- 4g94 turboed?
- 02 Lancer OZ Apexi SAFC II settings??
- Possible valve problem??
- sheet metal intake mani?
- Ported/Gutted Exhaust Manifold
- Engine Problem
- ROAD/RACE Header with CEL ELIMINATOR
- Mitsubishi engine codes(4g94, etc.) fully explained
- How to read a SPARK PLUG
- Engine feels/sounds ruff when turned off
- Oil Filters - which one is the best
- Radiator hoses
- Engine hoses...
- Mechanical o2 seems to work w/ RRM header!
- Fiberglass or Carbon Fiber
- Gm Maf/maf-t
- Emission Recall Notice 02-03 Lancers
- RPM hang, DUE TO unlevel MAS??
- Govern Limiter
- Mods
- Evo Engine swap!!!
- stock intake hose replacement
- Help! Whats the technique to remove bottom left exhaust mani bolt?
- Headers????
- adjusting idle
- Spark plug change
- Power Steering
- Question about injectors?
- APEXI i-Moni
- Apexi super AFC
- Crank Pulley for the 2.0 engine
- DOCH 4g93?
- Greddy eManage...
- Haltech ECU Plug and Play 99% finished for Lancer/Mirage
- put new longblock in....problems!!!
- Need a little help with an intake...
- What wires do you splice into for the RRM Piggyback
- Auterra Dyno run
- Engine rebuild
- 9.75:1 octane needed?
- reflash??
- $530.00 for a darn MAF sensor
- New Lancer
- maybe valve problems???
- ECU Chip actually works??
- need help...i put on weapon-r short ram intake
- My ECU fried??????????????????
- plug info?? please
- Stock EGT?
- 4g63 Head on the Lancer OZ??
- flow numbers for a stock 4g94 head
- I've searched the forums...
- AFRs for given octane
- IT A OF The VALVE HIGH PERFORMANCE???
- wiring question
- Ah yes... New Lancer Owner...
- Porting explination
- HKS Super AFR
- My SRI install Bomz
- RamAir update
- Puffing White Smoke Out From the Exhaust
- my header
- RRM Piggyback problem....help
- any info or suggestions
- Big FIX! now just a few little fixes (slight miss fire)
- O2 sensor wires and problem
- New CAI
- Swap ??
- wideband narrowband o2 sensor help
- General Ignition question
- Anyone ever degree an RPW stage 1 cam?
- ~Walbro fuel pump loudness?~
- Tuning ignition timing with an e-manage
- Pictures of ported cylinder heads
- stock downpipe
- Fuel Filter location
- Correct NGK Spark Plug Number
- Intake/exhaust Valves
- service engine soon light
- Engine And Tranny Swap
- cam gears
- Installed kamikaze headers on an 04
- bull frog head package
- Porting Out.
- Engine ECU Questions
- 02 Lancer OZ Rally? Potential??
- Rods and Pistons
- 93 Mirage Engine parts
- Check/Set Timing?
- Dumb Question: OBD II READER: Don't Laugh
- heres something that im going to try....
- Throttle Body Spacer
- GREDDY evo catback + kamikaze headers =???!?!
- Ignition Timing with an e-manage
- Need Help Raising Idle
- Help: Engine overheating...
- Decent spark plugs replacement
- Cruise control vac line length?
- might be a stupid question.
- Walbro w/o fmu?
- Blown Engine....Thinking about a Swap
- Kamikaze Headers
- NEED HELP ASAP! wher does this go....
- Will an 03 gsr evo exhaust work on 04 lancer es
- Just purchased the Greddy e-Manage, now what....
- Muffler help
- Correct me if I am wrong, but....
- AEM or INJEN?
- 05 Raliart block swap
- lifters
- pauter rods for sale
- Engine rebuild
- RRM piggy back
- Let's rewire the ECU!
- MIVEC's
- Low idle after spark plug change
- evo8 or secong gen eclipse motor possible swap for an 03 oz??
- Camshaft Position Sensor Install?
- Thinking of turboing my 03' Lancer
- WTF??!?! Stupid Techs!
- Wierd Idle?
- Valves ?
- mirage cam
- magnaflow universal muffler
- Question for people with K&N Typhoon SRI
- Cold Air Intake.... Need Help Asap!!
- WB02 for 132.99
- Wideband sensor Q
- Got My 4G93 Mani, Now Have ??
- CAI for automatic
- Adjustable Cam Gear!
- For those needing an o2 sensor replaced
- 2002-2003 Lancer ES Engine Swap
- Where is my fuel pressure regulator?
- Magna Flow CAT Back
- 420A turbo
- Evo fuel pump
- Different management units / different use and benefits
- Stock Crank Pully Diameter
- 60mm tb... narrowing it down
- Upgrades and How-To (Newbs look here!)
- Is the maf necessary with a piggyback?
- Bad Mufller
- found gsr motor
- greddy EVO catback ?
- pedal to the metal?
- RRM Piggyback ECU Does it Really Help
- Tuning sites
- eManage- ECU in limp mode?
- Quad Throttlebody 97+ Lancer Mirage 4G93 4G94
- Stock header flanges... cast or steel?
- Magnum Fuel Rail or Throttle Body
- A/F ratio for n00bs
- ok exhaust?? but not a stupid one either
- NA EGT Temp Comparison
- TPS wires
- connecting rod bearings
- Exhaust System
- how to tune apexi safc2
- Timing belt (help with re-install)...
- Mirage Header and Downpipe
- MAS that will fit my lancer. just wanted to be sure
- low idle. due to MAS?
- Question Camshaft RPW Stage 3
- Under Drive Pulley
- Need to increase hp???????
- Piggyback
- NGK Iridium Spark Plugs
- exhaust setup options
- CAI on auto
- 4g94 Camshaft
- 6A12 MIVEC Engine
- Mobile 1 Advanced
- Exhaust Sounds...
- Greddy Exhaust
- Bad Gas??
- What are the most cost effective engine mods?
- 6A13 engine
- Oil Change info
- Intake question
- Which do you recommend?
- 5" intake and heat shield
- Turbonator?
- dc sports vs. greddy
- horsepower
- RPW cam install on Sunday. Pre #'s
- Exhaust
- Smaller Battery???
- can anyone
- 11.5:1 pistons on pump gas
- Denzo plugs , Gap?
- Cold Air Intake MT/AUTO
- lights
- FSE FPR n/a to FI?
- is this a good setup? passing emissions.
- Piggyback Install
- ATTENTION: people with RRM Headers
- magna flow vs. greddy evo2
- How to tighten the belt
- help in swapping
- Ported 4G93 vs. RRM 4g94 IM
- sparkplugs and wires?
- Wraping the Entire exhaust system.....
- Huge Install Tomorrow... any tips?
- twin loop exhaust?
- bad o2 sensor
- Time for a tune up
- engine swapping help??
- evo 8 engine drop
- Latest RPW cam installed
- CEL light code 0421
- Header Install
- Rev Limiter
- Electric Turbo?
- header downpipe install
- Help Me Get Hp!!
- Installing stage 2, need some help
- Oil Pressure Gauge Help!
- Exhaust Gasket (where to buy?)
- Exhaust Manifold Gasket
- Mivec?
- Cylinder head for sale
- is your o2 sensor blown yet??
- piggyback or emanage
- Headers & Exhaust
- Gen 2 G92 MIVEC Head w/ Pics = 56K death
- o2 Sim???
- Bosch O2 Sensor Universal 4
- MAS question?
- More fuel
- To install a 255lph pump
- CAI don't fit the 05 Lancer!
- Replace Air Filter
- Ralliart vs Lancer OZ
- how do i hook up my gauges ?
- SRI question
- Help! Headers melted radiator fan
- Autometer Water Temp Guage ?
- Happies Ground wire kit ><......help
- Spark Plugs & Wires
- Help Intake
- keeping tabs on oil level
- Kamikaze Header
- I need info about stage 2
- Throttle Issues
- spark plugs
- Engine life?
- Best mod for mid range?
- fuel pump???
- Battery move to trunk
