  195. o2 sensor removal
  196. AEM without AIT and UEGO controller?
  197. AEM EMS 5bar vs 3.5bar MAP sensor
  198. Connecting LC-1/DB gauge to 1313 ems
  199. Can you use a switch to change maps on EMS?
  200. Anti Lock light on!!!!!
  201. Windshield wiper issues :(
  202. Fuel table question - EMS
  203. Help:Egt 30_2050 and knock sensor for EVO_IX
  204. Switching turbos, 30r to 35r, Do I need to make a lot of changes?
  205. EMS 1313 on 03 Evo VIII
  206. Switching to AEM EMS. A few questions?
  207. Ecu?
  208. Another idle question
  209. bucking and cut out?crazy crank and cam sensor readings?
  210. AEM+Meth ? MAP/AIT ?
  211. evo 9 aem differences?
  212. Quick Question!
  213. aem tuner south fl
  214. Radiator Fan
  215. Dwell settings on M&W box
  216. Timing Sync and Adjustable cam gears
  217. MAP Sensor Calibration
  218. AEM misfire problem
  219. Emissions Stuff I can throw out
  220. Saving some gas.
  221. GOOD! AEM Tuner in NC
  222. AEM Wont Log
  223. Tuner in VA?
  224. CHanging Injectors
  225. stupid AEM 1313u question concerning Uego
  226. help uploading a log file
  227. Scaling PTE 1200cc Injectors
  228. CAL file help
  229. reason for settings not selected?
  230. what laptop do you use?
  231. ecu off line?
  232. misfiring..... Yay or Nay?
  233. Oil temp and pressure sensor question
  234. 1000cc injectors with stock turbo?
  235. Evo sounding like a Suby?
  236. good aem tuner in wa
  237. Few logs...
  238. P0300 code and AEM
  239. where is the ecu ground wire terminated?
  240. EMS with Basic AEM UEGO Wideband
  241. Evap. Control
  242. Throttle Inj Corr Table
  243. long crank and stalling
  244. Idle questions
  245. HELP Car wont stay on**New Install**
  246. Help Connecting To Ems!!!
  247. oem Oil temp signal into aem ecu?
  248. Aem 3.5 bar map sensor problem with 3315 aem ecu
  249. BR FP3065, PTE780cc
  250. What level of cut for 2step?
