- OBX-R header installed
- Replaced my custom catback (pics)
- DIY Throttle Body Bore Out
- 4g63 in an oz "i rhymed"
- Any one running air bypass vavles
- Walbro 190 Fuel Pump
- fuel pump
- Tons of random engine noises, not sure how to diagnose
- Battery relocation
- Performance mods for better MPG?
- Acceleration Mods
- Intake Gremlin
- NSC Engine Damper Review
- noise in idle....
- MegaSquirtII Install......Help/Input????
- custom test pipe for 04 oz
- need help idling issues car shutdown
- '03 header on an '05?
- timing belt question
- RRM header question
- Serious Maintenance Questions
- Muffler Choice (not ricers)
- i dont think its hydrolock, what is it?
- Heat Shield
- Cheap intake mod
- Water Puddle, No start
- Aem Cai
- Exhaust?!!?
- Cat-back for Sportback?
- Greddy versus Magnaflow
- pulley question
- new mods & thanks
- $200 to spend!
- RPW Info
- k&n typhoon intake, fast simple question.
- running rich
- custom catback questions
- New mod--> lancer throttle body
- i need cams
- Exhaust Questions...
- Second thoughts (exhaust)....
- Installed Kamakazi Headers today
- Spark Plug / Breaking up Issue.
- temp gauge problem
- wanna take out power steering and ac
- missfiring question...
- bottom end (rods, pistons, etc.)
- Intercooler (newb question)
- Rrm Fmic?
- Most beneficial parts
- RPW and RRM performance review!
- Oil Pump Issue
- Catback size in inches for mildly modified O.Z?
- motor swap
- RRM Props!!
- 02 - 03 exhaust
- Rumble in the brakes
- I need a red CAI not Ram Air
- Air intake/CEL
- stroker kit
- How hard is it to installmotor mounts?
- Grinding noise. Help!
- Engine Noise......im getting scared.
- next upgrade
- ACCOLADE: 4-1 Header System Total Package Pics !!
- Any decent power mods for a 02 oz?
- engines for the OZ
- Backpressure & Exhaust Question
- Installling exhaust tomorrow.
- Cat flange
- engine problems
- Super Ghetto SRI
- Cai
- Need Help
- ROAD/RACE Stage 2 HEAD.
- Intake Issues!
- 4G61 into Lancer?
- Question!!!!!
- throttle response
- Lancer ES Engine
- Exhaust system difference 03-04
- Need 10 hp plzz!!
- Burning off oil
- O2, Wideband, egt sensors
- rmr intake filter size...
- oil catch can
- Problem Spark Plugs Coil? CEL
- Radiator problems
- RRM intake manifold and throttle body ?s
- Can Someone Point me to an Oil Cooler?
- whats the max power oz can handle on block?!?!
- 4g93 pulleys for 4g94 lancer
- weird cel
- What about DC Sport or Apex'i exhaust ??
- drop in filter
- Finally ...
- Greddy evo 2 exhaust question?
- Magnaflow exhuast leaks...New install
- Getting a new muffler
- Check out these injectors
- OZ RALLY Exhaust question
- A little research goes a long way...
- header making nose
- anyone running aftermarket connecting rods?
- torque pattern header
- Short Ram Intake Vs Cold Air Intake
- Swap Auto for Manual tranny
- Willing to learn
- idle adjustment
- BIRTHDAY!!! What upgrades should i get?? PICS! HELP MEH!
- Bigger injectors make a big diff?
- Installed RRM Test Pipe and Lightweight Crank Pulley today!
- No idea where to start
- Pulleys
- 05 lancer es returnless fuel system.
- warranty
- Piston and connecting rod donation
- Another Mod! intake Manifold
- any type of spark plug wires?
- need pointers
- Sea Foam
- Help!!!!!
- Engine Swap
- Exhuast ?
- Camshaft...
- header question
- valve cover gasket....
- Help!!!
- what you buy with $2000 in N/A mods
- Need Help Yet Again
- 6A12 MIVEC swap
- engine temp gauge?
- Running lean? Oh crap.
- NSC engine damper
- Any ideas for a catback for 04-05 lancers?
- Intake Question
- unhooked O2 no code
- Headers
- 02 Sensor Melted?
- Magnaflow 3 chamber muffler
- Head Studs for the 4G94?
- What other performance besides turbo?
- Jdm N1 02-06 Mits Lancer Es/ls Oz
- idle issue not RRM piggyback, could be and most likely is...
- Please help with my exhaust.......
- gear studder
- 2002 - 2003 lancer downpipe?
- SRI for 05 ES... yeah right... HELP
- Which Cat-back Fits?
- I need an o2 sensor
- engine swap
- Not much low end?
- 2002 lancer oz o2 sensor signal wire?
- Forged Pistions
- Need some NA advice
- Exhaust Concern...
- Arp head studs
- Weapon R review
- Front Mount "Cold Air" Intake
- extending o2 wires?
- my car is sucking right now...
- choosing intake
- High Flow Cats - shapes = ?
- Highest MAP on N/A car
- removing cats? @ muffler shop...
- Adding a cat to stock exhaust with afterm. muffler
- Magnaflow 2.25" Catback
- Valve Adjustment? lifters?
- Battery
- 02 bung placement with RPW race
- I don't want to sound like a Honda
- Balance Shaft Removal...
- Wow, and you thought YOU were a noob!
- arcing problems + a relapsing misfire
- Importing RPW engines
- RPW Headgaskets....give me suggestions.
- Cold air intake?
- intake Mani help!
- Intake air cooler?
- Any Ideas???
- Terrible Noob Question, Need Help Now
- All you need to know: SPARK PLUGS!
- magnaflow catback installed
- header question
- Should I clean the runners?
- A few questions on fuel needs and tuning
- dyno ?
- Boe's fuel rail
- Automatic frustration
- Fuel Question (just Ordered from RRm)
- Air Ducts and water/weather?
- A little help please - Vacuum lines
- cam in an 05 OZ?
- Nitrous?
- Engine Swap????
- Air intake for Automatic
- cat coverter
- Engine miss?
- best na setup
- RRM CAI Review
- Ok here's the scoop
- 05 us lancer es - FPR
- custom catback exhaust
- compression bent piping
- Warm Up Cat ISSUE: HELP!?
- Down Pipe
- Shell Gas best for pig?
- Ok I searched, one last question re PB
- 05 lancer es.
- Big problem with MAS
- Attn: OZ rally lancer owners!
- mod my lancer, help?
- Valve Cover Problem
- Bad gas mileage! Help
- Exhaust
- Yet Another Kamikaze Header Thread . . . please help
- Koyo Radiators N E good?
- 4G64 for $1000
- Searchin for best ECU
- Header Bolt Reinstall
- Rebuilding engine tips?
- Skunk 2 for Lancer ES?
- Kamikaze Header (yes i did search)
- A'PEXi Engine Monitor
- What coolant and mixture do you use?
- EVO engine swap into Lancer ES 4g94
- Speed and Run Catback exhaust
- Timing Belt Covered Under Warranty?
- O.Z. ralli turbo and AWD?
- pulley
- RRM Headers
- air fuel ratio reading
- Illinois Turbo installers in QC or Peoria
- Resonator
- Another Intake Thread
- Compression Check, NEED HELP.
- weird problem - car stalled
- 4g63T VR-4 Motor Swap....
- Anything New?
- Kamikaze Header
- fmu problem
- any motor swaps i can do?
- oil question
- Which cold air do you recommend?
- Which Headers ?
- I just droped MAF
- 4g93t
- Road/ Race Piggy Back ECU Ver 2
- Engine Swap
- Head Bolt and Rod End Cap Torque Specs?
