- Need Advise on Fans
- What do i need to turbo a lancer ???
- New engine wont start!!
- Exhaust Manifold studs
- g93head/g94 block swap ?'s
- Aftermarket Headers With Stock Down pipe
- Fuel FIlter Chaning OZ rally 2002
- 2003 Lancer OZ engine swap
- quick question
- Cars at 150k kms, dealership recommends timing belt replacement..
- RRM Crank Pulley Question
- 4g94 build
- turbo headers/manifold
- EVO Heat shield on a 4G94
- Injector problem
- Intake for an '03 ES???
- Downpipe?? Please Help
- Headers and dp with stock muffler?!
- 4g63 intake manifold? Onto 4g94
- knock sensor
- Amsoil Oil Analysis
- EGR problem?
- The lution By 3rd KREW Performance
- Tune up needed!
- Lancer OZ rally Aftermarket parts.
- idle issue
- Head bolts
- Simple timing belt question
- What engine is this?
- DarkMitsu's 4g64 Swap Page
- Idles Low
- 4G94 Engine Build!
- crazy tick/ rattle
- 4g94 vacuum configuration
- ENGINE SCRECHING SOUND when Rev'd
- Evo 8 oem exhuast
- 4g93 intake vs 4g94 intake RESULTS
- Just bought 05 ES some questions...
- Good investment?
- JDM Mitsubishi GTO 6G72 Engine '90-'95
- Looking for a new engine
- swapped to an eclipse 501 MAF
- Oil on sparkplug threads - valve cover gasket?
- Kool Vue Cold Air Intake???
- power steering pump failing?
- i need your parts/advice
- Where Can I Get an OEM Air Box for my 02 Lancer??? *PICS*
- Greedy ti-c exhaust
- Help...can't decide!
- uh-oh....need rad help
- need help with timing belt
- Exhaust question...
- Dent + Oil Pan = Bad Lubrication ???
- Evo swap into 02 lancer?
- 4g69 in 03-03 oz lancer how to?
- Spark Plugs and Wires
- ECU compatibility through the years
- 4G94 Block, Who Makes It??
- Mirage cam
- lightweight front cross member fitment question
- Turbo VS Two particals nitrogen, One oxygen
- Aftermarket Mufflers
- Head 4G18 - 4G15
- Weight loss
- Question about how to make gaskets
- I need help
- Difference between M/T and A/T Exhaust
- Billet 70mm Throttle Bodies for those interested
- Question about honing
- Bad Valve Guides
- Engine knockong ?
- rrm header help
- ebay catback
- Fuel
- Head bolt torque specs and pattern
- Quick 4g93 question about head bolts.
- Power under $1.000?
- Valve Gasket Leak, Will This Work?
- hydrolocked motor going threw new options.
- Engine electrical problem, Need Help...
- used cylinder head
- swap for a 4g94
- 4g93 crank pulley
- Still running rough
- Radiator Question
- Greddy Emanage Ultimate
- 03 OZ Cold air Intake Water Problem.
- My 4G94 Mivec build up
- APEXI SAFC 2 Harness Compatability Question
- 2g eclipse intake mani?
- new headers, and now stalls
- Stock injector and fuel pump flow rates...
- Help! 03 Lancer ES ((Bad Sensor))
- strange box in my dash
- 4g93t whant buy....
- idoling prob
- Clutch kits
- 1/4 mile time attack!
- 4g64 question....
- Another Misfire problem, can anyone help?
- idle problem, please help
- 4g94 gasket specs
- Misfire help needed
- sillicone radiator hose kit
- Gates racing products?
- cat question...
- help finding sway bar 03 lancer oz
- Engine rebuild kits?
- Stalls...
- 4G94 Forged rods
- exhaust question... anyone?
- need some help!
- 6A1X / 6G7X Engine Swaps
- Magnaflow Exhaust
- Removing oil pan
- Increase HP for a '09 Lancer GTS?
- Evo Swap ?
- Help and Advice
- Cai?
- wiring harness diagram.
- 4963 swap
- Possible Engine Swap??
- Timing belt tensioner
- Need help finding the right exhaust
- Best Mishimoto Radiator Kit option
- Problems finding new valves
- 4g94 dohc-gdi
- 1G TB Does it work
- 4G93T swap
- EVO Engine swap
- Low End Torgue
- Question on fans
- intake manifold upgrade?
- please help.. turbo/IC 03oz
- Performance Upgrades?
- Will it fit?
- Cams.
- Lancer es 04 exhaust
- Question About Exhausts?
- cheapest place to purchase a greddy ti-c
- Motor Mount bolt size
- Upgrade? or sell for evo?
- need opinions please
- Cylinder Misfire Help
- Crank Pulley Noise
- new intake,wierd idle
- quick question RRM headers
- need some idle/rpm help
- got a good laugh out of myself
- 4g94 is it interference or not...
- installing BOV/WG/& psi gauge
- 02 Oz Spark plugs
- RMR Intake on an ES
- 4g63??
- engine miss/service engine light
- Aeromotive FPR fittings
- Installing New Intake-> Trouble with screws
- What kind of intake?
- Compression test
- Muffler Question
- Stock Air Intake on 06 es question
- audible difference between crankwalk and pulley damper wear?
- 2003 lancer es
- Engine Swap
- 02 OZ engine swap
- 03 OZ Rally: Doing timing belt anything I should know?
- boost stock internals
- Authorized Modifications
- question about top end and bottum end
- P&P head and intake
- Need help, in middle of install.. Wideband LC-1
- 2003 Lancer Es want an engine swap
- Wiseco Pistons...?
- Timing belt replacement time after 100k?
- Is their an oil filter that lasts 10-15k miles?
- half size radiator.. what is needed to make it work...
- anyone on the RPW stage 2 cam
- Recommend spark plug wires?
- ok, injectors question..
- 80,000 miles... What should I do for maintainence?
- 4g94 DOHC?
- Dynomax Super Converter (CAT) any good?
- large oil leak
- pauter rods
- How many cats?
- Do i need a tune with high comp pistons?
- Need an OIL PAN..
- not sure if im posting in the correct section...
- engine build
- Coil Pack Recommendations
- Dun Dun Dun... Cracked Header :(
- oil light flashing at idle?
- What CAT do you recommend
- What dohc head for 4g64?
- Is it ok frun the walbro 255 N/A?
- What would be the best brand of headers to purchase?????
- What you all need to know about motor oil in our Lancers.... PLEASE READ
- RPW Camshaft w/ 4G93 Valve Springs
- quick question
- 4G69 swap, opinions
- Do I need to chage t-belt now???
- RRM Lightweight Pulley
- Flooded Engine
- Cat Question
- do evo catbacks work with oz?
- exhaust gasket
- Vacuum hose to intake?
- gas mileage high than low than high
- brake problems
- swap?
- o2 sensor
- Dimensions for a custom test pipe
- Where do you buy your parts online?
- Air Diversion Panel Question
- Need some quick help please
- CEL code P0421
- Bad Slave Cylinder ***n again!!!
- a quick question - header
- greddy help
- mod help
- Setting tdc with aftermarket camshaft...
- bad compression? bad piston rings? help
- Sound Problem with mods
- volo ecu
- 2003 auto coldair intake
- Dynolicious
- From World engine to Hybrids and evo swaps
- the right turbo
- Rrm Piggy!!!!
- Kill Switch
- Shop manual for 04 OZ Rally
- will these injector work?
- Oil Pan gasket torque
- Check Engine Line - On because of Cat? Need to fix....Emissions due.
- Universal Code Reader???????
- Please Help/ Motor Mounts!!!!!
- Crankshaft Pulley
- RRM Piggyback and Header
- Hey guys I have a Quick Q.
- RPM and MPH Help
- 4g94 mivec??
- CEL on
- is it possible
- CAI whistle after exhaust install???
- Does this work?
- Help Needed!! Engine Misfire
- Apexi Neo
- piggy problem
- Is the price worth the outcome?
- Timing belt issues/question
