- strange noise
- help Cel light came on last night
- Help please
- Clutch Problem?
- Idle thing Ive heard mentioned here before...
- Please help!! Check Engine Light on!
- speedio problem
- Odd Problem
- Idle Problem
- Problem With Idle Help!!!!!!!!!
- Has anyone else broken the locking ring for their headlamp?
- Loose steering wheel?
- eBay service manual cd
- Problem... is anyone outhere?
- Headers ...Huff.
- Adjustable shift light
- accelerator problem
- engine shut off when driving.
- Can't get the car to start but half the electricity works!
- Problems with PB V.2
- Squeeky noise w/Defroster
- CEL Still After Check Engine Light Eliminator
- Strange rattling sound - Any help appreciated
- having trouble disconnecting battery
- I really hope I dodged a bullet
- Idle problems..
- Sucked In water...need help
- READ THIS - water leaking, HVAC, blower motor
- trunk plugs
- Need help! Heater problem
- Help!
- Strange problem
- How To: Far left exaust manifold nut <- STICK THIS
- temp sensor
- Cigarette lighter fuse where??
- Problem with installing RRM test pipe
- clearing the CEL from header...
- Brake lights on w/ blinker & reverse?!
- Service Engine Soon light turns on and off
- dissapointing dyno results
- HELP _ Bottomed out Lancer
- AC not working...
- splash guard ripped
- #1 Cylender
- If I Get Zapped One More Time . . . !!!
- I'm officially stumped...
- Pioneer in Dash Screen/DVD AV INPUT PROBLEMS!!
- dude i need help trouble codes
- Factory Shift Indicator?
- my horn wont work
- ECU RECALL Now bumpy idle!!
- keys stuck!!!
- gauge cluster ?
- i need some electrical help....quick.
- Steamy windows...please help!!!
- AC/Heater knob won't stay down!
- Filter came off! Oops!
- How would this happen?
- RRM Test pipe buzz..
- problems with es
- WOW! i think that my car is EFFED!!
- water in intake
- Battery Problem
- AEM CAI rubbing...
- TPS readings on Auto
- MBC help
- PB ECU help, can't get front plate removed
- Gauge cluster wiring
- Drivers side power lock
- Driver side window problem
- slow driving shudders?
- I can't find the cause to my misfire: please help
- OZ mirrors vs 'standard lancer' mirrors?
- HELP!! YOUR opinion PLEASE!!
- stalling problem!!!
- Cigarette lighter stopped working!
- A/C Is knocking!!
- My service engine light is on
- IM install gone really really wrong
- My car won't stay running
- Kamikaze DP and RRM CAT Help
- Gauge
- cutting auto gear shifter
- CF tips to make a good fit???
- anyone have a headlight wireing diagram??
- My lancer is making me wish I purchased something else
- 2nd Gear Lag
- i searched but couldnt find
- Need input: Weird engine sound
- Oil light comes on
- header
- why does it feel slower after i installed a down pipe and a cold air intake?
- Front rattles like crazy
- Purge Valve in Gas Tank??
- what fuse is for windows/int light/mirrors
- MPG troubles
- GURUS HELP! Run withouit second o2 sensor????
- Kaminari FB doesnt fit w/intercooler pipes
- What do you guys think-Please read
- Need more help-ASAP
- Help ASAP-Very low idle
- Front License Plate removal
- Is it a TRACTOR or an OZ?
- Need to find Light ECU
- Service Engine Light
- Need Help Please!!
- Kick Pedal Removal
- Cel
- engine overheating after repairs
- AC knob backlight problem
- Somone has to know
- My exhaust giggles
- RRM piggyback problem, gas gauge not accurate
- Trouble code P1400 on 2003 Lancer
- Opened fuel pump to check install then reinstall now wont start!!!!
- Vacuum question
- Throttle issue
- Rpm spike to 2000-2500
- Troubleshoot my sparkplugs
- HELP (weird idle and SES light)
- Broke Dip Stick - Help
- Aem Ram Air
- Brake question
- Cat Bolts
- Exhaust question again
- Rubbing noise from the back wheels
- need help figuring this out
- problem wiht coilovers
- Problem while debadging...
- How often to change air filter
- How hard to change 02 sensors and where are they
- have power, no start? (need all the help i can get)
- Injen SRI hitting battery
- Exhaust question
- Mass Air Flow Sensor Problem
- need help w/ gauge cluster lights
- Programming keyless entry
- Help PLease, fuel pump!!!
- Wheel stud problem
- SRI blew off the intake manifold??
- ssshhhaaakkkyyy
- electrocuted
- CEL after cold air installation
- Aem Intake Problems
- Bit of troubleshooting help
- What Are The Odds Of Fixing This? *pics*
- wheel alignment price?
- Tachometer wont work "Help"
- Check engine light came on tonight. Ideas?
- 4G93 and P0401?
- Ticking, Popping sound I have no Idea
- Fuel Gauge
- Pcv
- Need Help Passing Emissions
- Do I need to replace my air filter or just get a recharger?
- Lancer's running PIG RICH....
- terrible clicking noise
- Please help me with a fitting question
- Keyless entry, clock, and dome not working!
- Misfiring, Spark Plugs, wtf?!
- stuck in the rain
- water leak
- windshield cracked....
- foggy tailight. how to get rid of?
- Interior question
- High Rev in the morning
- code 0421 cat efficiency low
- Fuel Pump relay installation direction
- Spark Plugs Do NOT Want to Come Out!
- Fuel Pump not pumping
- Help ESL On
- From oz rally bumper to evo bumper
- gauge cluster needles
- fuse panel
- Help! B&M adjustable short shifter install problem
- 4G93 IM, idle problems?
- engine idle problem???
- Swapped Evo 7 Wheel, now the turn signals dont turn off...
- Help with Buschur exhaust
- Weird Slipping?
- Engine revving itself in traffic
- Help me.
- volt gauge how-to
- I have coolant in my intake??
- ES->OZ gauge swap
- Loss of power :(
- camber problem
- Idle issue
- fuel
- Need help: Car is not starting
- Factory Service Manual (FSM)
- Leaning Lancer
- what color wires.. guage harness 02lancer
- Grounding Problems - please help!
- WTF, now I hear a whirling noise, what could it be?
- Help Please!!!!
- i dont have constant power...but accesory works?
- No power when my keys are out...
- New 05 Lancer, and it smells like oil burning!
- Anyone with a sunroof??
- do the OZ come with antilock brakes?
- Need HELP
- Engine Code with RRM Stage 1
- 2000 RPM rattle
- Weird problem no body has! (electrical)
- Help A/F install!!!
- HELP, Oil light????
- Figuring out rattling sound...
- Fadding Paint
- Air
- hand brake removing?
- cold weather = worse engine sound?
- Engine Shut Off.. Why?
- header removal
- Gas Mileage
- Exhaust leak and leak and leak
- Led burned out..why?
- RRM hose kit
- Fuse Diagram?
- Dim Cluster
- Dim lights
- Cigarette Lighter doesn't work. WTF!?
- factory pant problems
- chirping sound when I'm at idle
- Strange winding-up noise
- No More 2nd Gear
- possible transmission problem??
- Help Plz... Head Unit Probs
- A major hole in a metal pipe under my car...problem?
- skipping
- OZ Rally front suspension questions...
- US Lancer Wiring Diagram - PDF
- headlight wiring
- I crashed my lancer
- Any way to check MAS and o2 sensor?
- stock header removal questions
- 02 sensor
- ECU wiring diagram
- loud click
- Has anyone have any problems whit the parking lights in their car
- help is it safe??
- Karr Alarm
- buschur downpipe leaks (flex pipe part)
- keyless signals
- Piggy back and then CEL?
- obd code please help what does this mean?
- I now have a low IDLE
- Grinding in 1st and 2nd
- Where the F is my washer fluid going?
- alternator belt please help
