PDA
View Full Version : Lancer Troubleshooting
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12
  1. Cruise Control
  2. Aftermarket Steering Wheel
  3. front right rim/tire problem
  4. problem with ac controls
  5. Installed under glo light/ windows dont work
  6. Corner running light problem!!!!
  7. all my dash lights are dead??
  8. Help...my car wont start
  9. Somethings Wrong
  10. rather simple issue
  11. Rattle in door
  12. need RRM piggy back install instructions for manual
  13. Had a Problem Need Help
  14. Car running hot and idles weird
  15. B&M fuel pressure guage!!
  16. Put On R/B n Exhaust is hidden.
  17. CEL after unpluggin MAF sensor
  18. HELP Car won't start after piggyback install!
  19. Exhaust help
  20. Canadian Spec Lancer
  21. Braking noise
  22. Boost leak or broken compressor?? PLZ HELP
  23. Slight bumping feeling while stopped
  24. Service manuals for 2002 Lancer (should cover 2003 too?)
  25. my air conditioner is making weird noises HELP!!
  26. 1st gen apexi super afc
  27. Coil Pack not firing
  28. Help With Kamakazie Header
  29. Electrical problems after installing an SRI.
  30. Help!!! Trouble with intake...
  31. HOW TO INSTALL: kaminari body kit
  32. Another CAI mounting problem, Canadian version.
  33. shake and rattle only in drive
  34. my car is smoking is that normal?
  35. NEED HELP WITH FG Evo7 wing....?STABALIZE?
  36. Whining Noise
  37. floor mats???
  38. AC control lights
  39. strut bar help
  40. How much inner fender remove when installing AEM CAI?
  41. Does anyone know how to remove the side skirts and rear lip??
  42. My F***ing Exhaust!!
  43. after market tach
  44. Help with Gauges
  45. evo steering wheel installation
  46. MAF making zapping noises?
  47. help!!! steering problem
  48. car shakes at 2000 rpms
  49. Quick question
  50. exhaust smell
  51. idle shaking
  52. H1 Headlight= 1 Prong?
  53. Evo 8 Spoiler vibrating question
  54. SRI help
  55. piggyback problems, PLEASE help me RRM and evolved members..
  56. MIL Eliminator
  57. check engine light is on
  58. RRM Header
  59. US Wiring Diagram
  60. Installed my intake today, but theres one lil problem...
  61. For those of you with the so-called "Clutch rattle/tick"
  62. Buschur Highflow Cat install problem
  63. Automatic Transmission Jerk
  64. Electrical Issue. Stumped.
  65. post all STRANGE NOISE complaints here
  66. Post all RATTLE complaints here
  67. Post all SQUEAK complaints here
  68. Electric noise
  69. squeaking while driving...
  70. cedia headlight wiring...(not what you think)
  71. Part numbers?
  72. Did Search.....Need quick TIPS
  73. Burnt Fuse
  74. need help or service manual
  75. Throttle Body Set Screw
  76. hi-beam + low-beam headlights? possable?
  77. Sputtering.. some kind of misfire??
  78. Belt squeaking?
  79. Service Engine Soon Light.
  80. What's the name of this bulb?
  81. apex vafc or safc specs
  82. My Car is Up and Running again!!!
  83. No brake lights at all!
  84. Help!! engine probs
  85. Loose throtle cable
  86. Engine trouble - CAI + Rain???
  87. Clock Dimming (radio too) when HL's are turned on
  88. Removing Passenger Air Bag
  89. rrm rear swaybar
  90. Rattling noise from..then engine??
  91. Shimmy
  92. Test pipe help...
  93. engine noise at idle
  94. Antenna...
  95. Fans
  96. Throttle Body Cable...Help.
  97. cut ecu wires
  98. electrical problems help!
  99. acceleration noise
  100. steering column
  101. Is it supposed to be Jerky when I spin my Tires?
  102. RRM Gunmetals leaking
  103. Headlight electrical issues
  104. Squeeking coming from engine....pulleys?
  105. Cigarette Odor
  106. Do your stock tires go from under you on Rainy Days???
  107. Dome Light Problem
  108. dead battery from storing
  109. CEL light
  110. Noise in the steering column
  111. CEL light
  112. Engine ? Computer System ? i dont know
  113. Clicking Noise
  114. SO many problems, including rear bushings..
  115. SRI Installed/ Reset ECU?
  116. Low Idle Question
  117. headlight adjustment
  118. crap throttle response
  119. clicking from front driver side wheel
  120. clicking noise
  121. stock muffler removal
  122. lancer sidemarker replacement
  123. air fuel ratio correction?
  124. I think i messed up my gauges
  125. CAI question
  126. Help! ( car noises )
  127. axel back exhaust install problem
  128. turbo whine
  129. gasket sealant
  130. moisture in tail lights
  131. Power Line?
  132. electric trouble!
  133. strange noise
  134. help with service engine light
  135. Broken Buschur Filter
  136. damaged downpipe?
  137. calling all wiring and headlight experts
  138. Clutch
  139. weird problem turn signal on the cluster goes on when applying brakes
  140. rattling noise???
  141. MAS honeycomb question...
  142. The whole car is shaking
  143. Part # req. and brake question
  144. 03 Aem Cai Carb Eo #???
  145. front bumper damaged...need a little help
  146. 02/04 Lancer OZ
  147. Severe Rattle From Back of Car (Sounds Like Rear Windshield)
  148. Car dying as result of intake...
  149. jdm headlamps
  150. RRM Intake Part Missing
  151. Need Help Now Please!! Idling Problem
  152. CEL again
  153. Need Opinions Please!!!!!!
  154. SES light on..
  155. Reverse Style Guage Problems
  156. Rattling coming from trunk/ rear struts?
  157. Bodykit-blues
  158. Any ideas?
  159. Help Fast!!! O2 Sensor Prob
  160. RRM Header.. ??
  161. Where to find exhaust bushings?
  162. mas
  163. Noice On Driver Side...
  164. Intake HELP
  165. Testpipe bolt size?
  166. ///rrm
  167. A short in my headlights??
  168. Car Wont START!!! PLease HELP
  169. Door buzzer!!!
  170. Ignition Jammed
  171. Now turn signals won't work
  172. Noise when I turn it off
  173. wiper arm switch
  174. CEL came on today........
  175. please help? clicking noise
  176. your easy DIY = my hard DIY
  177. clunky lancer shifting
  178. Need a small part Please read and help
  179. 02 key?
  180. New Jersey's slowest Lancer
  181. my speed stops at 80!
  182. cattering noise
  183. My car is shaking .. steering wheel shakes, front wheels seem to shake?
  184. this sucks
  185. Front Bumper Removal
  186. rough idle/low idle
  187. Looking for a part
  188. Lights Out!?!?!?!?!
  189. clicking noise
  190. sway bar help
  191. Squeaking w/ AEM CAI
  192. Input needed............
  193. cant reach 4rpm
  194. Fuel Temp Sensor
  195. MAS sensor help
  196. Input needed - bucking
  197. Wiper blade
  198. Humming Sound
  199. test pipe trouble
  200. damn, my fuel econ blows
  201. New problems! (Idling this time)
  202. Problem with stock side skirts
  203. please help! car starts and dies
  204. I need help locating the fuse for my sunroof! Thx!
  205. a question to ppl who installed AEM CAI
  206. All around Greddy exhaust concerns thread (MERGE)
  207. Starter probs at 35000???
  208. serpentine belt going bad?
  209. Gas Mileage
  210. headlight keeps burning out
  211. problem with my shifter
  212. Mivec <<help>>
  213. Headlight Help!!!
  214. Trunk light, do we have one?
  215. noise in the rear of the car too!
  216. 80 miles already at half tank?!
  217. f*%$#!@ing squeek!
  218. Strut Bar Help!!!
  219. Gauges Dont Light up!!!!???
  220. AEM CAI install... SES LIGHT!
  221. complete dash removal
  222. safc to fix rough idle?
  223. cig lighter
  224. Service Engine Light????
  225. removal of muffler = exhaust hangage
  226. Injen CAI
  227. Replacing ugly orange bulbs...need help!!!
  228. helping a friend
  229. Cig lighter issue...
  230. HELP ME Comp. FRIED!!!
  231. whers the fuel filter
  232. help with intake
  233. intake problems
  234. Idling at 2 grand...
  235. What is this!!!?!?
  236. Possible boost leak
  237. AC Control Knob Not Working Right?!?!? Help
  238. airresearch turbo install HELP!!!!
  239. Unknown piece fell off!!
  240. okay new problem with misfire..
  241. gas pedal lag
  242. Please Help Me Now!!!
  243. auto tranny..
  244. new sound? what is it?
  245. LS to OZ gauge cluster
  246. why is my fuel pressure only @ 29 psi???
  247. Car stalling at low RPM! Help!
  248. spoiler holes?
  249. 3 Little Words/Questions
  250. Fuel Injection maybe???
