- Oil Leak
- ML2501: Turbo Specialties Superior Turbo Kits ... any experience?
- Turbo help
- TT install
- First Dyno Run....*help*
- Intercooler Question
- Race gas is awesome
- Whtas up with rrms 04 turbo kit
- Average MAF reading for RRM's intercooled kit?
- Need help with TSI kit
- intercooler piping ?
- RRM Stage 2 Questions...
- Boost Gauge install!
- Weak points after rings pistons and rods?
- mhi t25
- heres my list for 300+WHP
- help which turbo is this
- Completed Stage 2 Install!!!!
- How much Boost?
- rally edition going turbo
- Piggyback Ver.2 With Zex
- Speed of air
- Rob P's Custom Turbo Questions
- RRM Stage 2 Automatic Result
- Alky Injection For RRM/Custom Turbos?
- 04 Turbo Question
- kamikaze header
- manual boost controllers...
- Turbo Timer - if ur knowlegable pls read me!!
- GT25/GT28 Ball bearing Turbo!!!!
- Sequential Turbo or Turbo+Supercharger... are they possible?
- ~Hole in back of turbo...~
- Somewhat disappointing dyno
- Turbo Mirage
- ~Tapping the oil pan....~
- Can anyone tell me why EGT is getting hot? and a few other Q's
- T3 turbo on a lancer!
- Stock fuel line removal Q's
- Quick Question bout Greddy Turbo Timer
- Anyone figure out the 04 issue
- 04 Lancer headers for turbo
- Would this work?
- theory question...
- Simple Tuning
- Torque Converter News!!!!!
- Aeromotive FPR
- my set up
- Almost finished with turbo'ing a Lancer 4G94
- Boost numbers?
- Internal Wastegate Actuator Q's
- Possible Turbo Headers?
- New Fuel Pump for new Boost?
- Supercharge or get a ralliart?
- New F/I forum rule! READ ME!
- tried search can't find, fuel psi per, psi boost
- Boost Spike, but how?
- Turbo Questions (BOV, Vac, Piggyback,etc)
- inspection and turbo
- ECU wiring diagram
- FIANLLY!!! jesus...
- stage 2 problems
- New Old School
- Turbo Kit For $1470.00 Shipped?
- ~RRM STAGE 1 kit, STAGE 2 Clutch?....~
- stock injectors and boost?
- My Ripp Sds: 194whp/167tq
- Help Boost w/ gauge install on 04 o-z
- turbo, supercharger omg help me ; ;
- any of the turbo guys....
- Exhaust leak Preturbo.
- Converting injectors.....
- Ripp Stage 2 Manual 230whp
- Stage 2 finally
- About Time
- Piggy Back Help
- stage 2 a auto?!?
- stock injectors during boost STILL rich?!? guru's help
- Need Help
- Gas Mileage???
- How much can it handle?
- Removing Injectos 101
- Building Your Own Turbo Kit. Noobs please click!
- Installing Custom turbo *updating as i go so i dont miss anything*
- Rrm Piggyback Ecu On A Toggle Switch
- Supercharger Q
- How-To: Set up your Lancer for turbo install
- SC or TC? Need some real advice
- Mitsubishi TEO4H Turbo to fit OZ rally?
- What Turbo are you running?
- Custom Turbo Setup
- 2003 Lancer Es Custom Turbo Kit
- Vortech FMU and you...
- 04 turbo fmu ?
- tsi setup pros and cons
- avc-r
- RPW Turbo Pricing
- TSI kit still tickin strong
- Another exhaust question
- Help with street tuning my car
- Just installed non-ic rrm turbo!
- Anyone with a wideband (LA)
- Educate me on Vapor Lock
- SC questions
- Brainstorming: Fuel cut
- Project: Auto RIPP SDS
- Cold Air Intake .....Need Help Asap!!
- HELP! - Running Super Leeeeean
- Priming the Oil Feed Line? (turbo)
- will these plugs work?
- 2004 Turbo
- What Size Injectors?
- Greddy Type-S with RRM nonIC Turbo?
- just rode in ripp auto stage2
- preparing for turbo???
- it's better to be NA than have boost leaks
- got question about ECM Recalibration Kit
- SDS..not one of those questions
- Open to all turbo Lancers....
- PSI vs CFM
- Evo Turbo on Lancer
- RRM Non-intercooled 1/4 mile times
- Have Question on SDs
- Custom 16G6 Turbo Project
- HELP: P0139 Slow Response O2 Sensor Code
- T3/T4 Turbo is it too powerful???
- Oil return...can it be done through drain hole?
- Turbo Install; NonIC - Grinding?
- 2g eclipse internals
- RRM turbo kit
- Issue With FI
- Stock Evo 8 turbo kit?
- Road-Race 20g Turbo
- Want to hear sound byte of RRM turbo!
- Non I/C Kit in the Arizona Heat??
- Apexi A/F unit or Greddy E-manage?
- Boost controller?
- My RRM intercooled turbo passed the emissions
- Help from the mighty lancer peeps
- Places to order a turbo kit for a ES 05 Lancer
- Finally Turbo! Have Questions????
- installing my custom turbo & have some Q's
- Single spring mod on Type S and Valve is open
- Another RRM turbo enthusiast...here's my opinion
- dumbest question ever but i gotsta know if its possible..forgive me!
- piping setup
- Go or no go with turBO?
- ways to chill intercooler?
- Apex SAFC II and Bog at idle
- super charger?
- RRM Turbo!
- how much?
- How much horsepower will...
- Turbo questions
- Greddy Type RS
- If your not stage 2, your probabaly getting passed
- Bog under hard acceleration. Why?
- Help W/ Greddy Profec E-01 Boost cont.
- Help Manfold
- RRM Intercooled Turbo Installed
- Turbo inlet hose w/ Recirculation port
- Tunning with E-manage and new injectors.
- Hotshot940s Spring Mods...
- Help Stage 2 Guys, part needed
- cast iron manifolds
- How does this supercharger look to you guys?
- RRM turbo install
- RRM turbo and a car show
- Help Installing Stage 2!!
- SRI ?'s
- Someone help me with this please
- Exhaust
- Answers to turbo questions
- Need power
- Supercharger Fuel Requirements
- Stage 2 Turbo Cams
- quick question
- Any specific tools needed?
- NOOB Turbo?
- Can someone please give me instructions on how to install Short Ram Intake?
- Where do i hook the Oil & water lines?
- Prospective Turbo Buyer Questions
- My TSI Turbo Kit
- Stage 2 turbo Install!
- turbo water cooling
- ebay RRM turbo
- I Need some help with RRM turbo jnstall.
- Anyone want 2 do a custom turbo set up...
- RRM non intercool installed!!
- BOV vacuum line
- need injectors...
- Perrin O2 simulator
- 04 custom SuperCharger
- MAS sensor for the RRM Stage2?
- Greddy eManage...
- RRM TURBO Oil 10/30 or 20/50???
- Complete Makeover of My Custom Turbo Kit
- I Have The Intercooled Turbo With Safc2!! Help
- Passed Ohio E-Check Today
- Hotshot940s Boost Clips
- evo's turbo question
- I Need A Fuel Rail, Like Pronto!!!!!!!!
- anyone ever order the turbo kit from turbo-kits.com?
- upgrading RRM Non IC to IC! HELP
- RPW stage 1 cam + forced induction
- Piece my own turbo?
- Nextgenerationx features
- RRM Stage 2 Updates?
- RRM BOV Options
- need some help w/ fuel issues RRM Turbo
- noob question :)
- Dynod AUTO Lancer RIPP SDS KIT!!!
- New Rippmods Product
- Lancer turbo!!
- Who wants a standalone EMS for their car?
- 04 supercharger fuel system help
- Buying an RRM intercolled turbo kit....
- Installing a RRM intercooled turbo kit....
- ?????? About Turbo Manifold.
- Need Help with fuel system!!!
- I need help with fuel injectors
- TSI Non-IC Kit
- A little more go?
- found new turbo kit?
- Look what i got away with
- Vacuum issue
- Passed emissions
- question about stock internals
- Testing RC injectors
- How to spend 6,000 on my 04 lancer Es
- I Have The Money
- Nice sounding Carbon Fiber Exhaust?
- Got a ? about this turbo kit!
- Valves
- Update on McBrown35's Stage 2
- Hallman Boost Controler
- Vacuum Control Valve
- possibly blew a piston
- ROAD/RACE TURBO Mirage-Take a peek
- 2.5 custom downpipe *56K BEWARE*
- Vac Lines W/Out MBC
- Quarter Mile for Automatic Turbos?
- www.cheapturbolines.com
- Stage 2 MAS Mod?
- Stumbling and spiking
- Any advantage of running pressure line to wastegate off of intake manifold?
- question with turbo
- Blow'd it
- Slim fan question
- EVO exhuast gaskets fit?
- turbo question
