- anywhere in Atlanta, GA??
- Help!
- Intake temperature sensor info...
- Base map needed for JUN 272 cams
- aem uninstall
- Does anyone use aem ems on evo6 tme???
- Any Tuners or Experts near Cincinnati?
- throttle rises when lifting off accelerator?
- Injector timing?
- Aem ems radiator fan won't shut off ?
- Question
- Fellow Evo owner needs help
- Log, Log,...the Log
- Mabye someone can help
- Buschur's AEM package???
- AEM EMS...apple mac??
- AEM EMS and HKS DLI II
- AEM Twin Fire Ignition Module or HKS DLI II
- AEM EMS, 50 Trim, 1000cc inj =startup video=
- Getting the AEM EMS - Questions
- AEM with ebc question
- to AEM please help and frinds
- Fuel pump on/off
- AEM EMS for Evo IX??
- Please Help!!!
- any tuner help needed.
- OBDII & AEM EMS
- New AEM Electronic Boost Controller 30-4350 vs. AEM Add-On Solenoid 30-2400
- How to Configure my AEM EMS to use 1000cc injectors??
- AEM tune vid...
- EMS plus GReddy Informeter
- EMS Probelm
- SMC alcohol with AEM EMS WARNING!!!
- Help getting ECU up & running! Fustrated!
- gas tank level reads low w/aem ecu?
- EMS with AMS 1600cc injectors
- AIT sensor bung
- need an Intake for map conversion?
- inconsistant warm start up's?
- Boost control and wastegate pressure
- 02 sensor- need help!
- intercooler sprayer with ems.
- LC-1 Wideband to AEM
- aem and smc alky kit
- feedback on my logs...
- Can you use a 1.19 map on a older aem unit using the 1.11 or1.17
- How bad is 2 step?
- 2step didn't work, what did I do wrong?
- which pc card to serial card?
- secondary injectors
- HELP!!! Car won't start with new injectors, AEM EMS fried?
- electrically problem with ems
- hks dli / AEM ems
- GM boost controller hook-up and a question about saving the tune
- AEM EMS Cold Start
- EMS won't connect
- Boost Contol Help
- Boost control
- Can you just isntall a driver?
- 2 step help~
- with my ems...
- Future Set-up.
- De-celeration Table
- Pigtail for my MAP sensor
- A/C cycling...
- What sensor for the AEM EMS?
- anyone using aem 3.5 bar with MAF?
- **Learn To Tune!!!**
- Blue wire on wideband ...
- pricing on aem ems 30-1313
- quick aem ems help
- UEGO Controller mounting location
- Need EMS tuner near or around Philly PA
- wideband
- What Do I Need
- 5 Bar MAP wiring
- AEM Serial Gauge
- Estimated HP opinions~
- Need some logs
- Where to get tuned?
- Just Had AEM EMS installed but now...
- brand new aem ems with x-tras 4sale cheap!!!!
- Does the AEM have anti lag?
- wtb: 30-4100 uego & controller
- What did it cost you to install/tune ems ?
- Can anyone help me with a base map?
- Please look at my log
- Can someone look at my cal?
- aem uego 7 greedy e-01
- Will this be safe?
- Need an installer and tuner in central illinois
- Tuners in Florida?
- DO i really need DLI??
- unecessary items while using EMS.
- do you have the EMS set up to control boost?
- AEM vs. Autronics
- finding good place to get tuned in socal?
- David Buschur in Vegas.....
- Aem Ems Wiring Diagram
- Uego/cable
- AEM is awesome
- Fabbing up MAF delete?
- Best price for an AEM EMS?
- Speed Density or MAS
- Boost controler
- Need Help - IAT Sensor Stuck at 77 Degrees?
- Big problem w/ AEM & UEGO....Help Please
- Help me fix my stalling issues please
- aem uego
- Problems on Spool up
- Launch Control Question
- Dissapearing EMS
- AEM is this correct?
- IAT sensor help
- i cant change my map!!
- Ems Or Reflash For Stock Turbo?
- need help 2step amd rev limiter not working
- Knock volt count
- Check Engine Light
- HELP.....please?
- can the EMS hold more than one map?
- I need a base map for cams
- Very Cold Start problem
- Anyone need an AEM 5 Bar MAP sensor?
- Need a little more explanation on wiring wideband into ems.
- I Need A Aem Tuner To Fly To Hawaii!!
- problems with internal logger?
- have a problem
- car revs up when I let off gas pedal
- Weatherpack connectors ?
- Safe to travel on a base map?
- Question regarding EMS & Sensors
- EMS: Beginners guide on how to get running.
- First Startup / Config
- No Lift Shift/2 step in an 05
- Guys with AEM EMS....which intake with MAF del
- EVO will not start! please help
- timing map
- Evo will not start
- AEM Uego wideband
- Is my AEM jacked or what?
- Evo 9 aem
- Crazy knock voltage >>> FIXED
- AEM Serial Gauge Installed
- Need 35 map!
- Sean Ivey Tuned
- Coolant temperature sensor
- car wont start on a dime
- HELP, I need a decent cal file
- *evo Ix Ems*
- Base Map for 35r?
- Did I fry my AEM EMS out???
- EGT Probe
- trouble with my wideband
- Convert to maf for emissions question
- Sputtering when trying to boost
- map vs maf
- fuel pop
- dEAR SEAN IVEY PLS HELP ME
- Open vs Closed Loop
- aem ems update on tuning
- will disconnecting my battery cause the AEM EMS to lose its maps, tune???
- Spyware/viruses on my laptop: will it screw up my AEM EMS???
- AEM EMS?? Is it possible to do boost logs?
- I need a temperary map
- power steering pressure switch input on AEM
- Anyone have a pic of the Buschur MAP sensor adaptor?
- overheating since aem is in....advice..?
- suddenly running really rich, please help
- Knock Retard Bug & O2 Bug ??
- will anyone help?
- 4.0-4.2 volts of knock n hiccup
- mini battery with EMS?
- aem uego
- 02 sensors
- Backfiring, Fuel Cut
- Which wires to what on MAP sensor? (pic)
- Help My Friend!!!!!
- downgrade
- AEM EMS tuning now i'm desperate
- AEM EMS tuner needed
- USB Serial adaptor
- New AEM Serial Guage!
- Compatibility with Evo 7
- Bought used AEM EMS......
- AEM boost controler question
- how do i scale a bigger set of injectors with the AEM??
- haywire
- Fuel pressure regulator solenoid?
- check engine light
- Selling my AEM EMS NEW!!! not used
- VSS Tuning
- EMS on 2.3l stroker?
- My first aem ems(sean ivey tuned)
- aem ems 2 step lunch help
- Maf Ems
- AEM users?
- Anyone Successfully Tune Rally-Style Antilag?
- AEM from EVO 8 To 9
- Parts for Converting Maf to Map?
- Question about AEM EMS
- afc?
- Clarifying some MAF to MAP wiring.
- idleing problem, please help!!
- AEM in the mail
- plugs? ignition system???
- gt30r + aem ems
- EMS boost control.....very impressed.
- sean ivy
- 35-2109, 3.5 bar or 5 bar
- EMS and knock?
- 1313 vs. 1313U
- o2 question
- Car runs better than stock ECU now
- Cam gears + AEM EMS
- I need a good tunner in florida please help!
- Car doesnt start for crap, need help
- Got a ? for aem user's
- AIT sensor wiring question
- Can someone look at my AEM datalog???
- Good Tuner Required
- Newbie Help
- AC Condensor Fan ?
- AEM uego question
- Can AEM be used as a fan controller?
- Utec Pro, but EMS newbie.. could i tune the EMS???
- Aem + Hks Dli 2???
- Where to begin?
- AEM EMS for sale
- Comport problems
- Wideband and AEM EMS
- AIT sensor and alky question?
- map filter
- aem ems gains
- Base Map and Beginnings
- 2 step rev limiter with 05
- which USB to serial adapter works???
- Off the beaten path
- Newbie to AEM
- Question about AEM, MAP Converson, Wideband, + Tpye of BOV
- AEM Forum NOW Back!!!
- Cant keep car running with AEM....
- Aem Is Up!!!!!! Finally
- Both Computer and Tuning Literate
- NEED base AEM map
- Re-Tune needed?
- Potential stupid question
- AEM compatible with Coil On Plug setups?
- AEM Tuner in Texas, Oklahoma, Kansas area?
