View Full Version : Lancer Troubleshooting
Pages : 1 2 3 4 5 6 [7] 8
  1. arospeed front upper strut bar
  2. coilover problem
  3. ECU wires and an AFC
  4. Acceleration pull
  5. oxygen sensor simulator
  6. Help Please! Short Ram Intake! Install!
  7. HELP!!! throttle problem
  8. Tail Light "out"
  9. Car Shuts off when cold?!?!
  10. Intake or Electrical problem??!!!??? HELP
  11. H/U and Clock black out
  12. need help removing rotors
  13. http://www.spiralmax.com/
  14. Anybody Online W. Test Pipe ??
  15. ECU pinout diagram for US spec OZ?
  16. Factory Wing/Wiring Removal
  17. engine
  18. Shaky Driving ?
  19. pls help tail light not workin'
  20. tail light not workin'
  21. removing dash !!urgent!!
  22. relocating battery to trunk
  23. MAS Adapter Plate
  24. Ecu
  25. Header & CEL. Please help!
  26. Headlights on while switch is off
  27. Fuel gauge off a little?
  28. RRM Exhaust
  29. Head lights
  30. i got a problem with me 2002 lancer
  31. Steering Wheel Shakes
  32. KN filter
  33. Noise coming from 2nd cat
  34. Replacement wing mirror
  35. Should i push for this to be fixed?
  36. Friggin busted gasket!!!!!
  37. Engine Problems........
  38. Turbo done/have bad tap?
  39. Test Pipe Prob
  40. Possible Control Arm Recall
  41. possible ECU problem...people who know about ECU's HELP!
  42. Back Seat Prob...
  43. Noise after new intake
  44. RRM exhaust
  45. Seat Burns
  46. Breaking at High Speeds
  47. regarding eibach spring install
  48. Mother Kills S-AFC
  49. Car Shaking
  50. put..put.. CEL again
  51. warranty voiding
  52. i need help installing my apex-i SAFC!
  53. Shor Ram Intake
  54. Check Engine Light
  55. wheel noise
  56. I think it's dead
  57. Installing Optima Yellow Top
  58. Fender QUestion
  59. serious or not?
  60. Header question...help
  61. Newbie's question
  62. fart sound
  63. engine is laggin
  64. Paint chipping
  65. Help QUICK! w/Greddy Exhaust Install
  66. rattling
  67. Turbo and emmisions?
  68. rrm exhaust nut size?
  69. need help with wiring through front doors.
  70. Water in headlight...
  71. bulbs
  72. HID healight kit
  73. Squeaky rear suspension...
  74. ac controls
  75. brakes
  76. blown fuses
  77. Help Me!!!!
  78. need some help installing strutbar
  79. idle problems
  80. rear defroster
  81. ECU Reset
  82. does this sound like i have a tranny prob?
  83. handbrake adjustment?
  84. ECU help
  85. straight pipe
  86. Warped rotors
  87. Flat spot
  88. Hit A Curb
  89. squeeking
  90. Killed my engine
  91. Dire help needed for catalytic converter
  92. Scraped rear bumper!!
  93. Mitsibushi lancer Paint?
  94. my rpm fluctuates
  95. Which wire is the correct one for a air/fuel gauge?
  96. Urgent!! Need Help!!!
  97. Water In Trunk?
  98. Annoying Creaking Sound..
  99. Suspension Problems
  100. cant get it back on!! please help
  101. wiring behind gauges
  102. worrysome problem
  103. my lancer is 2 tone grr
  104. evo VII hood
  105. Air Intake problem
  106. test pipe question
  107. fuse help..
  108. how to install pivot shift light
  109. Headlight alignment question.
  110. Which MOD Chip is the best for the Lancer 2003 LS?
  111. SRS Airbag Light
  112. Help..I need advice on a repair problem
  113. odd sound
  114. How do you install fog lights in a 2003 Lancer LS?
  115. New Lancer 2003 LS Whistling Sound
  116. New Lancer 2003 LS Steering Misalignment
  117. depressed...burned clutch
  118. "clacking" valves?
  119. Last Nut 4 Header
  120. is my car ****ed up
  121. Headlight Bulb Socket
  122. rrm header
  123. i think i got hydrolock
  124. very strange prob
  125. massive smog
  126. wierd sound
  127. SHift Knob
  128. Eibach Pro-Kit rubbing problem.
  129. Lancer Fart?
  130. Removing Front Bumper
  131. rmr intake idle
  132. Slight Rattle at high Revs
  133. HUGE problem!!!!!!
  134. Shifting gears...
  135. dents above the drivers door
  136. How do I get moisture out of my headlight
  137. Pinched Vaccum Hose
  138. I need help with my check engine light
  139. oil plug
  140. testpipe mpg??
  141. Recalibrating Gauges
  142. Flakey electronic logic?
  143. oil light
  144. when i turn my car off...
  145. Buschur exhaust fitment
  146. Aem Cai
  147. Seat Belt Light
  148. automatic high idle
  149. strange noise
  150. Headlight Adjustment
  151. Silver Star Headlights
  152. Test pipe installation question
  153. RRM intake installed....question?
  154. knocking lifter??
  155. how do i reset the "service soon" light?
  156. How do you turn the CEL off?
  157. Road Race exhaust section rattling
  158. wiring safc
  159. front end alignment and kamikaze header
  160. SES and ECU Computer Code advice
  161. flat tire... hehe actually I noticed rust when changing it.
  162. motor mount question
  163. Headlight Fading Question
  164. Evo7-style Grill
  165. Vaccum Hoses
  166. Clutch Chatter
  167. Maintenance question.
  168. Windshield wiper removal
  169. RRM Brake Pad Instal Help
  170. engine question
  171. RRM throttle body
  172. Breather filter..
  173. power loss
  174. Gasoline Smell...
  175. yellow valve cover
  176. eninge bogs when i give full throttle
  177. RPM's falling backwards
  178. Engine stalling after RRM Valve Cover installation
  179. engine prob
  180. Gas smell in oil
  181. Daytime running lights...
  182. mas swap
  183. Mas Sensor
  184. spark plug Q
  185. Steering Problems?!?!?!
  186. turbo ok..intercooler?
  187. Front Signal Lights Broken
  188. e brake and battery light flashing
  189. ecu harness for installing apexi afc???
  190. Turbo lag
  191. RRM exhaust install . .
  192. RRM Intake and MAS Problems
  193. Mitsubishi Shop Manuals
  194. Installing a MIL Eliminator
  195. hesitation during acceleration
  196. Idle Problems to Stall..
  197. Adjusting headlight angle
  198. powersteering
  199. Cruise Contro and RRM Throttle Body
  200. Broken Injen-Anyone else?
  201. Wiper problem
  202. help anyone?
  203. Just picked up RRM exhaust...great but too loose
  204. my cel is on and i dotn know why
  205. Major Concern
  206. need help installing tach
  207. 11 Thousand Miles and Dropping Oil...
  208. Front license plate scraping
  209. Cool Morning Car Noises
  210. brakes,tires,struts, pull to the right
  211. Kamikazi header gasket
  212. Shocking
  213. Door Handles
  214. Ses
  215. Pissed off at exhaust
  216. fog lights installation
  217. hooking up a tach
  218. Kamikaze Rattling
  219. Aem Cai
  220. firewall plugs
  221. odd noise
  222. Paint peeling?
  223. tapping noise coming from front driver side tire?
  224. clicking noise
  225. steering
  226. Optimum catback/piping size?
  227. Hit the curb with my rims CHROME
  228. Muffler rattling
  229. anyone have no problems with kamikaze header?
  230. front bumper
  231. How do you remove wax from rubber?
  232. Kamikazi Header Help!!!!!!!
  233. Service Engine Soon light not working
  234. Is that just heat shield?
  235. some crap comming out of my car?
  236. Does anyoens car make a loud knocking noise
  237. RRM rear sway bar noises??
  238. Rock I hope your online...
  239. friends lancer intake problems
  240. Headers and the CEL?
  241. Lugs..Damn it.
  242. %&#!@ damn top strut mount... NEED HELP!!!
  243. Test pipe install problem
  244. Front License Plate
  245. IAT sensor
  246. Electrical problem
  247. Breather help!!!!
  248. warranty...
  249. WTF!!! check engine light off now
  250. rev limiter eliminator? anyone
