- engine oil light
- 02 intake manifold on 06 motor
- header sensor
- exhaust measurements!!!
- mods
- head stud help ?
- good brand battery?
- water pump replacement
- engine replacement questions
- Pulleys oh my
- Car stalling after K&N, HELP PLEASE
- Oil Pan Leak...What do you guys think?
- Idles keeps going higher and higher
- Spark Plugs
- easier way to tighten the altenator belt??
- Engine Sounds Like A tractor
- replacement exhaust hanger????
- 0-10 Take off Shudders
- Exaust too loud :(
- My OZ Exhaust Sound Clip
- HELP!Can't tell speed,temp or gas!HELP!
- idleing and higher rpm and spark plug help
- 2003 oz battery, alternator/high output qustions
- RRM cam gains
- Greddy EVO2 on an 04?
- whats next?
- Injen Short Ram Intake
- Performance Upgrades for 2002 OZ Rally AT
- 4G69 Into OZ Rally?
- Aftermarket Exhaust sound inside car
- Pulse plugs anyone?
- Fidanza Flywheel
- at what PSI do you go into the motor
- homemade intake
- whats a good swap
- To cold air intake or not to cold air intake?
- fidanza adjustable cam gears for 4g94
- maf adapter?
- Radiator drain plug location for a 03 Oz Lancer?
- Car only starts when jumped.
- Underdrive pulley stuck...
- My car is overheating..
- tachometer installation
- WARNING: Header Thread (found a new one)
- evo engine damper
- Bought a wrong kit: Can a 02-03 CAI fit a 05?
- is this somthin to be conserned about...
- Water temp adapter?
- Stock 2003 OZ, top speed results?
- 4g94 oem rods
- Should I buy an exhaust muffler or full exhaust?
- Where's the oil sending unit?
- Placement for Temp sender for gauge
- 4G93 TB ??? Need a quick reply...
- Im at 57k Miles
- Narrowband O2 Sensors
- Header, Cat-Back, Let me have it!
- Megan Headers for 04-06 ES/OZ
- what mivec head?
- camshaft duration and lift ???
- Thermostat Woes
- vacuum gauge
- rod bearing? piston rings?
- intake mani? suggestions?
- 02 Lancer Oil Capacity
- cam gear ajustement, how to ajust
- 03 Lancer OZ rally intake
- what injectors u guys using
- Random CEL today...
- 4G96 cams
- Exhaust options for 2006 Lancer ES?
- Timing belt change info
- Need OEM Mitsu Part numbers...
- New catback exhaust!
- clutch goes straight to floor with no pressure
- which radiator should i get??
- Anyone shoot nitrous (wet shot) thru stock 4G94
- Stocky Or A.m. Radiator
- how bad are these spark plugs? *pic*
- Would a 4g93 duel Throttle Body fit on a 4g94
- broke top plastic on radiator
- Cam upgrades & valve springs....
- RRM short ram air kit(filter fell ovv)
- Po421
- this is a dumb question about 4g64 motors
- Header Guard on Lancer es...
- The time is up...60k miles.
- engine swap plans
- Got a CE light?! Post here!
- Who has a spec manual?
- power steering fluid
- Ported 1.8 4g93 or Ported 4g94?
- Service Engine Soon
- cold air/short ram intakes..
- Please Help
- power steering pump replacement
- semi major problem
- Coolant issue - Need some ideas
- Spark Plugs for 2006 Lancer Es
- Mitsu dealer wants 500$ for...
- What to do opinions needed
- intake manifold question
- 2002 oz rally check motor light
- Exaust for my 2006 Lancer Es
- Whats worth Buying?
- Lancer Noob please help
- Fuel cut?
- Magnaflow Catback exhaust problem
- What exhaust to get?
- ROAD///RACE Light Aluminum Crank Pulley
- Cold Air Intake Kit for 2002 Lancer
- opinion on lancer mod
- Weird Feeling on my 02 Lancer... Jolts.
- Changing the Serpentine belt and valve cover
- watch this video
- wierd revving
- Gas with SRI
- MAS on short ram.
- service engine soon light came on
- New Car...what To Do?
- Replacing driver side fan with slim fan?
- Weird Engine Noise HELP!!!
- Recieved my camshaft today!
- Urgent!
- Spark plug wiring
- MAF Dissection
- Front Motor Mount installed(Finally!)
- Lancer Es Cruise Control
- mit 2003 oz cold intake???
- catalytic converter
- Muffler and header question
- Rrm Turbo Kit
- Coil Pack Testing...
- not sure if its worth it
- Small auto problem- lend your ear
- rrm header makes crackling noise?
- Evo 550s on a 4G94? any fitment issues?
- weird stutter/putter when driving
- Could someone look at my spark plugs/boots...
- Why is my header blue/purple?
- What size MM Socket for exhaust install
- what would be the easiest...
- Mystery engine component
- coolant bypass Good or Bad??
- RRM Camshaft Review *FINALLY*
- *UPDATED* pictures of custom intake manifold
- RRM Crank Pully Installed
- speedchip!!!!!
- Alternator
- 4g94 for evo engine
- Raising rpms
- Throttle Body?
- what spark plugs???
- Headers
- Exhaust ..??
- Valvetrain rattle?
- walbro in a n/a engine?
- Muffler tips
- Exhaust Question
- RRM Pistons and Rods
- RRM Headers & noise?
- 20w50 oil on a n/a lancer?
- Speedchip?
- Crank Pulley Replacement?
- My CAI Broke!!!
- more info about a custom downpipe...
- Location of VSS on 2003 Lancer OZ
- Lancer <> Evo Front Motor Mounts?
- Alt Belt A Very Big Thing
- Ground wires?
- lancer engine troubles
- Cam gear info
- Some questions on plugs/wires/coil packs
- Custom Intake Manifold
- Air Intake
- Leak down test
- RRM head
- 30,000 Mile Service OZ Rally
- Belts Squealing
- Power steering & A/C removal
- Engine Bay Underpanel
- Muffler
- Cai??
- Pictures of custom intake manifold - **UPDATED**
- NA Build
- Little help?
- Galant V6 Engine
- low idle after..... 04 Lancer OZ Rally
- Mini Battery voltage??
- correct fpr?
- Radiator problem
- exhaust question
- anyone in nyc area
- Will 03 catback fit 06 - sorry if answered before
- 100k miles on lancer
- engine stumbles
- Which cam? (Vendor opinions welcome)
- What cam for 02 OZ?
- test pipe question
- 4g13 to 4g18 swap
- stock water temp sensor thread size.. please confirm!
- Fuel Pressure: Please Help!
- Wheres the Crank Shaft Sensor ?
- rrm pulley
- Dual Muffler Theory..
- Hard install?
- Random CAI questions
- Engine miss question
- Another N2O thread
- Performance Radiator?
- Need turbo advice
- FPR Setting
- Questions about the 4G94 SOHC Engine.
- mass air flow
- Lancer Es Engine Swap
- SES Light went n what does this code mean?
- Question for kamikaze customers...
- 02 ES Sensor Problems
- One emmissions problem straight to another.
- swap help
- vaccum leak=shaking engine?
- weird crap
- Car surges with AC on
- fuel filter location
- spark plug wires problem...
- trottle po sensor and egr valve
- I know nothing about nothing, expect I want a pretty car with a nice sound!!
- Cost of new Cat converter for Lancer OZ Rally?
- Alternator Help (picture)
- spark plug wires...
- Which Exhaust???
- Can you powder coat a header?
- RRM CAI - need bolt size
- Finally Put the OBX header and downpipe on!
- Magnaflow Full Catback review/pics/vids
- Bad Luck For Me
- which spark plug
- rrm ported intake maifold
- Where to find 4G94 engine! Price? Availability?
- Engine braking
- Which intake?
- how to make the adjustment of the timing belt
- Ignition System
- Floatted RPM drop when put in nutral
- How-To : Port a stock Intake Manifold
- Questions on Koyo radiator!
- throttle cable got stuck?
- Torque Damper
- which headers
