View Full Version : Lancer Engine Tech
Pages : 1 2 [3] 4 5 6 7 8 9 10 11
  1. Car Stalls in Reverse - Wierd
  2. OBDII Code 335 & 340
  3. Cleaning TB + IM, HELP!
  4. turbo question
  5. Most quiet muffler with silencer?????
  6. what octane gasoline?
  7. Torque specs request for tomorrow's belts change...
  8. 4B11 swap???
  9. Best Belts out there for an 04 LANCER
  10. Car shuts down in the middle of the highway!
  11. Please Help!!!!
  12. Improving Fuel Economy
  13. Stock fuel pump?
  14. weird noise from under the hood
  15. Oil Question...
  16. RRM High Flow Cat Install (rust problems included)
  17. rpw cam
  18. RRM Piggyback Computer
  19. rrm cel eliminator
  20. Msd
  21. Stage 3 cam
  22. Spark Plugs???
  23. 4g94 DOHC???
  24. Max RPM?
  25. Just how much power..
  26. fast stock lancer es
  27. Power Steering Leak?
  28. 4g94 performance parts.
  29. 4g64 question
  30. Can't drive over 100mph
  31. Exhaust - 02-03 compatibility with 04+
  32. Whats best now?
  33. TSI Turbo for 4g94
  34. 4g69 into 02 oz rally
  35. Guages needed question
  36. Heat differance experiment before and after DIY throttle body mod.
  37. Lifters
  38. OBX Header
  39. Titanium exhaust now available
  40. heat wrapping
  41. Mods before FMU
  42. Headers/Downpipe Issue
  43. Manual Tranny Oil
  44. To DIY or Not to DIY (Timing Belt)
  45. SOHC to DOHC??
  46. MAF Restrictor / Piggy::: New question
  47. Overused but can find info on OZ exhaust Mani
  48. Ground Wire
  49. Lancer Sputtering
  50. OBDII Or CAN scanner...
  51. head gaskets
  52. Noticing something odd
  53. New Engine Questions
  54. Old News!! 4G64 Swapped Into A 2002 Lancer
  55. Wiring up gauge lamps? simple question...WHERE?
  56. 2005 Lancer OZ UPGRADES
  57. 6G72TT swap in 03 lancer oz
  58. about rrm's camshaft
  59. torque on arp head stud?
  60. engine stalling!?i
  61. where is the first catalytic converter located
  62. Custom Piston Order Form
  63. who has a greddy??
  64. Torque Specs for Head
  65. Sheet Metal IM
  66. Engine light codes HELP!!
  67. Cel eliminator.. interesting experience
  68. Crankshaft Pulley
  69. brand new car with weird idle!
  70. overheating issue
  71. K&n Sri
  72. quad throttle + forced induction
  73. RRM camshaft review?
  74. Sellin my stock exhaust off of my Ralliart..will it fit on an es?
  75. Raising Rate FPR
  76. Exhaust Help!
  77. head 4g94
  78. idle problems
  79. CAM Gear benefits?
  80. Port and Polish Cost
  81. Intake mani. install and review
  82. Catback Exhaust Questions
  83. Question on injectors.
  84. Noise Concern !!!
  85. performance/noise concerns
  86. Greddy Evo2 Exhaust..
  87. car didn't come with a manual???
  88. Lancer N/A Guys.... have a few questions for you
  89. Intake adapter question - fitment?
  90. rpm jumps when ac is turned on
  91. hi-flow cat for 04?
  92. greddy evo2 catback exhaust
  93. Adj. Cam Gears???
  94. HELP ME! Lancer aint running right
  95. Car Stalling Help!!!
  96. oil in a plug!!! help
  97. How many HP did I add?
  98. idling jumping while car is at stop
  99. Exhaust Question
  100. Oil choice
  101. IM/TB Spacers
  102. Help 02 Lancer Wont Start
  103. **Mirage Underdrive Pulley on my OZ**
  104. Fuel rail question
  105. springs, retainers, valves, etc.
  106. Best SRI for Lancers
  107. Install-Clutch and starting problems
  108. fuel rail question
  109. Finally got my Pistons!!!
  110. OZ Rally 2003, non-modified. Which ign.wires ?
  111. Rod bearing and valve seals
  112. Hows that for a port?
  113. torque patterns
  114. cam, valve springs, cam gear
  115. Cold mornings
  116. Help with engine problems
  117. Intake manifold and TB install problem
  118. NGK g-power BKR5EGP
  119. Question for People with Filled Motor Mounts
  120. Motor Mounts
  121. simple spark plug question
  122. EVO Radiator fit 02 OZ?
  123. diagnose my problem
  124. Engine Help
  125. What's the Best!!!
  126. Timing Belt
  127. DIY Individual Throttle Body Setup.
  128. Electronics Question
  129. Rev Limit
  130. 93 octane?
  131. Im gonna have some money, what should i do?
  132. Air Fuel Controller Help
  133. Air filter problem
  134. Eclipse parts on Lancer
  135. headers, throttle body, or piggyback
  136. Stupid question.
  137. Timing Belt over 70k = mishap!
  138. Low Idle in Rain
  139. Pretty bad ticking on cold start? any info, please help!
  140. pistons & ecu
  141. Getting 150 HP from the 4G94
  142. car idle
  143. 4g93 Im
  144. Exhaust mani help ASAP
  145. Funny sound coming from intake. any ideas?
  146. cherry bomb exhaust
  147. Low Idle??..
  148. Engine Question
  149. Question about vacc hose.
  150. stock lancer es modification question
  151. Headers
  152. a2design Stage 2 Intake Upgrade??
  153. A2 Designs pulley review
  154. A2 Designs 4G64 Engine Swap!!!
  155. Camshaft - anyone try Delta?
  156. Torque..
  157. Views on 2.0 Lancer 4g94 Cold Air Intake By A2 AND Intake Manifold help
  158. Frankenstein 4g94-3's?
  159. AccoladeSportParts - Official A2 Designs Dealer !!
  160. Intake Manifold Comparison
  161. RRM CamShaft & RRM Pulleys
  162. The 4G63 into a Lancer mega merge thread
  163. Short ram or full cold air intake?
  164. has anyone removed power steering or A/C?
  165. Fuel Injector - Technical Description (Edit)
  166. mas airflow sensor(or somethin like that)
  167. COSMO Racing Power Tuning Lightweight Underdrive Pulley
  168. 4G63 Swap
  169. Auto RRM SRI modding...56K maybe not
  170. nitrous Question
  171. DIY interfooler?
  172. throttle cable pulley
  173. Pauter Rods
  174. Full exhaust?
  175. Fuel Pump Rewire ???
  176. NGk Iridium For Base Lancer
  177. A2 Design Return Fuel Conversion
  178. A2 Designs crank pulley
  179. Stroker Kits
  180. Engine differences
  181. How much would a evo engine
  182. Turbo Head Gasket
  183. where i can find injectors?
  184. Blown motor - Engine Swap?
  185. RRM Camshaft
  186. A2-Design Twin Throttle Body Intake Manifold
  187. RRM Headers+Turbo??
  188. Question on TB
  189. Quad TB's + Turbo=??
  190. A2 Designs - Twin Throttle body
  191. Lancer Pulleys!
  192. Individual (quad) TBs
  193. How-To Cam install questions....
  194. AEM on a 2002 OZ Rally???? PLEASE HELP!
  195. air filters
  196. why is my car still missfiring
  197. Compressed Air Boost?
  198. Do SRI/CAI improve gas mileage?
  199. DIY intake question not yet covered?
  200. arcing and a misfire
  201. concerning horsepower
  202. idle problems
  203. Gas mileage mods?
  204. Pics of OBX header and Downpipe installed...
  205. 100mph is it a computer thing
  206. Rrm Crank Pulley
  207. Stock Intake?
  208. check your heatshield
  209. Cam Gear
  210. Check Engine Code P0102
  211. 4g93 intake manifold - please help!
  212. Reconmend me a catback
  213. Head question for anyone with answers
  214. Timing Belt and Water Pump.
  215. Kamikaze header or OBX?
  216. help fast please - turbo on an es
  217. Header and such
  218. Question For Everyone
  219. Pics: RPW twin throttlebody setup
  220. Do these boots look bad enough to cause a misfire? *no 56k*
  221. crank pulley upgrade.
  222. need wiring diagram of ecu connectors
  223. phenolic spacers?
  224. Exhaust smoke.
  225. won't stay running
  226. 2.4L DOHC into and OZ
  227. my car is screwed up
  228. clutch problems.
  229. need help with lancer please
  230. ? about any cam install...
  231. Exhaust Thread
  232. Squealing Belts on Cold Startup?
  233. 0 - 60 Video
  234. Questions about fuel supply/tank
  235. ACCOLADE - Coming SOON - Cold Air Induction Kits
  236. Accolade - Stage 1 Cam New Price RPW Quality
  237. Pulley removal help
  238. Trying to figure out if its worth it
  239. Oxygen Sensor Question
  240. What exhaust do you have?
  241. 2.0 w/ 1.8 head
  242. quarter mile
  243. 02-03 Kamikaze on 04-05???
  244. shop manual
  245. Is fuel management needed yet?
  246. Performance Questions
  247. Engine bolts
  248. ROAD/RACE- A cam is coming!
  249. Shop replaced timing belt, now no power.... help
  250. Exhaust options
