View Full Version : Lancer Troubleshooting
Pages : [1] 2 3 4 5 6 7 8
  1. DashBoard Light Problems
  2. high rpm, no power
  3. Misfire Problems
  4. so now what...
  5. Need help Troubleshooting... EGR Valve Maybe
  6. car wont start
  7. Alt problems? Brake n Battery light On...Help me out..
  8. Question about Condenser Fan
  9. Engine Fan Issue
  10. P0335 and P340 faults
  11. power flickering/flapping? bad plugs?
  12. CEL Question
  13. 2006 Lancer Stalls on start
  14. pass suspension noise
  15. Quick fog light question....:)
  16. Bent a performance rim..advice..
  17. 2003 Lancer OZ and 2004 Lancer Evo Mirror Compatible?
  18. Fuel injector problems?
  19. shake
  20. cel code 456 issues
  21. Need Help! Please! Airbox disassembly/ maf adapter installation
  22. Brake Light
  23. Po421
  24. Question About Dash Lights
  25. squeking rattling noise
  26. RPM idle is low Please help!
  27. SES - Threw x2 P0181 - Fuel Temp Sensor. Fix?
  28. Fixed Blown Head Gasket. Need help clearing Code
  29. blower motor bulletin
  30. Washer Tank
  31. Question about 2003 Lancer OZ Air Conditioner
  32. headlight
  33. A/C vibrations and Warm
  34. Need Help tonight ASAP on Crankshaft Positioning Sensor Location PLEASE!!!!
  35. Spoiler Question
  36. my 03 lancer es
  37. quieting down exhaust???
  38. AC light not lighting up???
  39. Carbon Fiber Hood?
  40. turn signal/HZRDS
  41. Fuse Problem! need help asap.
  42. headlights wont turn on?
  43. Lancer Factory Service Manuals Available Here
  44. Idle Problems
  45. Help... where should this go??
  46. 2002 Lancer OZ Rally Repair manual
  47. Engine getting too hot?
  48. Timing belt repair
  49. 05 ralliart hvac control panel
  50. Blown had gasket changed now low comp??
  51. Trouble after intake manifold install
  52. starter question
  53. AC/heat stuck, won't move. Sun roof problem too.
  54. vibration in trunk
  55. bad putter/studder
  56. car wont start
  57. transmission sensor diagram
  58. Parklights not working?
  59. issues
  60. Gas lid help
  61. 03 Lancer run rough after new plugs
  62. A/C problem, sometimes it works, other times not so much
  63. weird issue on a/c
  64. Engine Light Off and On
  65. Kind of unimportant question/issue about instrument gauge but..
  66. Acceleration Issues
  67. Pulling "P0090"
  68. Brakes issue
  69. engine knocking and ticking
  70. Check Engine Light and Water
  71. Problem with cruise control, piggyback
  72. P0421
  73. HID kit with relay harness, weird problems
  74. Lancer doesn't start sometimes
  75. Lancer sportback stalling problem
  76. lancer is overheating
  77. Why? Does it Matter?
  78. Mitsubishis from Costa Rica!
  79. Ohm Fuel Level sender???
  80. A couple of OZ questions
  81. OZ Rally Owners!!!
  82. Please help!!!
  83. header noises
  84. High idle of between 1300 - 2500 RPM
  85. A/C Issues - Clogged?
  86. OZ Rally Lip Kit
  87. A/C knob broken
  88. Mirage head probs I think. Senate help!!!
  89. Where I can get a 2003 lancer fuel-tank cap spring
  90. P0135 CEL 2002 Mitsubishi Lancer ES
  91. Gas Milage for 03 OZ
  92. daytime running lights (front) won't turn on
  93. Downpipe cover?
  94. Xenon bulb help
  95. Help Needed Now! Key position locked
  96. Lancer not starting after sitting a couple hours
  97. 2003 lancer air conditioning problem
  98. tail lights fitments?
  99. Battery light on dash
  100. A/C Problem
  101. volt meter drop
  102. is it a motor mount??
  103. 2003 OZ O2 Sensor
  104. Strange Grinding
  105. Reset Engine service light
  106. My Stick Melted!!!!
  107. rmr seat bracket issues...
  108. 2003 oz problem
  109. srs and seat sensor problem
  110. p0171 engine code
  111. Alternator problem?
  112. engine squeeling
  113. Need Help: 2003 Lancer camshaft position sensor
  114. Spark Plug Wires.
  115. wheel bearing prices
  116. Bolt in starter cross threaded
  117. RRM Throttle Body installed
  118. HID question plz help.
  119. help me and i'll give you penny =)
  120. wierd noises?
  121. Lost Power-Steering
  122. Short Ram Intake, idle problem
  123. the lighter sensor burned out
  124. New Projector Headlights... Dead Battery! Help!
  125. Please Help with Throttle Bucking Issue
  126. Looking to buy a lancer
  127. Radio and power locks not working!
  128. ok i will seem very retarded im an aspiring car guy question about carbonfiber hoods
  129. alternator/electrical mystery...
  130. will and OZ exhaust fit ES
  131. check engine light keeps coming on
  132. water leak under glovebox
  133. Misfire between 0 and 5% throttle? HELP!
  134. Splash guards?
  135. Squeaking from rear end
  136. SRS light on?
  137. odd eletrical problem
  138. EVOVII cf hood on oz
  139. help lumpy bumpy rough idle!!!!!
  140. I need help please
  141. Wheel bearing?
  142. Fan Running Continously
  143. Cruise control and RPM needle issues.
  144. back light not working no matter what
  145. Electrical Problem... Please help!
  146. 2002 Lancer not starting/fuel injectors not recieving signal
  147. gas pedal sticking
  148. Is this SeriouS ???!!! Rust!!
  149. Bad/Rough Idle Thread
  150. Rattle Noise, problem?
  151. Help! Lumpy idle & misfires under high load
  152. Nooooo i need help!!!
  153. exhaust manifold gasket?
  154. How to change coil pack boot?
  155. Big Clunking prob after drop
  156. Aftermarket HID stuck on high beam
  157. PLZ HELP: P0300 , but only at high speeds. . .
  158. I'm a search-tard today, CEL list?
  159. Problem with 2003 Lancer ES
  160. P0181 & P0421 & Dim Dash Lights!
  161. Help! Broken bolt on alternator
  162. new pcv = low idle?
  163. Sun Damage Carbon Fiber
  164. P0171 - System To Lean
  165. Windows Getting Stuck
  166. need seats
  167. Idle Issues
  168. Hesitation under WOT (cold) = bad O2 sensor?
  169. oil leaks and SES lights
  170. overheating after headers installed
  171. Brake problem? What needs to be done?
  172. Cruise control problem
  173. wierd issue, new to me helpme:
  174. Tach problem
  175. light came on after changing my belts
  176. Leaking Tranny Fluid!!!
  177. No go from brembos
  178. almost like a miss when idle???
  179. Weird sucking noise in 2002 Lancer
  180. Timing Belt Repleced
  181. 2009 Lancer GTS Subwoofer Help PLEASE!!!!
  182. Warrenty/trans issue
  183. Sound in the steering column - need help
  184. SRS light goes on and off randomly
  185. 2002-2003 Lancer Projector Headlights
  186. Help With Start-up
  187. P0763 Shift Solenoid C Electrical
  188. 2006 lancer es problem
  189. Exhaust too loud! Oh No! HELP
  190. Heat wont turn on in 2003 Lancer Es
  191. SES - Cylinder 4 misfire
  192. Man that noise keeps bugging me!!
  193. Cigarate lighter not working....
  194. AC light comes on when heat is on...?
  195. Kind of weird, and I could be wrong.
  196. OZ shuts down in 2 sec.
  197. Hmm, thought the battery was the problem.
  198. Help with interior lights
  199. Loose Shifter
  200. OZ gauge needles off
  201. 03 lancer has noise and vibration
  202. Jacking my car to find noise cause damage?
  203. does this look like an exhaust leak to you
  204. 04 exhuast issue
  205. lights gone out
  206. No Heat!
  207. are lifters adjustable on 03 lancer oz
  208. Intake bolt broke.
  209. Engine running super lean at idle
  210. EGR Valve issues
  211. Problem with SS clutch line
  212. Help Seatbelts Dont Work!
  213. Intermittent starting issue
  214. no sound out of my stereo???
  215. knock sensor problems...
  216. RMR Type 1 Lip Help
  217. Start up belt squeal noise FIX
  218. Tunning Piggyback?
  219. Sputter. HELP
  220. oil leak on a 2002...
  221. lancer problem
  222. has anyone had their lifters replaced?
  223. o2 sensor problems!!!
  224. do i need to modify my exhaust
  225. Noise from engine
  226. emissions
  227. Headlights turning on by themselves
  228. What are the 3 wires going to the positive battery terminal
  229. new/used Exhaust smoking
  230. New Intake issues. HELP!!!
  231. Idle issues... Occurs about 4 days out of the week.
  232. emergency Please help
  233. Signals/Hazard don't work, relay?
  234. Car running a little rich (I think)
  235. tranny trouble
  236. 2 vibrations in 1?
  237. guage cluster help
  238. Sun Roof Gave out..
  239. Reverse Light and start up squeal
  240. Vacuum diagram?
  241. Huge sound when reversing,then something stuck
  242. steering wheel help?
  243. Belt Squeal ?
  244. Slight Squeak!
  245. Power go's Down?
  246. Painting 2003 Lancer ES
  247. 03 ES Engine Light on and off
  248. Clogged Catalytic Converter?
  249. Removing aftermarket EVO spoiler from 2003 lancer.
  250. Warm ac
