- when to go to higher octane
- Radiator
- e-manage help
- fuel pressure
- kamikazee with rrm turbo?
- Autometer tach #3911 install help!!!!
- Intake Manifold measurements
- which parts r legal?
- Super Hot Engine bay...what to do?
- Mil Eliminator
- SRI's
- clear this up
- Someone Must Know!!!Ecu Help
- NO MAF sensor?
- whats the purpose of.....
- US lancer Canadian lancer differences?
- NA reflash lancer??
- Headers with turbo
- Kamikaze Vs. RRM
- rrm magnaflow catback?
- ECU Part Numbers HELP
- Confused
- A853 srt-4 swap???
- rmr intake size?
- headers; kamikaze or rrm
- RRM muffler tip owners?
- Denso Iridium spark plugs (stock v. new)
- Home made CAI
- Lancer Stock Fuel Pressure
- Cryo2??
- installing rrm header...
- Short Ram Intake Question
- exhaust?????
- 30,000 miles and dropping oil!...again.
- cheap ground wire kit on ebay
- axle-back exhaust from mufflertech.com
- double cat idea
- 6A12 Engine Swap
- Pics of SRI install, want mounting info
- Header question
- Hp
- cams
- Carb Cert Parts
- Piston/Rod Combo
- DC Sports Exhaust
- RRM header
- New Engines....
- Switching Oil Types?
- What Oil Filter?
- What CAI or SRI do you have?
- CAI or SRI
- Oil and water temps and oil pressure #'s
- engine swap
- Amazing Engine Tech.. and it's real CHECK IT OUT!
- Yet another plug wire question
- U.S Lancer MAS honeycomb
- Why do ECU reflash's cost so much?
- RPW Internals
- should iget a "s-afc"
- aem vs. injen
- K&N Typhoon Intake w/ Pictures
- New exhaust ! twin canister
- Sequential Shift Light Question?
- High Compression Pistons
- MSD ignition?
- oil chart?
- I Did It!!!
- Headers
- what is it?
- The wait....
- Rrm Ecu
- to squeeze or not to???
- New Product Coming to a Lancer near you.......
- throttle body
- Homegrown SRI ver 2.1
- HEADERS; so i really need one?
- Check out new WeponR intake
- Stealth Test pipe!?!?!?!
- engine packages
- N/A Engines
- Short ram intake
- K&N Typhoon Intake???
- Intake Info???
- exhaust
- Aem Cold Air Intake
- Install a Fuel Management Unit (FMU)
- 4g64 engine w/o turbo..
- pistons swap
- cheap mods
- ultimate racing exhaust
- Injen CAI installed, now Pop?
- Weather Problems
- exhuast question
- Whistle/Hiss when Accelerate?
- Genuine Mitsu Oil Filter
- Injen Cai Install
- Aem Cai
- Holy Cooling Fan!
- Radiator Cap
- Homemade short ram intake
- Dohc Oz
- Questions
- fuel management issue
- Ordered a Buschur Exhaust
- Leak in RRM Header. Anyone else?
- Good aftermarket companies for my Lancer Evo 8? (and a few parts questions)
- XoXo intake
- CAI -vs- Ram Air
- Flames
- SO Breathers? and the US lancer?
- The real story of Weapon R
- Catback: Done
- Header Question
- Anybody with a automatic Lancer running a RPW cam?
- Problems with AEM CAI
- bumper melting!
- intake crisis
- DC Sports Catback Exhaust
- 4G63 Head
- about injectors..
- changing engine block
- Intercooler
- Will SAFC work?
- You want a SRI?
- Another stupid ebay question
- HOW TO: Install an Apex`i S-AFC
- cheap mod
- Specs for Desktop Dyno 2000
- NGK Iridium Plugs
- Another S-AFC thread
- Finnaly installed my K&N
- i want rice
- magna flow sys. Vs. Greddy catback
- Horsepower gains
- Synthetic Oil = BAD
- Cel stopper
- type of spark plug for oz
- Injen filter size
- How many days do u give me before blowing up my engine
- Adjustable cam gear
- Need Help
- Exhaust
- APEXI S-AFC help!!
- Swapping a 4G94 HEAD OUT WITH A 4G63 DOHC
- Already Searched: need real info on 4G63 swap
- electric cutout
- Greddy Exhaust mounting
- Battery Crank Amps
- BaCKpResSure
- G-tech Meter times!
- sohc 16v... where do you get one of those cams?
- Funny sound from AEM CAI. Need help please.
- Nos
- CAI for auto
- Engine calcs
- Headers!! RPW or RRM
- Nitrous Question
- s-afc on US Lancer
- Help With AEM Water By-Pass Valve
- Install An Intake [DIY]
- HOW TO: 2G Eclipse GSX Fuel Pump Swap
- greddy e-manage with 1.8 mirage
- Bumper to Bumper inspection
- Consequences of running too much boost
- CAI cleaning
- rrm clutch and pressure plate on the way
- Upgraded to Turbo
- Thermostat
- Just installed my intake, with problems of course...
- question about auto lancers...
- exhaust
- exhust...taking off...
- General info on Deyeme engine mounts
- Anybody Dyno Tested?
- Chip question
- Flywheel
- Cherry Bomb
- Cheap engine swap for you guys.
- Does anybody know??
- exhaust
- CAI: Need help
- turbocharging
- Performance Chip:
- wut is this thing?
- Plug wires installation
- Throttle body
- RPW Camshafts
- Ignition coil
- OZ Fuel Filter
- JET v-force
- Custom Ram Air
- question: headers and piping
- Best Exhaust
- new engine
- oil brand
- synthetic motor oil!?
- Intake Manifold
- Is the valve cover aluminum?
- RPW throttle bodies
- Testpipe.com
- exhaust piping
- Ground Wires?
- sound clip and header review
- Turbo Manifold and Exhaust Parts almost finished
- 4G63 Eclipse Motor??
- Evo exhaust is 460 at rmr
- how unorthodox
- Obx headers
- home grown NOS???
- more eng. H/P
- For everyone with with an e-bay intake!
- EBAY $5.00 Resistor???
- first mod?
- Friend of mine needs some help
- Cruise control Info
- evo 8 motor swap
- Technical Stumper Question..HELP!!
- Ebay Air Intakes
- Mivec Engine For 02 Lancer
- Quick Question!!
- hiss sound??
- The better engine?
- ignition system question
- i installed by short ram intake but...
- Low dB High Flow Exhaust
- Best intake so far..
- Ignition Solutions Plasma Blaster
- RPW Cam shaft and Cam Gear ARRIVED!!
- Bomz intake
- K&N Typhoon Intake System (US Lancer)
- More Liters!
- Driver Adaptive technology?
- IAT Sensor...HELP!!!!!
- What's the first thing we should do?
- Re: ECU JetChip Upgrade...
- Turbo Your Lancer For Cheap
- Weekend Work..
- Dohc?
- GCA true flow intkake?
- Keeping air damn
- free magnaflow exhaust
- fastest US lancer?
- Exhaust opinion
- Top Speed?
- Homegrown SRI
- intake from japan
- Injectors And Fuel Pump
- Warranty Questions
- Idle Problem
