- High Flow Cat
- thought this would help
- 2.4L Header
- Map Ecu2
- upgrading AT valve body and torque converter
- transmision...
- This happens when a 4g69 tries to compress water...
- fried 3 sensors last night...
- swapping to normal lancer ecu
- If you had a grand...
- My Clutch Job
- RA firing order same as EVO?
- Airbox mod
- Low oil pressure at idle
- Foglight Tints!!!
- my ride drives by it self...
- rpw twin throttle body kit
- Bad oil control (feeder) valve
- Tranny cooler finally installed
- sqeeking sounds
- question on tuning
- Stock 04 exhaust question
- Road Race Header
- Throttle Position Sensor
- Downpipe newbie
- Noise from clutch bearing
- leaky exhaust?
- ECU went into Safe Mode?
- Camshaft
- Lost Power Can you help me find it?
- upgraded tranny work
- short ram to cai
- Oiled filters=MAF sensor problem?
- Got a new clutch, quick question
- RA program searching?
- Idle issues after valve lash adjustment
- Having trouble starting
- fuel pump
- Black Exhaust Tip
- Injectors
- rrm downpipe... can you weld a typical CAT into it?
- Cel - Sri/im (merged)
- need an ecu pin out diagram
- Advice on tranny rebuild
- Piping ?
- who has the rrm header/dp and tune piggyback?
- Exhaust Noise
- Cylinder head Installed + a lot of Mods!!
- Safc-ii ?
- Err! Stripped a nut doing the valve lash adjustment
- 04 Ralliart Shifting out of first gear issue
- SMT 6 Applications?
- Engine Misfire
- Hard Shifting after Ralliart short shifter install
- Reliability With Mods
- installed rrm header an dp
- RIP Tranny: 9/22/04 - 8/7/07
- Greddy Evo2 Axelback Exhaust?
- which Exhaust system fit on 06 RA?
- Installation time for camshaft
- basic mods horsepower?
- valve adjustment?
- Engine hesistation when cruising
- what did girlfreind break
- Evo oil cooler fits Ralliart
- bored..here's my ralli reving..video
- Does the order of installation matter?
- RRM's Intake Manifold
- Fuel Injectors For An 06 Ra
- rrm test pipe vs rrm downpipe
- injectors
- RRM vs RPW
- please help me with safc 2 ps yes i read everything
- Perfect Power LetRipp Fuel Tuner
- Just installed my new RRM CAI. Now, question.
- Borla?
- cat back question
- DP vs Header and DP
- Almost Stalling
- ok new RA owner question
- RRM Header, worth it?
- Custom Work input needed.
- Factory Downpipe Performance
- RoadRace LSD: Current LSD Owners, please help !
- quick question
- cold air question
- so;
- Anyone running NO rear muffler?
- The power is in the HEADS!!
- CAI induced ECL
- o2 Sensor solution!!
- Transmission question
- Custom idea for Intake...
- I have a BAD feeling about this...
- Fujita Intake
- piggyback + pulley + intake = nice combination
- stock exhaust size ?
- Serious Questions for anyone running nitrous...
- EGR elimination !!
- need a clucth
- looking for a good package
- pulley vibrations
- voltage stabalizer
- custom sri problem
- RRM Clutch Line
- Ralliart Flywheel and LSD!!!!!!!
- new greddy ti-c exhuast
- O2 Sensor
- new mods
- hood hood bush problem!!! HELP!!!!
- will a dohc fit on a 2.4?
- air tornado
- Piggy for auto/manual
- CAI and CBE a review
- vtec controller switched to mivec controller
- Dynamic Ignition System?
- Will rims make a difference to tuning?
- Apex SAFC-2 or NEO in a Ralliart
- RRM Underdrive Pulley
- Free'd up some extra TQ! free...almost
- Shifter Bushings
- RPW - Camshaft & Cam Gear & Retune!
- Best Short Shifter, and brass Vs. Ploy Bushings
- Installed My B&M Short Shifter
- Kamikazie Headers
- Timing belt Cover Question.
- Quick noob question (HP/Torque)
- Rust...
- Running Lean?
- Cylinder Head project !!!
- Greddy Evo 2 Exhaust
- Stuck Throttle cable?
- Pinched fuel return line?
- CEL and resistor/capacitor
- New TSB on 04 RAs that have trouble starting
- rrm underdrive pulley
- Air/exhaust set up.
- Pulley installed
- RPM's stuck at 3200?
- just purchased my rrm pulley!!
- intake manifold??
- question for he Automatic RA drivers.
- Researching AWD Conversion
- Piggy Problem
- RPM Issue
- if you have the tactrix cable...
- Motor mnts/Tq damper
- here's a new one on timing
- Sri Rrm 4g69
- Help! Where can I find this part?
- lower tiebar
- Magnaflow Catback 15805
- Thermo Block Intake Manifold Gasket
- RRM short ram air
- how many have had tps or power lost problems?
- tuning with a wideband basics for the RA
- Evo Awd
- Possible CryO2 application!!
- NSC damper kit
- How the mas sensor can be tested
- RRM Axleback Fit
- Taking apart a 4g69
- rrm IM
- total power loss
- problem at the dyno??
- How much ignition degrees mivec advances?
- LSD for an N/A?
- RRM Flywheel and ACT Clutch
- How to increase compression
- bad day at dyno
- cam n cam gears??
- Getting Piggyback (tuning question)
- 200whp N/a
- RRM Axleback comparison
- Intakes for 06 ra
- question about removing cat...
- max horsepower
- Evo Throttle
- rrm port and polished head - review
- longer 5th gear
- Ralliart CAI
- so im new...
- Problem with my accessory belt and pulley...
- Rrm Cat Eliminator - Please Read!
- Done the mods now what ?
- Clutch/FLywheel Q.???
- road race intake
- MAP ECU, anyone have test this?
- Quietest Muffler?
- Centrifugal Supercharger
- Time to replace the clutch
- rrm sri problems
- Another Awesome Header Review
- RPW Tranny cooler
- Willwoods and LSD next month.
- ROAD/RACE- Cam and Ported Head
- RRM Test pipe????
- Valve cover bolts
- Anyone have the Piggyback for an automatic?
- I need more MODS!!
- Tranny Probs
- rrm piggy and normal idle
- Firering order
- What are some of the Pro's and Con's for the ROAD/RACE PIGGY BACK ECU
- picture of a 2.4L flywheel?
- Any other drop-in Air Filters that won't void the warranty?
- Check englight codes PLZ HELP
- Chevron Techron - so far so good
- RRM Header
- What spark Plugs should I use
- cam gear...
- I just ordered my greddy - evo2 exhaust
- Transmission skipping?
- the rrm udp
- Now i'm confused about what engine we have
- SES Question
- Another cool site..check it out
- Came across this Hope it helps You guys
- All motor
- Service Engine Soon!!!
- Fuel injectors
- RRM Header review
- whp
- ingen cai ordered
- Oil Change need input
- Synchromesh: Some feedback
- RRM UDP Question
- Re-Flash...Unanswered
- 04 RA Muffler HELP!
- Anyone have tested this??
- cleaning the air filter
- NSC dampener
- flywheel machining specifications
- boring out the 4G69 motor
- Thinking about engine swap for 04 ralliart?
- oversized throttle body
- psc1 001
- how to get 5-speed shifting as smooth as possible
- Installed IM!!!
- RA Transmission bolt pattern
- Custom Exhaust
- Next Mod !!
- N/A mods compatible with turbo
- KwEsTiOnS
- Shifter will "pop" out of 1st gear HELP!
- RRM Headers and Flexpipe
- Lost 3rd gear...
- headers...
