- dont heart to ask.
- question on us lancer stock header
- Oil/fuel Sensor Placement
- Engine Swap?
- timing belt
- can these be changed?
- intake mani or throttle body?"
- what happens to Mass Air Flow Sensor(i think?) after a cold air intake installation?
- rrm header qs
- intake question :P
- RRM Header + Buschur downpipe?
- 04 Lancer FPR
- More tech questions I hope to be answered
- who is the faSTEST?
- what is the torque power band on an 03 OZ?!
- do the digital odometers on 02/03 lancer o.z reset to..
- quick question: will the guages cluster from a 02 work on the 03 lancer?
- Finding Rod Bearings.
- how to install aftermarket tach?
- mil eliminator install Q's
- RRM piggyback MPG
- Question about C.E.L
- Custom Machined Parts
- Help with Exhaust
- Need Help with AEM Cold Air Install
- do my plugs looks ok?
- parts
- Does Anyone know if there is an online Chiltons?
- help with my FPR
- What are the exhaust manifold torque lbs?
- Wires to tap for the 02 Simulator?
- got a question about fuel pressure adapter!!
- 02 sensors help
- Lancer Racing Electrical Cpu Module 5+ Hp????
- 2000 2.4L Eclipse Engine???
- Engine Bay Picture Help...
- Lancer 1.8 SOHC owners
- grinding question
- Radiator Fluid
- Need some opinions....
- Which Header???
- Header Q's
- What muffler should I get?
- 02 sensor wires questions
- mil eliminator help
- Intake Question
- exhaust piping question
- Pulley question
- Spark plug write up?
- Why the MAF??
- Mivec Head Swap
- Z1 Performance Chip
- need cam info
- Cooling Fans
- Lancer engine belts
- System pressure questions (Intake and exhaust)
- ebay intake
- rrm or rmr sri
- RRM Piggyback problems?
- Loss of Power
- How can i increase the gas millage of my 03 lancer es
- HEADERS question.. Help...
- how far can n/a go without fuel mods?
- feul rail
- RMR Intake: Noise Problem?
- PCV Valve Question
- 4G94 = Open or Closed Deck
- Evo Catback on ES
- ECU questions, if thread already exisits, please link
- BackPressure Qs?
- Idle Problem
- Rpw's turbo/supercharger cam shaft
- Low Temp Thermostats
- EMS?? Which one does what?
- Coolant Temp
- pully kit
- N/A questions
- piggy back/ headers
- Need Help Fast, Cam Issues
- How reliable are Lancers?
- Mirage 6A12 engine swap
- RRM Short RAM Install Concerns
- OIL Spurting out!
- Need cam help
- Porting and Polishing Heads
- AEM CAI Bypass
- Locate IAT sensor on 2002 Lancer
- 5w30 oil
- PiggyBacks HERE
- ? about quad throttle bodies(rpw intake mainfold)
- No money, what to do!
- Does s-afc work on NA cars?!
- Is turbo the way to go?
- Question to RRM
- question about testpipe
- Dumb downpipe question
- Best intake out there?
- Wiring Tach Meter
- Just Ordered KAMKIKAZE Headers Any Tips?
- Apexi AFc
- header question
- tech questions...
- CAI Auto Lancer
- Shopping list
- How much fuel is going into the engine?
- Best connections for ground kit
- Question on breather filters install
- New Mods
- RRM Piggy back
- GReddy exhaust gaskets???
- The NEW RRM Fly Wheel
- help with exhaust
- RRM Turbo and exhaust leak
- Wonder if this MIL Eliminator is any good???
- do i need a valve cover gasket?
- No-CEL header?
- RRM Throttle Body
- Final Thread on CAI water problem
- "V-Tec" prob with CAI - Quick Fix!!!
- Rpw..yes Or No
- no power if AC is on?
- reason for lack of hp
- 02 Lancer AEM EMS
- 1st gen apexi super afc
- Fuel line diameter
- HIGH PERFORMANCE SPARK PLUGS and Wires
- headers
- is switching the mivtec into the 03 lancer worth the time and problems
- RRM vs Jet
- Port and Polished head
- How many amps is stock alternator
- Turbo muffler on N/A car
- JIC vs. Greddy? Exhaust help
- Does anyone know if the K03 turbo would fit/work for the 03 lancers?
- someone pleae make a carb legal header
- Question on the RRM piggy back ECU
- Need cam specs
- High flow catalytic converter question
- How often change Mobil 1 synthetic?
- Engine interchangability
- installing AFC need to check pinouts
- 02 sensor
- Valve cover torque
- Need some cam help here
- Best SRI
- Converting AEM CAI to SRI; Possible???
- CAI on a AT Lancer; Is it possible?
- Plugs
- cam gears??
- RRM ECU piggyback questions
- walbro pump gss-342
- Possible fastest n\a setup? Expected gains!! Engine techy must read
- Cam install help!!
- Grounding Kit
- 00 to 04 codensor ?
- question about intake and exhaust manifold
- Vehicle Emissions Sticker
- HELP!!! 3" vs. 2 1/4" pipe catback
- Thinking of buying new spark plugs
- K&N Typhoon Cold air intake for AT?
- RRM piggyback emissions?
- replaced all belts
- help??? hearing engine noise!!
- Timing Belt ?
- Catalytic Converter Problems
- Resonators and mufflers
- What Engine upgrades can I get for an automatic? Besides a Turbo
- Installing Greddy cat back
- Mirage Header in a OZ
- Oz RAlly Sleeper!!!
- Turbos
- ECU reflash and piggyback questions
- Header?
- new to nitrous please help
- Just installed RPW header, downpipe and buschur high flow cat. Small problem. Help!
- rod length
- I need some info!
- nooB question on 2nd cat
- Installed Injen short ram intake
- rough shifts w/ automatic
- Quad throttle body?
- Question about grounding kit
- gauge switch
- Breaking in ECU
- AEM Cold Air Intake Installed
- maf restrictor plate
- Which exhaust system?
- MAF Install
- To keep the cat, or install the pipe?
- obx short air intake problems
- O2 sensors
- MAF sensor swap???
- Greedy Exhaust
- System Too RIch
- Intake and Catback????
- Securing intake
- Anyone else's SRI make a sucking sound?
- Installed buschur exhaust
- New guy has question on intakes
- did anyone ever buy one of those eRAM's?
- eManagement or rrm piggyback
- Tsi Turbo For Lancer
- Injen CAI Install/ Problem
- HELP!!! Switch for an ECU???
- test pipe
- Evo mas adapter on our lancers?
- ported and polished engines for lancers
- How hard is it to change timing belt??
- Camshft Position Sensor
- Kamikaze header
- Evo motor put in a Lancer?
- CAMS, we need them
- intake manifold gasket
- Power stering and ac belt?
- Venom control module
- Looking for CAI pipes. Just the pipes.
- Header & Downpipe Installation
- EBay CAI?
- Had your warranty Denied/Voided?
- Engine making noises Help!!
- question about NOS
- RRM PB and CEL
- Cat replacement question
- Aem V2
- RRM Piggyback Fed Up
- O2 Sensor
- Lineage kit v. hyper kit
- Ground kit, does it really help?
- Ebay Straight Pipe
- stroker kit
- General intake questions
- Motor mount help
- Compression
- Headers with Emissions testings
- "Ralliart" oil caps on Ebay
- Your RPMs on ignition switch?
- I need help
- RRM Header and bad idle ...
- quick question
- Injen CAI
- Dump tube?
- strange idle?
- Exhaust
- idle problems
- 247HP Supercharger Drive System for our Lancer??=)
- Frustrated Buschur intake
- Oil light is on when standing still
- Lancer's and Mirage's chassis'
- exhuast/header/downpipe/cat combo
- 4g-63 swap ?
