- ACT clutch for Ralliart.
- Total HP increase..
- For those of you with factory intakes
- Rrm Sri
- Took the RA to the track
- Q for RRM, is it possible to increase the revolutions...?
- Possible ACT clutch for the RA?
- please tell me whats wrong with my car
- Where i can see Mitsu. parts from dealer
- Magnaflow Exhaust #14829, or RRM Axleback?
- Question for RRM...
- header back exhaust
- Ralliart Cat-back exhaust systems.
- Corner Speed, Exist Power...
- magnaflow: sound round VS oval body
- AEM Intake????
- opinions on RRM downpipe and Piggy ECU
- hitting the 14's
- hey what do you guys think
- Safc
- Rrm Lsd
- sr intake question
- Urethane Exhaust hangers
- Review of Authority EVO Short Shifter?
- CEL light after installin CAI.
- Throttle body bore for MIVEC
- Auto RRM Piggy
- need some help
- I have no idea what just happened, HELP!
- Replacing fuel filter
- transmission problemo.
- pics of a cai or sr on a RA
- ECU reflash..
- hydrolocking my motor
- CC lancer Help (4G93)
- K&N Filter?
- Oil caps
- LSD Varibility
- Lose horsepower when you take out air filter???
- CAI vs SRI on RAs
- does the rrm downpipe effect sound?
- piggy back ecu????
- lookng for a header
- beautiful :) ... :)
- my ralliart at the dyno
- it was a long day instaling new mods
- just finish the RRM clutch line
- RRM Downpipe CEL Update...
- finished installing the shifter base bushings
- RRM Axle Back, Bolt on?
- magnaflow exhaust = dope!
- Unorthodox Racing Flywheel!
- RE: Cam gears or pullies
- tranny
- RRM RA SS clutch line
- Gear Ratio
- From 1st to 2nd...Engine knockin???
- Quick question
- AEM bypass valve + Injen?
- Changing Tranny Fluid
- Automatic Boost
- RRM axle-back installation
- Kartboy Ameoba shifter base bushing question...
- ecu explination?
- Top Speed Exhaust???
- Engine Compartment Exhaust System Heat Shielding
- LUCAS synthetic OIL
- BAD grinding from 3rd to 2nd
- Estimated Quatermile
- question regarding exhaust
- RRM flywheel
- rrm piggyback
- Quick question about intakes
- Looking for the right muffler
- Problem with RRM axle back :(
- anybody else have clutch problems in the morning?
- Greddy question
- N2o
- K&N filter.
- zero gravity module chip
- fyi: tranny fluid
- 3000km - problem or paranoia? [Clutch]
- Air Filter For RA
- 4G63 evo motor into RA
- RRM axle-back exhaust??
- What spark plugs to get?
- what fluids to use?
- green top injectors for the RA
- Hi flow cat
- Tranny.....same, but different?
- OBD diagnostic plug?
- radiator cap
- Q: Field AFC ECU Extension Plug & Play Harness
- Replace Engine
- engine name
- ACT or Cusco clutch?
- ? about rrm intake i baught
- Just curious about redlining
- Rev question..
- What parts are in the 4G69
- Notchy/Grinding Shifts
- MSD Ignition
- Racing Performance Works
- Nice Exahust system
- is there something wrong?
- Low RPM's
- Will this CAI Fit???
- injector size?
- Tornado or Spiralmax
- off road pipe question
- Mitsubishi Lancer VR-X / OZ
- What kind of spark plug wires does the RA have?
- OEM Exhaust and Header Needed
- An Exhaust DON'T
- pictures on my custom intake and cat back!
- B&M Short Shifter
- ? about RRM ECU
- Mobil 1 Synthetic oil
- UD pulleys
- octane rating
- Emanage, SAFC, ???
- Tranny Popp.! sound from 1-2 shift.
- Thinking about RR CAI? Read this FIRST!
- Starting Problems
- AEM CAI for an AUTO RA
- CAI and wet weather
- WTF?? aint this thing going to block my air flow?
- Drop in K&N Filter
- Ultimate Racing
- E-Manage for Ralliarts..?
- Speedshifting
- B & M vs. Ralliart shifter
- AEM bypass valves feedback
- CAI from Road Rage question
- Ultimate Racing Cat-Back Exhaust and Air Intake
- DOHC 4G93 Exhaust Manifold fit on SOHC 4G93?
- Dumped 2nd on my Tranny *cries*
- Transmission *cries*
- Mivec Engine ... is it a MPI set up or GDI
- 5-speed, how u like it
- Ordered my CAI for ralliart!!
- Leak from underneath the car...
- Short Shifter
- So what MAS does the ralliart run?
- Performance Upgrades for 2.4 Mivec
