- electrical problems
- Bulb frying my harness?
- Vibration In Cabin and Pedals
- Exhaust Prob...
- Crankshaft Position Sensor Malfunction...
- Truck won't open!
- Something wrong with brakes?
- Knocking at right front wheel
- MAF Sensor Problem, unplug ECU and it is fine...
- Car Horn Steeling Wheel
- 2003 Lancer...won't start.
- bad fuel injector???
- Unstable Steering wheel?!
- Quick questions...
- headlight flickers when driving...
- Dash Backlights are dead?
- power steering pump
- A/C led??
- rear seat belt
- boost leak?
- revving during idle...?
- Wont Idle
- wrong air intake??
- Help with code and starter !!
- Lancer Recalls!!!
- thumping sound?
- RRM Header Problem
- Tsb: Dtc-p0335
- ahhh clutch!!!
- HELP!!! Weird knocking when at a stop...
- Warranty question
- car is stuttering big time
- Lower Arm Under-Brace
- K&N Air Filter
- Which Battery
- Latin Lancer: OZ or Ralliart?
- burning smell after CAI install
- Too much power steer fluid
- Cruise Control
- Exhaust Not Fitting
- Speaker problem
- O2 Sensor and Cat Converter
- Very Odd Sound
- intermiitten and slow starting HELP!!!
- Tach redlines at 4000?
- way to brighten stock lights w/o getting cheapo hid's
- Is my car safe?
- Bad tires causing vibrations?
- do i need a new clutch?
- Door Trouble!!!!!
- spark plug tube removal
- My wing broke!!
- alarm
- Nozzle sprayer issues!!!!!!!!!!!
- CD Player E 01?!!
- car died while driving and wont start again
- Exhaust leak causing car to die?
- Creaking noise from steering
- New timing belt, car now makes nosies
- Oil pressure gauge?
- Once again, Lancer + Stupid extreme cold = no fun
- curb problems
- Lifter knocking
- Not Starting after rebuild
- replaced 02 sensor and still a code?????
- Electrical Short
- Car dying on me...wtf?
- Car pulls to the right.
- need help installing tach!!
- Lancer+Extreme cold = no fun
- Bad Harmonic Balancer, need info.
- 2002 Lancer Temperture Knob hard to turn over
- Bought a K&N Typhoon short ram, Low idol/ oil light
- Weird noise when A/C is on
- Broke Intake Mani Bolt!!
- WTF? Steering Wheel Prob
- Shifting issue
- Cold engine startup problem. (whole car shakes)
- Speedo
- RPM bouncing while idleling
- Normal idle RPM?
- Why did Mitsubishi do this ? (spark plugs)
- scratch removers?
- HVAC no longer works. Any easy fix possible?
- Weird sound at start up
- Anyone have access to FULL TSBs???
- oil light comes on at idle?
- check engine light question
- Clogged Cat?
- engine trouble
- exhaust tip touching body kit!! what to DO??
- Car squealing at start up
- Lighting problem
- o2 sensor help
- Need guru help on power steering
- Need Help with Brakes
- Slave Cylinder
- Broken Temp Control Knob.....Help!
- Uneven tire wear
- CEL light on EVEN with eliminator!
- help!!my car dies and wont start!!
- cd player
- Rough Idle in the Rain
- wedge bulb for cedias
- car dies after stoping
- I think the blower motor may be going...
- Greddy evo2 Exhaust *BUMPER MOD HELP*
- Screwing around got me in trouble
- Hesistation
- HELP HELP HELP - water in engine!!
- Throttle/Gas Pedal Response
- Scratching sound when I brake!
- Car overheating
- Wheel Bearings Keep dieing
- Clutch pedal is harder to press down
- power steering??
- evo 8 wing install
- Blower Motor Sound?
- Tailight Problem *Wiring Perhaps*?
- 02 ES Stalls at idle
- Weird situation
- fog lights
- Fuel gauge Problem?
- Electrical Problem
- Odd problem
- Front end driver side shake?
- Sunroof won't close
- Rough idle
- Oil level and Pulsating RPM
- Suspension Rattle
- Fuel Inlet Restrictor where did it go??? ohh AND P0421
- HELP FAST!! Unsealing resealed lights..
- My Clutch!!!
- egr valve
- coilpacks
- clickclickclickclick when im in drive stopped
- noise going over a bump or dip
- exhaust replacement suggestions
- won't stay running
- High Rev Problem
- Hesitation in Accelleration
- ac problem
- Exhaust, Progress Antisway and springs problem
- need help car has i rough drive
- HID Problem
- Loud Noise under the car
- Idle Problem
- Fuel injectors/rail question
- Weird noise, and it's not the usual squeak
- o2sensor/Heater
- rough start up?
- hid flickering randomly
- Vibration when I drive
- Air conditioning leak? (need help)
- Brake light? WTF
- Simple question...
- Water??? from where
- RRM Header SES
- Car shakes at 75-80 MPH
- High mileage, what maintainence should be done?
- Fuel Gauge Problem
- p0102 error code
- Car won't start
- suspect: cv joint - culprit: ball joint?
- car pulls hard and wheels wobble at 65+mph
- High Idle, help!
- Control arm bushings????
- Cat Problems?
- backfiring question
- Ground Wire Kit Question!?!?
- SES Computer Code 0421
- Help trouble shoot my A/C porblem..hesitation
- Blowing Power Window Bus Fuses....
- Shifter problem...
- I think i f-ed up my trans
- High revs in park?
- Help Loud klunking sound Pics and more info inside
- Squealing belt
- accolade rear bumper cracking....
- LC-1 Wideband problems...
- Radio dont work anymore
- window no work
- Cel P0421
- RRM piggy Ver.1
- After a week of trying !
- Battery/alternator problem - help?
- Changing decks
- got a hole in your radiator??
- Cannot get remote programmed!!!!
- engine control fuse keeps blowing out
- Another RMR install problem/question
- Header Gaskets Question
- Startup problems...
- Idle problems
- Broken Spark Plug?? HELP!
- trouble removing badges
- Bigger Injectors for N/A lancer?
- A/C Problem
- P0135 O2 Sensor Heater
- Timing belt jump
- Oil Problems
- Is my clutch going out?
- Headlight Question
- High-pitched vibration noise
- Car problems!! Bah!
- 2002 ES Camshaft Position Sensor Install?
- Friction with Kartboy shifter bushings
- cruise control turns off when right turn signal goes on
- Need help getting the headlights off an 06!
- Spark Plug Help!!
- Wtf .. got my front strut bar today
- lights out!
- Ah I broke a screw!
- Temp control knob
- downpipe heatshield rattling
- Wow i juss installed my short ram intake
- Help! Cig lighter not working!!!!
- Help with FUEL LOSS
- A/C wont shut off!!!
- How do you take out door panels?
- Brights out, but reg. lights still on??
- CD player error ER1 ?
- turn signal fuse
- Wheel Shimmy
- Gasket???
- died left side(whole) lights! please help!
- RMR Lip Type1
- P0456: Evaporative... System Leak
- Weird idle
- Low Oil Pressure VS Slipping belt
- Where did you put/hide your ballast for your HID's?
- hummmmmm
- trip gauge
- here we go again
- Need to rewire back my oem headlights
- ticking/rattling/knocking/
- Tick Tock
- Belts
- Sudden power loss to cylinders 1 & 4 !?
- I got 99 problems...
- dash light problem???
- How important is 30000 mile service
- lancer running loudly
- Car stalled when I turned A/C on ???
- Cobalt Air/Fuel Gauge Problem...
- Belt problems!!
- windshields
- Windshield washer fluid pump
- OBD II codes
- Installing anti fouler on O2 sensor.. where is it?
