View Full Version : Lancer How Tos / Installations
  1. How-To: Factory Evo Strut Bar...
  2. adjusting 2003 lancer headlights?
  3. ? on E85
  4. How To Remove Stock Side Skirts
  5. how to change the location of alarm light
  6. How to Swap your ECU...
  7. where to get a turbo manifold
  8. Dynamatting my 02 OZ lancer
  9. hey i need help
  10. Stock side skirt removal?
  11. OZ Rally Lip Kit
  12. question about car audio system
  13. under hood bushings...
  14. Change Brake Lights
  15. Tranny filter, HELP????????
  16. Can I swap a 4g64 for a 4g94
  17. will a 03 lancer trunk fit an 05 lancer es
  18. 2004 Lancer ES ... grill???
  19. Install CAI on 2006 Lancer 06
  20. cold air intake
  21. 03 Lancer OZ Cold Air Intake
  22. How to: 02-03 Projecter headlights and HID install
  23. request on how to do timing belt and waterpump
  24. DIY: Power steering fluid flush/change
  25. How-to-Swap Evo9 Steering wheel to your Lancer OZ rally
  26. 03 Rally
  27. How to install ipod to radio
  28. Wheel Bearings on an 03 Lancer ES
  29. Lancer OZ Projector Head lights
  30. How do I remove these screw from the filter box
  31. Help me! How do you install front strut bars!
  32. DIY: Clutch secondary/slave cylinder repair
  33. Spoiler...
  34. Turbo Build
  35. How to make you own lip!!!
  36. how to flip your round turn signals with the running day lights!
  37. How to: remove trunk panels
  38. How to put rear seats down
  39. How To: tap water lines for 16G turbo set up
  40. How to Install Rear Transmission mount/roller, plus upgrade
  41. 02 OZ LANCER, can anyone answer my questions?
  42. Low and high beam on at the same time
  43. How-To Automatic Transmission Flush
  44. Question about the Blower Motor
  45. How to install interior lighting... Good Pics
  46. How to: change spark plugs link not working???
  47. how to: drip molding removal
  48. Cedia Headlights
  49. Mesh Grill
  50. Spoiler
  51. replacing the mirror switch on 2002 lancer ES
  52. Squealing!!!! ITS DRIVING ME CRAZY
  53. RRM Piggyback ECU Install (Manual Transmission)
  54. How to: Change Belts and/or Crank Pulley for 04+ ES
  55. H.I.D questions???
  56. Aftermarket Side Mirrors
  57. How to fill holes from spoiler.
  58. unbolting the camgear
  59. RPM signal wire
  60. RPM signal wire
  61. How to: Evo rear seat conversion
  62. How To: Megan Racing Seats & Brackets
  63. How to: 04-06 bumper removal
  64. How to change the Valve Cover Gasket on 2.0L Lancer 4G94
  65. How To: Fill/fix the license plate holes in your OEM bumper
  66. How To: Alternator swap
  67. How-To Replace a Clockspring
  68. How-To : Port a stock Intake Manifold
  69. RRM High Flow Cat Install (rust problems included)
  70. coolant bypass mod
  71. DIY Guide for flipflop trunk mod
  72. How To: Change Rotors/Drum Covers..
  73. Side Turn Signal Always On (Adding LED)
  74. Ground wire installation
  75. Lancer 06 tach install
  76. How To: Change Taillights..
  77. How-To: VG Install..
  78. RRM Header: Install, Review, How To, Everything WITH PICS 56K No Way!
  79. How To: Change Headlights..
  80. **How to change your oil**
  81. easy brake bleeding system
  82. How-To Install Redline Auto Shift Knob
  83. Gauge install - Voltage, A/F, oil pressure
  84. How to rewire '04+ headlights!
  85. Ho-To-Program Keyless Remote From Ebay
  86. Generic/Ebay Grounding Wire Install.
  87. Custom & Economical Laptop Station
  88. Radio LCD to red *Brighter*
  89. Refabricating the Interior
  90. eBay Indiglo Gauges
  91. How-To Remove E-Brake Handle
  92. How To: black out headilghts on 04
  93. How-To: Set up your Lancer for turbo install
  94. How To Change Spark Plugs
  95. Making a Custom Fiberglass Speaker Enclosure *Long Tutorial* 56k - go away!
  96. How To: Injen Heat Shield Air Duct
  97. RRM header install
  98. AutoVation Heel Guard Installed
  99. How To Change The Color of Your Gauge Needles
  100. Deyeme sway bar bushings
  101. ROAD/RACE Spring Install guide
  102. intake manifold install w/pics
  103. intake manifold install w/pics
  104. Installing Upgraded Fuel Rail - 4G94
  105. RDDesigns (PDXRalliart) Sub-Friendly Rear Strut Brace Install
  106. How to: Paint a bodykit
  107. $15 Shorter Shift Install
  108. Kartboy shifter linkage bushings install
  109. Replace brake pads
  110. Tranny Fluid Change thread
  111. ** HOW-TO ** making stock radio red
  112. RRM Piggy Back ECU install (Auto)
  113. Console Lights All-In-One How-To
  114. How to Install JDM Headlights
  115. Don't Buy Racing Seat Bracket...here's the how to
  116. How to paint headlight housings (DIY)
  117. Changing brake fluid
  118. RRM CF Cubby hole cover
  119. HOW TO: Easy Cluster Swap
  120. Repairing wheel/rim scuffs and damage
  121. Relocating the battery (How to)
  122. Amp and Sub Installation - Photo Rich
  123. Suspension / Spring install
  124. How to remove front and rear door panels
  125. Remvoing Manual Center Console
  126. RRM CF Eye Lid Install!
  127. Evo knob install in OZ. (Pics. How To.)
  128. Wheel stud replacement?
  129. Install Site updated!
  130. How to align Lancer (ES, LS, OZ) headlights.
  131. How to: Front bumper removal
  132. Install a Fuel Management Unit (FMU)
  133. HOW TO: Install an Apex`i S-AFC
  134. Changing reflectors
  135. Removing Center Console
  136. Install Xenon Headlights [DIY]
  137. Install Fog Lights [DIY]
  138. HOW TO: 2G Eclipse GSX Fuel Pump Swap
  139. Deyeme Racing Motor Mount Rear Install Guide
  140. Sway Bar Installation Manual
  141. Custom front grille instructions.
