View Full Version : Lancer Troubleshooting
Pages : 1 [2] 3 4 5 6 7 8
  1. No spark/no fuel to engine?
  2. egr problem and running rough
  3. Squeaking exhaust
  4. 02 OZ cuts out under 3000RPM
  5. Tach in new dash doe not work. Help.
  6. Code P0421- Call Mitsu before you do anything!
  7. Issues after CAI install
  8. A/C problems and vibrations
  9. 2003 OZ Rally tinging?????????????
  10. Need Help!! (^_^)v Please!
  11. Is this an exhuats leak??
  12. Lancer... Problems with part durability/car reliability...
  13. weird noise coming from engine
  14. 02 Lancer OZ overheating and other problems
  15. steering wheel problems
  16. Factory alarm not working
  17. Help! AC turns on and off by itself
  18. Oh Noes! My Cruze Controlz!!
  19. help needed radio, clock, key fob not working
  20. O2 sensor question
  21. my car died on the freeway
  22. Brake Pedal Vibrating
  23. car shivers
  24. Help!!!
  25. Odd squeal when wheel isn't turned
  26. turn signals not working
  27. What is the Difference between ES and SE?
  28. Help! Nasty Sound when trying to Reverse
  29. Strange Idle after 4g93 manifold
  30. throttle cable siezing
  31. A/C problems.... and few others....
  32. What Engine do I have?
  33. fuse's
  34. Help!!Clock Spring
  35. Need help haveing wierd noise from engine
  36. check engine light... code PO135
  37. Bogging and cylinder misfires in 2002 ES
  38. Car will not start
  39. Wireing / Fuse HELPPP!!!
  40. Grinding noise from left front wheel area
  41. Sunroof Fuse??
  42. Help!!! Bad Rumbling
  43. Evo WING For OZ Lancer
  44. Car won't start, please help
  45. Sunroof
  46. Depo Headlight alignment
  47. rough idle? whats causing it?
  48. Bumpy road steering issues
  49. Help - Engine Fan stays on
  50. some issues, need help
  51. Auto-cruise-control-ecu pin out
  52. How much $$Labor is it to check wear on timing belt?
  53. fuel pump
  54. Before I buy this Lancer...
  55. timing with stage 2 cam
  56. need help asap
  57. Right hand tail light and marker light + no gauge dimmer
  58. Sputter ??
  59. power windows not worcking
  60. walboro fuel pump not pumping
  61. problem with my heater unit?
  62. Car not starting, possibly no fuel pressure
  63. Eliminating Secondary O2 sensor?!?!?!
  64. Unstable voltage!!!! help
  65. High Idle when car is hot.
  66. radio fuse???
  67. 03 Lancer A/C problems
  68. Reconnecting the o2 Sensor
  69. radio reception cut-out when HIDs turn on
  70. Trouble from K&N Intake
  71. idle trouble
  72. egg smell?
  73. Front suspension problem?
  74. Light on the Trip Odometer
  75. Need Help!!!! Tail light problem
  76. Engine Problem..Need help!!!
  77. Help Please, I Need Help :-(
  78. evo steering wheel
  79. bad relay/flasher...
  80. everytime i put a new fuse in it blows.
  81. No Spark, Car Won't Start
  82. Backlight out on stereo
  83. Possible Electrical Problem
  84. Cant remove steering wheel
  85. help..melted ecu connector..now what
  86. Looking for a part, turning light holder, 02 lancer es
  87. Swappable Gauge Clusters?
  88. I'm screwed!
  89. Tight Gears!?
  90. Dash Lights don't work
  91. clutch goes straight to floor with no pressure
  92. Heard a "pop" and then it died
  93. Another water leak!!!
  94. Spark plugs causing bad MPG?
  95. Shaking on takeoff in 1st...
  96. Problem with steering wheel vibration!!
  97. Dome light comes on at random (power off)
  98. '02 starting problems
  99. Eclipse HU and Ipod adaptor help...
  100. Windshield Washer Spray Nozzles
  101. Fog Lights
  102. keyless entry...
  103. New bored throttle horrible shifts
  104. Curbs SUCK!
  105. vibrating/out of round issue
  106. Wierd "ticking" noise
  107. Big Problems
  108. noise after accelerating
  109. maintaining CAI in wisconsin winter
  110. Hit a Crub, fixed (some of it) and aligned. Still need help...
  111. serpentine belt pulley noise
  112. Small or Big problem??
  113. PO421:Warm Up Catalyst-below threshold (bank #1) CEL
  114. Convert to LEDs
  115. Electrical Problem
  116. Cigarette Lighter
  117. this can be a problem
  118. Must fix annoying rattle!!!!
  119. car bogs
  120. trying to find transmission filter in 03 lancer ES
  121. HELP QUICK!!! Starter wont engage!
  122. 02 Alarm system
  123. Help Sunroof
  124. Squeak Problem Fixed!
  125. Horrible Problem
  126. egr help:helpme:
  127. weird idle after transmission replacement
  128. EGR Problem...
  129. Help!!
  130. Weird Engine Noise HELP!!!
  131. Problem Accelerating - RPM's Race Up but no power change
  132. aftermarket tailight problem.
  133. Battery problem
  134. weird lights
  135. Radio and clock just went out
  136. Problems RPM Stayin Up
  137. lug nut studs
  138. loud snap sound after car is warmed up/idle
  139. Breaks squeaking
  140. P0421 and P0301 codes after 100 miles...
  141. My HVAC Dials refuse to move...
  142. radio and dash
  143. Intake squeek, belt noises, etc.
  144. I think this is bad...
  145. 2 Minor Issues I have questions on...
  146. How to do a headlight conversion
  147. Greddy Counterweight shift knob not installing
  148. 03 lancer ES hvac...
  149. my lancer is HOT and i mean over heating
  150. Parts from evo on an ES
  151. tranny swap?
  152. compatability between lancers?
  153. hard gas pedal
  154. I believe it is but I have to double check...
  155. Cruise Control
  156. 03 Lancer ES: Just Quit.
  157. Exhaust and Intake Question...
  158. cylinder 4 misfire issues (P0304 and others!)
  159. ATTN: Those with rough idle....
  160. ways to prevent/cover up rust?
  161. Downpipe problem
  162. Gauge cluster help
  163. Right Tail Light?
  164. Coolant temp. gauge acting weird, any suggestions?
  165. Debadging gone wrong
  166. Light Bulb Types For Depo EvoVII Tails
  167. Electrical Wiring - Max Voltage/Watt threshold for 03 Lancer
  168. Battery dying.
  169. Daytime running lights
  170. 03 lancer OZ multiple engine problems
  171. my keys wont come out?
  172. Car rocks back and forth when starting
  173. Fuse Box Diagram
  174. Car still not runnin(HELP)
  175. CAI Problems
  176. brake lights problem, fuse or bulb?
  177. bulbs?
  178. timing belt
  179. rrm pulley
  180. OEM style foglights of Ebay
  181. Car wont start
  182. my a/c exploded
  183. Having problems with my car starting...
  184. Remove Stock Side Skirts
  185. Weird smell.
  186. Car won't start-not getting fuel?
  187. Inner Tie Rod End
  188. Help with gauge install
  189. got an issue? here's a tissue!
  190. Won't start
  191. Need help removing strut top nut!!
  192. Jerkiness when slowing down
  193. a/c help
  194. A/C not working
  195. Gas Sensor/Guage
  196. gaz tank
  197. GAP btwn Bumper&Headlight
  198. Front Radiator Support.
  199. Gauge Cluster needles sticking
  200. Greddy EVO2 exhust Mid-Pipe Question
  201. ac problems (im runnin out of ideas)
  202. Gas mileage problems
  203. Engine Fans
  204. air intake problems
  205. Weird Noise
  206. Tie rod end issues...
  207. Tie rod end issues...
  208. Low IDle...
  209. RRM Piggyback with worse MPG
  210. Evo cluster Anti Lock
  211. Help!
  212. damn damn damn
  213. p0107
  214. Oil Disapearing
  215. blackout tail lights
  216. PO401 Insufficent Exhaust Gas Flow
  217. A/C not working
  218. service engine light
  219. A/C Controlls..
  220. 60000 Mile Service
  221. 2003 es hvac the same as the 2005?
  222. having a hard time shifting into 2nd gear
  223. instrument panel
  224. P0715
  225. p0421
  226. clutch bleeding problem
  227. Brand New Optima Red-Top and now Car wont start..???
  228. Idle Problem
  229. A/C Issue
  230. Problem with engine possibly? Over rev's
  231. Lancer doesnt run properly please help..
  232. stupid brakes
  233. HID install
  234. Front end clanking sound
  235. Good news about ses light
  236. OBX Header/ O2 problem
  237. HELP plz bad
  238. Headlight going out... often...
  239. Lancer Es Gear Knob
  240. Really strange and annoying under-hood noise
  241. Oxygen sensors?
  242. Help Help Lancer Wont Start
  243. Car Stutters during take off, almost no power... picks up when u floor it.
  244. Glove Box Won't Close
  245. car wont run right in park
  246. a/c off car stalls
  247. Low Idle
  248. Also an electrical problem
  249. Depo Evo VII Clear Taillights Wiring Problem
  250. 2 Questions
