View Full Version : Lancer Tranny/Drivetrain Tech
Pages : 1 2 [3]
  1. Transmission Kit!!!
  2. How much power can a Lancer tranny take?
  3. Differential question...
  4. Clutch issues.
  5. This was the best deal I have ever got!!!!!!
  6. n0ob <----- quick question
  7. Ebay short shifter
  8. Help out good old uncle marc
  9. Auto Tranny Information for the Lancer
  10. RRM Clutch install?
  11. Auto Lancer Owners Enter Here
  12. Evo 8 short shifter
  13. Auto Tranny "Slipping"
  14. Should I Get The B&M Short Shifter?
  15. RPW "short shifter"
  16. Helical Limited-slip Differential
  17. Ebay short shifter
  18. Wheel Hop!!!
  19. The difference between Evo shifter & Lancer shifter
  20. auto ****fting probs
  21. changing tranny fluid
  22. sequential shift for automatics
  23. How tough is the lancer tranny??
  24. Organic Clutches
  25. Oil Slosh/Burning
  26. problem with auto tranny!?
  27. Clutch
  28. Ebay short shifters
  29. Cluth a shifter question
  30. EVO drivetrain in an OZ?
  31. Problem please help?
  32. Invecs II Transmission swap
  33. do i NEED a pressure plate?
  34. B&M Short Shifter Part #'s
  35. How many people have perf. clutch and LSD- U.S. Lancer??
  36. Another fun part awaiting install
  37. Vibration in clutch pedal
  38. rrm clutch and pressure plate
  39. How much should the B&M shifter loosen up?
  40. towing ability
  41. does this sound like a auto tranny prob?
  42. Will The B&M shifter fit my 03 OZ
  43. FF convert to AWD. How?
  44. anyone know about level10 shiftronic
  45. Auto Torque Converter??
  46. funny question
  47. notchy 1-2 shift
  48. Cost for higher gear ration?
  49. Programming Your Automatic For Better Shifts
  50. Motor mount torque specs
  51. Automatic Shift Points
  52. Short shifter kit question
  53. rev limiter
  54. lightweight flywheel?
  55. wheel bearing and brake pads.. linked??
  56. OEM Clutch/Pressure plate capabilities
  57. ???Auto Slipping???
  58. Shift Kit
  59. Slow take-off
  60. Short shifter causing transmission problems
  61. awd not in this car yet.
  62. new rrm clutch bucking?
  63. clutch install in 02 lancer
  64. Automatic to Manual
  65. clutch restrictor Q
  66. Kazz LSD for US Lancer~!!!
  67. changing tranny???
  68. Phantom Grip v RRM
  69. Lancer - Weak Tranny?
  70. Phantom Grip LSD
  71. Slipping clutch
  72. cost of clutch installation?
  73. How do you adjust clutch pedal?
  74. b&m shifter
  75. flywheel?
  76. High performance torque converter
  77. skipping clutch or transmission?
  78. How much horsepower can stock transmission handle
  79. minimal response from 1st
  80. Automatic Transmission...weird sound
  81. Downshifting an auto?
  82. Paddle Shifting
  83. AT to MT Conversion??
  84. INVECS III Tranny
  85. clutch
  86. shift kits for autos
  87. Short Shifter Install
  88. EVO shifter in US lancer
  89. Energy Suspension Bushings?
  90. Lightened Flywheel???
  91. which tranny fluid to use?
  92. B7M ShortShifter for $109?
  93. Gear ratio?
  94. clutch
  95. Confirmation from Clutch Masters
  96. Aftermarket Clutch Upgrade
  97. grinding in 5th
  98. Is my gearbox destined to get fuct?
  99. Road///race Front Lsd
  100. clutches help me!!!
  101. flwheel
  102. auto draging lancer oz
  103. Wanna change the transmission?????
  104. Tranny fluid
  105. 5 speed overdrive
  106. Automatic question?
  107. 3rd gear pull?
  108. B and M shifter?
  109. i was wondering about the 4wd?
  110. first to post hehe (actual content inside)
