- Timing Belt. Plz help
- concerns of hydrolock
- HELP!!! DEPO tail light wiring problem!!!
- A problem
- gauge cluster light not working
- vibrations in steering wheel
- Gauge cluster km/miles
- Help with Tranny
- GUYS i NEED HELP FAST!!!!
- Just installed cat pipe, muffler rattle?
- Fuel Filter Location
- fuel gauge wrong! help!
- Quick Blinking
- HELP: Fuel Pump Install
- Question Concerning Lancer ES Washer Fluid Reservoir.
- brake pedal...
- rattling noise in neutral?
- anyone install an air/fuel gauge on their lancer?
- grill rattle
- Knocking/clicking feeling 4th gear only, any RPM
- A/C Compressor/Electrical Issue
- Peculiar electrical problem [Please help]
- HELP... Error Code P0421, "Warm Up Catalyst Below Threshhold"
- Wheel hop/tranny slip?
- help with door
- A/C Problem Need Help.
- I keep blowing fuses
- rrm header tingling/rattling noise.
- anyone know how to flush steering fluid
- Weird noise when turning
- Whats wrong. HELP
- Climate Control Problems
- Sealing exhaust gaskets.
- lil vibratn in brake from wipers?
- My car is shaking, please help.
- AEM CAI Mounting bracket broken. With Pics. What do I do?
- Smoked Engine
- Blown engine?
- Piston rings?
- SES light/intake
- Rather odd cooling system question
- is it possible to program a Lancer's remote control?
- the tach needle bounces back and fourth at idle.
- Nothing electrical works…
- Painting the grille.
- How do you clean melted bumper off of muffler?
- steering problem again HELP ME
- anyone else getting code p0300?
- Peeps with RRM header
- driver seat squeaking
- headlight aiming problem
- Bulb size for ES gauges!!
- Emanage schematic
- Felt like tranny was stuck in gear today...
- Radiator Fluid Type
- Springs question
- Speedo gauge is off...
- RRM Throttle Body/Gas Mileage?
- Help!!! Quick
- Flip-Flop trunk help.
- RRM Throttle Body Noise
- Help! Header Install - How to get to the lower left nut?!
- problems with stock battery?
- Smoky the Bandit
- noisey a/c
- Question to everyone
- Knocking Trans
- Knocking when foot is off clutch
- Loosening the top nut during spring installation
- Doors that wont close in the summer and broken cruise control
- Sunroof Wont Close, anyone experience this?
- Engine blew up
- Help! My stero & clock won't come on now that I installed my Amp & Subs!
- how do u take off our hand brakes
- Timing Belt Install [PLEASE HELP]
- hi-beam + low-beam headlights? possable?
- Hood Latch Question for EVO VII Hood!
- Full Throttle Question
- Cruise Control
- Aftermarket Steering Wheel
- front right rim/tire problem
- problem with ac controls
- Installed under glo light/ windows dont work
- Corner running light problem!!!!
- all my dash lights are dead??
- Help...my car wont start
- Somethings Wrong
- rather simple issue
- Rattle in door
- need RRM piggy back install instructions for manual
- Had a Problem Need Help
- Car running hot and idles weird
- B&M fuel pressure guage!!
- Put On R/B n Exhaust is hidden.
- CEL after unpluggin MAF sensor
- HELP Car won't start after piggyback install!
- Exhaust help
- Canadian Spec Lancer
- Braking noise
- Boost leak or broken compressor?? PLZ HELP
- Slight bumping feeling while stopped
- Service manuals for 2002 Lancer (should cover 2003 too?)
- my air conditioner is making weird noises HELP!!
- 1st gen apexi super afc
- Coil Pack not firing
- Help With Kamakazie Header
- Electrical problems after installing an SRI.
- Help!!! Trouble with intake...
- HOW TO INSTALL: kaminari body kit
- Another CAI mounting problem, Canadian version.
- shake and rattle only in drive
- my car is smoking is that normal?
- NEED HELP WITH FG Evo7 wing....?STABALIZE?
- Whining Noise
- floor mats???
- AC control lights
- strut bar help
- How much inner fender remove when installing AEM CAI?
- Does anyone know how to remove the side skirts and rear lip??
- My F***ing Exhaust!!
- after market tach
- Help with Gauges
- evo steering wheel installation
- MAF making zapping noises?
- help!!! steering problem
- car shakes at 2000 rpms
- Quick question
- exhaust smell
- idle shaking
- H1 Headlight= 1 Prong?
- Evo 8 Spoiler vibrating question
- SRI help
- piggyback problems, PLEASE help me RRM and evolved members..
- MIL Eliminator
- check engine light is on
- RRM Header
- US Wiring Diagram
- Installed my intake today, but theres one lil problem...
- For those of you with the so-called "Clutch rattle/tick"
- Buschur Highflow Cat install problem
- Automatic Transmission Jerk
- Electrical Issue. Stumped.
- post all STRANGE NOISE complaints here
- Post all RATTLE complaints here
- Post all SQUEAK complaints here
- Electric noise
- squeaking while driving...
- cedia headlight wiring...(not what you think)
- Part numbers?
- Did Search.....Need quick TIPS
- Burnt Fuse
- need help or service manual
- Throttle Body Set Screw
- Sputtering.. some kind of misfire??
- Belt squeaking?
- Service Engine Soon Light.
- What's the name of this bulb?
- apex vafc or safc specs
- My Car is Up and Running again!!!
- No brake lights at all!
- Help!! engine probs
- Loose throtle cable
- Engine trouble - CAI + Rain???
- Clock Dimming (radio too) when HL's are turned on
- Removing Passenger Air Bag
- rrm rear swaybar
- Rattling noise from..then engine??
- Shimmy
- Test pipe help...
- engine noise at idle
- Antenna...
- Fans
- Throttle Body Cable...Help.
- cut ecu wires
- electrical problems help!
- acceleration noise
- steering column
- Is it supposed to be Jerky when I spin my Tires?
- RRM Gunmetals leaking
- Headlight electrical issues
- Squeeking coming from engine....pulleys?
- Cigarette Odor
- Do your stock tires go from under you on Rainy Days???
- Dome Light Problem
- dead battery from storing
- CEL light
- Noise in the steering column
- CEL light
- Engine ? Computer System ? i dont know
- Clicking Noise
- SO many problems, including rear bushings..
- SRI Installed/ Reset ECU?
- Low Idle Question
- headlight adjustment
- crap throttle response
- clicking from front driver side wheel
- clicking noise
- stock muffler removal
- lancer sidemarker replacement
- air fuel ratio correction?
- I think i messed up my gauges
- CAI question
- Help! ( car noises )
- axel back exhaust install problem
- turbo whine
- gasket sealant
- moisture in tail lights
- Power Line?
- electric trouble!
- strange noise
- help with service engine light
- Broken Buschur Filter
- damaged downpipe?
- calling all wiring and headlight experts
- Clutch
- weird problem turn signal on the cluster goes on when applying brakes
- rattling noise???
- MAS honeycomb question...
- The whole car is shaking
- Part # req. and brake question
- 03 Aem Cai Carb Eo #???
- front bumper damaged...need a little help
- 02/04 Lancer OZ
- Severe Rattle From Back of Car (Sounds Like Rear Windshield)
- Car dying as result of intake...
- jdm headlamps
- RRM Intake Part Missing
- Need Help Now Please!! Idling Problem
- CEL again
- Need Opinions Please!!!!!!
- SES light on..
- Reverse Style Guage Problems
- Rattling coming from trunk/ rear struts?
- Bodykit-blues
- Any ideas?
- Help Fast!!! O2 Sensor Prob
- RRM Header.. ??
- Where to find exhaust bushings?
- mas
- Noice On Driver Side...
- Intake HELP
- Testpipe bolt size?
- ///rrm
- A short in my headlights??
- Car Wont START!!! PLease HELP
- Door buzzer!!!
- Ignition Jammed
- Now turn signals won't work
- Noise when I turn it off
