View Full Version : Lancer Tranny/Drivetrain Tech
Pages : 1 [2] 3
  1. why my gears wount go in
  2. throwout bearings?
  3. Accolade - Short Shifter Kit
  4. Downshifting in and Auto....?
  5. Things need for a clutch Kit
  6. Damn oppossums and trannys
  7. 3rd Gear Rough Shifting
  8. Help on replacing my Auto tranny
  9. noise in idle...
  10. Auto Shifting Question
  11. 03 lancer es clutch
  12. RRM Stage 2 Clutch / Flywheel / Crank Pulley Review.
  13. Auto 2 Stick
  14. Mitsu Denied Warranty Claim Help !!!
  15. Zoom Clutches
  16. Did I fry my clutch?
  17. short throw shifter
  18. Short throw
  19. flywheel install question (2003 Lancer OZ)
  20. Slave Cylinder Question
  21. transmission mounts
  22. Turn any automatic into teptronic??
  23. 2 days left and counting......
  24. clutch install?
  25. Need tranny shop info....please...
  26. who has a kaaz lsd
  27. Front sway bar???
  28. fidanza installation
  29. kaaz lsd speedo gear
  30. Car stalled on highway - HELP
  31. AWD Lancer?
  32. Flywheel/Headers
  33. Turbo or Clutch/Flywheel etc. Part 1
  34. 03 lancer es auto to manual
  35. Stage 2 clutch issue
  36. stock clamping force number?
  37. Auto tranny problem? Car moves in P.
  38. turbo plus auto tranny=bad
  39. Anyone install clutch themself???
  40. My clutch experience with CNFX
  41. Why is the clutch so expensive
  42. Clutch is dying....
  43. Worksevo or RRM Clutch?
  44. quick shift
  45. Auto Transmission Cooler
  46. short shifter installed, have question
  47. jumps
  48. tranny overworking
  49. KartBoy Bushes
  50. clutch changing question??
  51. Tranny cooler set up?
  52. fidanza short shifter
  53. Need some tranny info for check up
  54. Weird Noises, Please give feedback:
  55. Works Stage 1 Clutch Review
  56. issues with aftermarket oils
  57. Manumatic, Sporttronic, etc...
  58. Question from Singapore
  59. Opinions on SPEC Clutchs?
  60. FWD Transmission Removal
  61. AUTO Tranny problem?
  62. Front motormount specificity Question
  63. Metal or Poly Bushings??
  64. tranny....NEED HELP ASAP!
  65. 2nd trans problem in 2 months!!!
  66. tranny prob with turbo
  67. help with clutch
  68. NTB: Clutch for 2003 OZ
  69. Shifter thread...
  70. Manual Trans Gear Ratio?
  71. knocking noise coming from motor when clutch is released
  72. Cheap Stage 2 Clutch
  73. weird problem never herd of
  74. auto tran to manual
  75. Cluch slipping
  76. Do I need a new clutch?
  77. rev limiter
  78. Blew My Stage II Clutch Set-Up!!!
  79. electrical engineering question
  80. LancerShop Authority short shifter installed
  81. Evo engine,tranny swap
  82. Best Oil For OZ?
  83. axle removal?
  84. Blend of Redline...
  85. auto to manual
  86. 7K Rev Limit ECU questions
  87. 2nd gear
  88. Torque Converter Shop Found In California
  89. Flywheel Bolts???????
  90. stage 2 a auto?
  91. Throw Out bearings
  92. Car accident, need advice
  93. Clink/Clunk from driver side..
  94. ~STAGE 2 cluch/ turn down stock flywheel?~
  95. Can you reset the automatic's computer for shifting gears?
  96. MT Neutral Position Switch?
  97. Stock Clutch Vs Stg 1 Clutch Vs Stg 2 Clutch...which???
  98. Transmission service advice
  99. anyone had a leaking slave cylinder???
  100. where i can buy Pressure Plate
  101. EBAY underhood shifter bushings
  102. Clutch Pedal Adjustment?
  103. possible 6 speed
  104. Just installed stainless clutch line
  105. Street Customs short shifter is solid
  106. Tranny Swap Mystery
  107. Works stage 2 clutch....overkill?
  108. leaking gear oil
  109. ACT clutch for lancers?
  110. Auto Transmission Problems (Warranty Issues)
  111. Tranny swapping???
  112. BG synchroshift
  113. Clutch fluid
  114. A little surprise from Kartboy
  115. Anyone having probs w/ stage 2 clutch?
  116. Flywheel.... interesting
  117. Have a Leaking/blown Slave Cylinder
  118. 5spd to 6spd Conversion
  119. to sell or not to sell
  120. How well will the transmission hold?
  121. Auto Tranny Question
  122. shift retainers..
  123. Weird gurgling sounds when I depress the clutch.
  124. flywheel help
  125. Foam on the intake scoop?
  126. Shiftronic
  127. aut transmission getting stuck
  128. How fast should I slow down without downshifting?
  129. Can You Really Change An Automatic To A Manual?
  130. Great price on Fidanza Flywheel
  131. Transmission Fluid
  132. help! about my tranny
  133. Automatic Transmission Cooler
  134. Motor mount is on (front at least)
  135. Transmission with turbo???
  136. EBAY Short Shifters!
  137. tob question
  138. t.o.b. question
  139. Clutch noise or tranny!
  140. really stiff clutch, sub freezing temp
  141. downpipe???
  142. 1st to 2nd grind
  143. Turbo Kits for OZs
  144. Energy Suspension bushing
  145. My shifting is getting rough.... any ideas?
  146. flywheel for auto's?
  147. prep for tranny swap!!!
  148. Manual Tranny Upgrade?
  149. Stage 2 Clutch, Flywheel and Motormounts Review
  150. Clutch & flywheel review?
  151. Anybody see this short shifter for the Lancer
  152. How do i bleed the clutch for a lancer
  153. fidanza flywheel......centerforce clutch
  154. clutchmasters flywheel
  155. Info about this clutch kit PLZ
  156. engine noise?
  157. Need Some help....
  158. act clutch
  159. Automatic Tranny Fluid Change
  160. Right Hand Drive Conversion?
  161. ok....just wondering.
  162. Clutch stiffness
  163. Help from anyone with an RRM Stage II Clutch
  164. RRM Flywheel
  165. Clutch Question
  166. Broken Oz Rally trans and clutch!!!
  167. Gear oil dilemma!
  168. crank on tranny
  169. Clutch And Transfer Case Going Out..
  170. Third Motor Mount???
  171. drive axle
  172. Got My New Mounts In!!!! (In RED)
  173. Replacing the OZ Rally clutch
  174. RRM's new clutch options
  175. I'm gona go nutz
  176. Tranny question
  177. Automatic Transmission Upgrade
  178. Just installed short shifter
  179. Rumor and Q about tranny fluid
  180. ?'s for Anyone w/Deyeme motor mounts....
  181. Amazing Short Shifters
  182. AWD or RWD conversion?
  183. would you re-gear your tranny?
  184. Wheel bearing nut size
  185. Is the US Lancer tranny the worst?
  186. Clutch!!!
  187. Flywheel/Torque Converter
  188. Automatic Tranny Help
  189. factory short shifter
  190. Cluth Master Cylinder and Slave Cylinder bad??!
  191. RoadRace Flywheel
  192. 5 spd 2 6 spd
  193. Anyone install their own LSD?
  194. Changin the fluid for AT
  195. tranny dipstick is stuck
  196. AMS Clutch Install
  197. Need motor mounts
  198. question re: AT filter change
  199. Best shifter busings?
  200. Changing the clutch
  201. Attn Turbo Guys..Clutch Question..
  202. Kartboy shifter linkage bushings install
  203. Stainless braided clutch hoses???
  204. Automatic Transmission upgrades?
  205. exhaust??
  206. Will tranny hold up
  207. Limited-Slip for an Automatic?
  208. automatic to manual tranny swap
  209. Burnt My Clutch out!
  210. Clutch line compatability
  211. Installed B&M Short Shifter
  212. reinstalling tranny
  213. Gear Ratios...Possible?
  214. Where can i find shifter bushings for my lancer?
  215. What have they done to my car?
  216. Button to toggle between normal and the piggyback mode for the ECU
  217. mobil ATF+3 TRANSMISSION FLUID
  218. Maybe Tranny issues?
  219. Purchased a short shifter...
  220. transmission fluid
  221. short shifter ???
  222. Triple Disc Clutch?
  223. Having problems with warranty on tranny
  224. Question bout the gear
  225. tranny noise
  226. noise from under car???????
  227. Gear ratio's
  228. Downshifting
  229. Manny tranny prob.
  230. Problem Will Not Go Away... Please Help
  231. Tranny work?
  232. transmission strength
  233. rough accel in 2nd
  234. Loud Ticking....Just Noticed today
  235. transmission cooler
  236. fidanza flywheel
  237. auto tranny upgrades, who's selling it?
  238. price on short shift kit
  239. HELP with tranny
  240. Quarter Stick...
  241. Is Resistance when Shifting into First Normal?
  242. looking for ES bushings...
  243. found this on ptuning.
  244. Short Shifter: Was I sent the wrong item or is this not the correct shifter?
  245. Manual tranny fluid
  246. What kind of lube comes with the B&M short shifter?
  247. Energry Suspension
  248. RRM ECU Flash and auto shift points
  249. short shifter
  250. NEED HELP, BROKE MY AXLE!!! Mechanics please help...
