- 02 lancer OZ service manual
- Clutch issue
- cel for o2s when the work fine?
- i want to swap my tranny help me
- Power Steering Gone???
- lance clutch act?
- 03 OZ clutch question
- Clutch slipping
- Clutch problems(throwout bearing)
- Several Error Codes
- Automatic Transmission Filter
- are you tired from speed limit sound i have the solutino
- auto swap 2 manual
- 02 OZ Lancer 2.0L
- hey you
- Upgraded Torque Converters
- Manual tranny oil
- Lancer OZ Clutch Kit
- Slave cylinder swap
- fwd to rwd......possible?
- 6 speed on a 02 lancer es ... possible?
- swap tranny question
- help with clutch install question
- alternator belt
- Clutch Problem
- clutch
- Went Out In Parking Lot Today
- Need a new clutch for 2003 lancer oz, recommendations?
- Am I screwed?
- Lancer 03-04
- 04 oz trans in an 03 oz?
- RRM clutchline
- Auto tranny upgrade for 4g94
- Torque Converter 2002-2006
- Requirements for new Clutch
- 2002 Lancer OZ clutch problems
- Looking for a Cluch for an 06 Lancer
- Ralliart axles???
- No clucth
- Installing a clutch on an 03 OZ
- 2003 Lancer front tranny mount
- 2003 Auto Tranny Insanity
- Anyone actually seen the factory A/T filter?
- 05 Tranny Noise/Vibration
- Problem with bleeding the clutch...
- Has anyone heard of this??
- ralliart tranny onto oz or es engine
- Another try at auto shift kits?
- Which Stage 1 Clutch to buy? (OZ Lancer)
- Help! After trans swap problems
- syncros?
- Slipping Clutch..
- Interchangeable transmission parts 03-05
- Built auto or manual tranny?
- stonger trans
- mirage clutch
- Not sure what its called....
- ss clutchline help!!
- shifter bushings
- Question about transmission swap.
- motor mounts
- Underhood shifter bushings
- question for hub swaping
- Cluster
- A/T Boost Controller
- Question about SS Clutch line and Restrictor
- doing a drain and fill, ATF
- New clutch/flywheel...Resurfacing???
- Question about warped flywheel
- CV Boot Kit
- stock tranny
- stage 2 clutch
- Fidanza short shifter w/ twm, kartboy...REVIEW...
- Shifter linkage
- Loud noise
- Worst Problem EVER!
- Lookin for LSD for may tranny
- Transmission blew. Need new axle shaft
- CV bad AGAIN!
- location of input speed sensor
- Tranny problem
- Fidanza Flywheel Installation
- 3rd gear grind story
- Wheel bearing part number
- Flywheel resurfacing
- 03 OZ Rally Clutch...Performance?
- speed sensor issue after 5spd swap
- Shift Problem(I want your expert inputs! :D)
- temp sensor
- Lost Nut
- bad driving on 3rd gear?
- 2002 lancer tran problem
- help tranny
- tranny swap
- Would an 05 Lancer tranny fit in an 02??
- Trouble Getting into 1st and 2nd when cold...stalling
- PO715-odbc code problem
- Soft clutch
- Transmission F-ed Up
- Lubricant for Shifter and Linkage Bushings
- Need clutch soon...what one?
- which fluid to mask tranny chatter?
- CV Shaft
- automatic lancer es 3 to 4 gear problem
- loss of 4th gear. 02 LS auto trans
- 2002 Oz rally PLEASE HELP
- Rear wheel hub assembly torque
- Shifter assembly question
- new clutch
- which lsd you have
- car not running right?
- Clutch too soft.... sometimes wont engage..
- skid plate
- Still No Parts list for AT to MT swap?
- Authority Short Shifter Installed!!!
- Clutch Question?
- Transmission Done!
- Manual Transmission Removal
- 6 Speed Lancer?
- gear slipping?
- Test pipe question
- turning off on park...
- which reline is best for A/F
- Drain Plugs
- 02-03 Manual Transmission Limits?
- cedia 4g93t gearbox conversion
- Got cel Please help with any ideas
- Rattle noise?
- Bad Clutch?
- trying to replace transmission filter in my 03 lancer ES
- 03 lancer road race clutch line
- lancer es speed sensor issue
- Redline or Royal Purple?
- clutch line
- short shifter quick question
- A/T Cooler w/ Fan
- how much power can the auto trannies handle??
- Clutch replacement prices???
- which clutch kit to get?
- 5th gear problems....
- If I do a tranny swap, should or could I change motors?
- tranny swap?
- quick question.......
- Engine Noise Level
- car not going into gear
- AT to MT swap - possible?
- Help me please!!!!!!
- TWM short shifter install question/help w/pics!
- Rack in Pinion
- Clutch Q
- problems with conversions??
- How do I know if my clutch is dying?
- Evo tranny guts into 02 oz rally?
- 02-03 Lancer ES Transmission Part Number
- lancer es transmission swap
- (Auto) What Type of ATF and Filter??
- Reverse gear sometimes doesnt engage.
- ra gear swap into oz
- 3rd gear... please help
- my weekend in pictures :)
- where is the reverse light switch???
- More TOB questions.
- clutch bleeding????
- SPEC stage1 clutch for 2003 lancer oz
- 03' OZ rally Clutch
- auto to manuel conversion
- help with tranny swap
- cusco lsd
- street/strip clutch and flywheel?
- (Auto) Tranny Flush vs. Drain & Refill
- Fidanza Flywheel
- 02-03 gear ratios, once and for all.
- Manual Tranny Rebuild
- Shift knobs for 02+ Lancer???
- Gear Ratio's for a 02 and 03 Lancer OZ?
- Whats a good clutch?
- Transmission help???
- My manual trans is dieing young! help?
- Unorthodox Clutch & Flywheel
- clutch installation
- 02-03 Manual Transmission Fluid
- another tob/slave question
- Shift Kit for Auto
- stupid stock dipstick
- Shifters
- yes another tranny swap....
- hows the tranny swap?
- ROAD/RACE Race Series Aluminum Flywheel-4G94
- my conversion is on its way
- Auto tranny & POWER!
- Car move when in gear, engine off
- oil cooler
- clutch breakage
- Tranny Swap?
- slave cylinder / throwout bearing
- Tranny flush and drive belts?
- problem with flywheel
- Ordered Buscher Shifter Linkage
- works evo clutch issues
- Pop out of 1st?
- Kartboy Bushings
- Flywheel
- Phantom Grip LSD
- Works product review
- act/clutchmasters install w/part numbers
- slipped on ice .. dont know what happen!
- short shifter
- how much HP
- kartboy ss on 01 eclipse?
- Crank Pulley Question
- Time for a new Clutch Assembly
- auto/manual final drive compatiable?
- take care of your tranny
- 1st gear popping out
- Short Shifter?
- Limits of the auto tranny....
- Clutch Reccomendation
- Clutch Kits
- where to buy act kit
- GL5 Rating on Synthetic Manual Tranny Fluid
- Throw out bearing new still ****ed up
- soon to be M/T
- Where can I get axles at?
- 02-03 Slave Cylinder
- 03 lancer rear wheel drive
- clutches and suches
- tranny
- flywheel confirmation
- Is the 02-03 and 04-06 clutch the same?
- A2 Auto tranny shift kit?
- Automatic Shift Kit???
- Car jerks betweens speeds of
- Short shifter not recommended?
- Helping Picking Clutch Kits & Flywheels...
- Royal Purple ATF Max.
- Which clutch is better?
- Tool to use for Manual tranny Drain/Filler plug
- Changing Tranny Fluid
- throwout bearing HELP!!!
- Shifter Bearings aka Bushings - $10 shipped.
- FI - Clutch Slippage - New To Forum
- Clutch Problems?
- Lancer Auto into 5spd
- reducing wheel hop?
- kartboy shifter base and linkage bushings installed
- What size is the bolt going through the motor mounts?
- is this the transmission drain plug? picture inside...
- Mind Of It's Own
- 4G69 tranny in a 4G94?
- B&M sport shifter
