- What level of cut for 2step?
- ign phasing / knock tooth correlation ?
- am i getting ripped off for install + tuning prices for my aem ems for evo IX
- need a break in AEM map for Evo 9??
- Horrible AEM tuning from the "pros"
- Aem On Evo Vi??????
- Aem Map And Air Intae Temp
- Evo 9 AEM EMS
- URGENT: need AEM software v1.19 and a way to get my map from a cd to my AEM
- Ems Drivability Question!!!
- wb 02 sensor placement
- acd lights with AEM
- aem newbie problems
- attn: anyone who drives a car with AEM in cold weather
- Caroline Residents *Attention*
- Using JDM Map Sensor
- Shutting off ac compressor
- how to connect aem evo8 ems to wideband??
- AEM User Manual
- aem ems with aem wide band sensor
- Yet Another Hard Start Thread
- Weird high idle problems TUNERS HELP!
- Boost Controller Creating a Boost Leak?
- "Open Source" AEM cals...
- Evo IX AEM locks up
- How much knock (V) is actually knock?
- NEEDED EVO8 BASE MAP (2.3L Stroker, GT35R, 1000cc Injectors, HKS 272's)
- Please look at this log Tuning guru's
- Boost Control...
- AEm tunner
- Cold start Warm start!
- AEM Tru Boost controller gauge help
- aem 3.5 bar map sensor wiring to aem evo8
- aem ems tuning
- fan speed ?'s
- aem guage cable question
- Help With Cold Start!!!
- Good reputable/experienced tuner w/AEM EMS in Nevada/California area?
- Timing With Meth
- Looking for people who've used "Big Al" to tune AEM EMS...
- ems starting problem**please read**
- aem tune southeast wisconsin
- Drivability
- No Lift Shift Question
- Pump Not Priming
- "AEM" Boost Solenoid
- stock motor 35r base map
- AEM EMS on stock block with 35r
- question on boost solenoid
- AEM 1320 (IX) and AEM wideband gauge problems
- EMS offline - not a new install
- anyone in the indiana or indianapolis area with much experience with the AEM's???
- Tomei Cams 260 Evo9
- JDM 3bar MAP sensor & AEM?
- problem detected..............aem evo 8
- Base Map 4 05' evo 8...please :)
- no throttle response after shift?
- ecuflash to aem
- Base Map for EVO 9 with bolt ons?
- couple questions about EMS!!!
- AEM & Factory MAP and IAT sensors?
- AIT sensor harness
- Base map for hks 3037 turbo kit??
- Aem Tunner in the Bay Area
- low-Z Injectors
- EcuFlash Mivec map conversion over to an AEM map
- map sensor???!?!?!
- Opinions - No Lift Throttle Shifts !!!!
- Problem with AEM EMS *HELP*
- Aem wideband location
- starting fix for Evo 9???
- idle problem
- Ignition timing - how to play it safe?
- AIT sensor location
- 1313 or 1313U?
- Misfire at high rpm, possible sensor issue?
- AEM and Emissions
- Stop mileage counting?
- Aem Uego
- Who tunes ems in Florida thats reasonable
- Air fuel ratio?
- aem ems affect gas gauge??
- connecting aem uego 30-4100 to 30-1320 EMS???
- Tuners by state?
- Serial gauge and laptop connection
- Base Cal request for VIII, 3065, HKS 272, 1000cc, 5bar map
- Who do you guys think is the best AEM tuner in the country.
- Lean and knocking getting on throttle into a gear
- lookin for a good tuner in CT
- AEM>HKS V CON Pro?
- Anyone ever seen something like this in a log ?
- Tuning Mivec map
- AEMlog scaling
- Question about switchin back to stock for emission
- Few questions about idle...
- Need base to get car started
- AEM EMS Tuning in or around Nashville TN
- Base Map to get me to shop
- switched map and car wont start, help!!!
- computer porgram
- Extra Injector
- AEM tune?
- EMS isn't reading RPM's
- Should I
- high sporadic idle and "hanging" rpm..
- Is there a AEM Tunning Course
- Tuning for dummys
- How to turn on the AC fan?
- MIVEC map in AEMPro?
- aem/ windows vista??
- EMS tuners in WA
- Got AEM then blew motor while tuning
- How do I use a separate boost controller?
- Bad idle... please help
- Does the AEM EMS utilize the stock 02 sensors???
- Electric fan install?
- Can a "shift cut" be programed?
- Which boost solenoid are you using?
- Shift Light
- Twin fuel pump tune question
- engine "putting" randomly
- Just Bought EMS for my IX
- question about buying EMS
- Switching Maps?
- question about ems boost control
- AEM tuners wanted in portland
- I have a question about EMS
- AEM Serial Datastream Gauge
- cold weather starting with an AEM EMS
- Need help, swapped out AEM EMS to stock ECU, now throwing codes!!!!
- TPS sensor problem!
- Turn ac fan on
- Setting up a Two Step..
- Is this calibration safe to use?
- Any step by step install for Evo 9?
- CEL as a Knock light
- Setting up Knock control etc etc....
- Problem w/ AEM PEMS for Evo VIII
- Uninstalling the EMS
- EMS VS FCON V Pro?
- Lets Play AEM Trivia!!!!
- Do you Like Your AEM EMS???
- Aem Ems
- newb aem question?
- Aem Pros Tune In Please
- 50 trim base map?
- nitrous wiring question
- I Got Mase'd!
- Need cable from EMS to Laptop!
- Evo 9
- Need 2.3L w/GT35R Basemap
- 2step Doesnt work.... weird
- fuel pmup cuts off
- Injector fuel trim
- aem tru boost
- Base map
- AEM wide band
- Is this the right one????
- need map for ems
- ems problem maybe
- installing EMS
- AEM Certification Program
- Car stalling more frequently w/ EMS...
- aem ems to aem 30-4100
- 2 step each time you push the clutch in?
- Cars running lean
- new tune for lower and upper piping?
- Questions about e85 tuning
- Knock issue question
- Problems with the 05 evo AEM EMS??
- Aem Uego Wideband Problem
- Can my AEM EMS be expanded easily?
- During Shifts...
- Bosch o2 short lifespan...
- aem
- HELP Needed with UEGO and 1313U EMS
- 2STEP on EVO
- 2STEP on EVO
- need opinions on where to go
- How do I view logged boost and AFR?
- AEM tuners in texas?
- Anyone have a basemap? 2.3L Stroker
- AEM EMS Problems? What are there?
- 1st gear rolling @ 0% throttle with AEM EMS
- gm boost control solenoid
- aem ugo gauge help
- serial port card for laptop
- Want a fast startup time?
- Massive Problem
- If anyone needs a Cal file for Engine Start and Idle...
- Looking into building a racecar
- WR application question
- Need alittle help!!!!!!!
- Lightweight flywheel and stalling
- how to's?
- Which output controls the radiator fan? (Evo VIII)
- Dash Outputs
- A/C disabled, need help
- How are u tweaking ur aem to get better mpg?
- who has modified their thr. inj. cor. tbl.?
- I need a V1.19 map......
- AEM Tune for IX??
- can i up the boost and be safe?
- Need some help with A/C fan always running...
- AEM base cals for IX
- AEM Crank Problem??
- AEM Serial guages.
- Finally cracked my AEM EMS open!!
- Is there a evo specific aem?
- What does your A/F trace after shift look like?
- AEM EMS for the EVO-IX Released!
- AEM EMS good for a daily driven evo?
- Where is your map sensor measuring location?
- New to aem ems
- AIT sensor question...
- Backfire at WOT
- AEM EMS Boost Control Vs Greddy Type S Dyno inside!
- differance between GM and AEM
- Replacement O2 Wideband for AEM Guage type.
- car dies?
- knock volts when to worry?
- AC stays on???
- logging paremeter's
- AEM works, my power went from 390whp/312wtq to 443whp/393wtq
- starting fix for AEM EMS trouble
- Car wont start
- dload, who has it working well?
- boost solinoid
- base map
- Question about AFRs
- help with aem gauges
- Need some help/info
- help please
- setup for 03 2 step
- hmm.. Either UEGO reading double or AEM reading half?
- iat sensor
- Best alky kit using EMS?
- wideband install
- Running AEM on Cam Angle Sensor Only?!
- Cold weather = car won't pull @ WOT?
- best place to buy aem ems
- Does my log look aright?
- AEM EMS for the IX
- Ntls Setup On '05'
- cheapest place to get sensors + install help
- ems sensors
- new aem ems for sale cheap
- AEM Tru Boost Tips
- WTB: stock boost control solenoid from AEM user
- Can evo 8 and 9 use same EMS??
