- Same ECU across years? 02 vs. 03?
- hurricane power cold air intak ever heard of it?
- Horse power figures
- Some Throttle Body Questions
- Companies making rods?
- Buschur Catback issues?
- will the greddy e mange be enough to..
- gonna fill up the tank tonight!!
- NA Update: 16.209 @ 86.19
- Question about injectors
- What exhaust part is this?
- Aftermarket Oil Pump
- 2g gsx injectors - Will they fit?
- Upgrade
- Help no power to fuel pump
- idle problem than dies...
- Just ordered RPW stage 1 Cam
- Fastest N/A Time Slip Updates
- pda help.
- SafcII help
- RIPP Prep
- How much whp with stage 2 turbo kit?
- Loss of gas mileage w/ catback???
- installed my GReddy. boy was it a biatch!
- SC or N/A help me out
- Yet another cai verses sri question.
- A huge hole in my downpipe??.. Is this supposed to be??
- Help please with Power Steering and AC Belt Tensioner?
- mirage exhaust fitment
- start up problems
- New N/A Project will beat ///RRM Stage 1 car
- Goal: Fastest N/A Lancer-----mods list inside
- Stock Water Temp Sender
- Exhaust Header
- Help deciding on a catback?
- Kamikazee hdr/dp with test pipe....will it sound ricey???
- Oxygen Sensor
- Which coating should I do on my header???
- RRM Bored Throttle Body
- fuel pressure reg psi
- msd sport compact replacement coil
- Loked for it didnt find it, so Just asking
- Engine Swap Lancer OZ V-6
- Potential HP W/O turbo?
- does anyone know if these fit?
- Service Engine Soon light came on today...
- Rebuild Engine?
- Help on next upgrade
- Installation Help
- Help w/ engine codes
- ~Kamikaze Header problem~
- Does intake brand matter
- IAT Sensor
- Sticky Pedal????
- Upgrading muffler for 2004 OZ?
- Which fuse is...
- What header is this???
- Is my tranny dying??
- Toluene
- Magnaflow Custom Catback installed
- 4g92 mivec
- O2 cel fix!!
- Back firing
- start-up question..
- CEL code b1 s1
- Latest piggyback install
- EGR valve
- Whos interested in Tech Manual for US Lancer
- any 04's with RPW header?
- Help Needed car wont turn over.
- Million dollar question - Emanage
- Intake & throttle body is on
- Headers and stuff
- Piggyback ECU
- NA Modifications could have no affect?
- ?'s 'bout Fuel Injectors
- Buschur Racing 4G94 Wiseco Pistons In Stock!
- Round vs Oval Mufflers: is there a difference
- Car Dyno
- Custom Exhaust Setup Questions
- valve cover
- Valve Cover Bolts
- RRM and RPW
- Header Confusion
- O4 ralliart o2 sensors
- RRM Piggyback / Headers Combo
- bought drop in k&n filter and need your help!
- Where to get a new honeycomb?
- Estimates??
- Factory mistu ground wire kit
- Kamikaze header is on
- Hyper Ground Cables
- Cat converter options?
- Aftermarket Radiators?
- low end power???
- Spark Plug wires
- so i think im the lastest victim
- head swap: runs like a racehorse
- y does it tick?
- Aem Cai
- hp gain
- head swap: now won't start
- Purpose/Function of grounding wires?
- throttle line
- How do I?
- Piggyback solder questions
- RRM Piggyback
- bypass valve / hydrolock info
- Ignition systems
- Grounding wires
- valve cover qs!!!!!
- flowmasters
- greedy or Apexi!
- SRI/CAI question dealing with freeway driving
- Need some help with an OZ!!
- RRM Piggyback & cold weather
- S-AFC or Emanage?
- Throttle Tight, then throttle loose problem
- Magnaflow Exhaust
- Intake question
- Cold air intake...
- Twin Throttle Bodies
- HELP! oil pan drain plug bolt specs
- Walbro Fuel Pump
- Road Race ECU Misfire...
- Water Pump
- exaust/header issue
- kamikaze header install
- fuel rail swap
- Injector Resistors on Lancer?
- Brands of Intake
- 2 vs 2.25 vs 2.5 exaust
- ignition coils
- Yet another exhaust thread - but personalized!
- stock cylinder bore
- Making the exhaust decision
- port and polish
- plz ex. exhaust to a semi-newb!!!
- Intake Mod and Engine Photo *Comments Wanted*
- anyone using 2inch exhaust piping
- 4G94 specs
- Magnacore wires (again) few pros
- Exhaust
- Need more power
- Exhaust resonator
- Turbonater?
- Ecu, Looping????
- valve problem
- intake manifold install w/pics
- Is this correct? (Vacuum hoses)
- Shouldn't i be having more power?
- HELP! New Smog Laws = no intakes legal?
- Idle Flux?
- alternator belt??
- SOHC vs DOHC
- RoadRace Testpipe?
- Twin Filter Intake
- SES fix?
- oil ???q's???
- hot day, lumpy idle/stall please help.
- custom exaust
- voltage stabilizer?
- kamakazi header for 04
- 4g63 swap
- Fuel pump?
- compression
- I have a question!!!
- Intake manifold installation
- In search of braided steel fuel lines
- exhaust experiment and questions
- rrm pb ecu question
- Ignition and Fuel System
- RRM piggyback plus cams?
- ricey exaust like a vtec civic???? help!
- will i need the cai ne more
- Swaps???
- Cry02?
- Vacuum gauge
- Cold Air Intake for AT 02 lancer ES
- somebody install this urself?
- Where to buy new Engine Oil Pan
- okay one last v6 forum
- Okay second questoin.
- Turbo ES ???
- Possible Hp
- Tightening Throttle cable?
- turbo timers?
- RRM Auto Piggyback HELP!!
- Installing Upgraded Fuel Rail - 4G94
- Might Need a new alternator
- What is it and can i remove it?
- Sun Ground wire (hot Earth)
- Last day at track, dissapointed
- engine swap ?
- ECU or turbo first???
- CEL = Output speed Censor. HELP!!!!
- Looking for good intake kit
- RRM Intake Manifold and Throttle Body
- test pipes
- Sites selling CAIs
- What turbos are cam compatible?
- What else to change when timing belt is....
- How Tough Are the Factory Internals?
- Question about the Intake Manifold
- Engine?!!?
- Blew my engine - RRM IC Turbo
- Headers?????
- Throttle Body Port by ProflowDesign
- Convince me!
- Available swaps...??
- Ported Throttle Body & Intake Manifold
- Got my typhoon intake today!
- Magnaflow Install
- Mini style intake?
- Digital Readout - SAFC or other?
- Piggy Back and Shifting???
- head gasket change?
- Header + Catback Buzz Problem...fixed!
- Mas Help !!!!!!!
- Injen intake system
- performance parts 2004 lancer es
- How to: I.M and T.B
- 2002 Mitsubishi Lancer O-Z Rally Edition L4-2.0L SOHC MFI / Piston and Connecting Rod
- Has anyone used the "Bullfrog Head Packages" ?
- Lancer Shop short shifter
- whats a good super for ES?
- How fast could you?
- Intake manifold and TB.
- Injen CAI for 2004 ES
- stroker kit (US LANCER)
- Exhaust manifold bolts on Evo. The same as OZ?
- MAF simulator?
- Walbro pumps for OZ's ??
- Is this possible???
- gutted muffler?
- BOMZ Short Ram Intake
- Cylinder Head Gasket
- auto lancer
- 4g63
- Muffler - Oval or Round? Size?
- engine code ?
- how do i get more rpms?
- header installed! now i have some qs!
- Take it off!
- ?? on NOS, NX, Venom, ZEX all NO2
- exhaust gaskets
- HELP!! Do I have an Exhaust leak?
- Return of the coil thread.
- header install qs????
- A Question for RRM
