View Full Version : Mitsubishi TC-SST Discussion (All Equipped Models)
  1. SST acted up strangely today
  2. MR Cammed?
  3. Feels like neutral?
  4. Tapping Noise
  5. This Forum
  6. P1877
  7. Evo X MR problems continue
  8. Basic SST Questions
  9. SST Brake pedal adjustment?
  10. Cold weather + hard downshift
  11. 2nd gear slip in manual mode!!
  12. 0-60 Times Launch/No Launch Tune/No Tune
  13. Question regarding MR SS-T
  14. Why no external transmission cooler for 2010 MRs?
  15. Where all the SST Clutch upgrades at
  16. How brave are you? Neutral drop.
  17. Recommend Transmission Cooler?
  18. SST serviceable soon?
  19. Temporary transmission failure
  20. MR transmission issue.
  21. Proper shifting points for TC-SST?
  22. 2nd gear
  23. Technique For brisk take off from lights w/o LC
  24. MR TCU Flash?
  25. Purchased 2nd Evo and have ton's of ?'s
  26. What's the real deal with boost controllers on the SST?
  27. Rev Limit in auto mode
  28. updates on the upgrades?
  29. How much WHP are MR owners running?
  30. Transmission slip
  31. Trans Temp Gauge Sensor
  32. Got Clunk?
  33. Weird SST behavior during launch
  34. Better launch control with COBB AP?
  35. Fellow SST owners: Is this normal?
  36. SSP Clutch Pack Install Shops..
  37. What happens when the SST reaches its limit? (read inside to find out)
  38. Tranny cooler "group buy"
  39. 305 hp 349 ft/lbs tq
  40. CAMS and SST
  41. AEM Transmission Temp Gauge
  42. Any way to keep the SST shift mode setting to not set it on each start?
  43. SST FLUID COOLER is out!! with test comparisons!
  44. Any actual reviews of the SSP ClutchPacks?
  45. Rough shift from 4th to 5th Gear
  46. SST Coolers- why not use existing tranny coolers?
  47. Compiled List of all SST Oil Coolers
  48. Evo X MR Launch Control? (I know its been asked).
  49. Is it tranny problem?
  50. aftermarket shift knob
  51. TC-SST Fluid Poll
  52. SST oil coolers
  53. TheSin's TC-SST Project an SSP Production
  54. SST Transmission FAILURE THREAD - Post your results !
  55. Service required TC-SST related warning -
  56. Who would switch to a Manual if given the chance?
  57. ams sst cooler kit?
  58. SST & hand brake?
  59. SST engaging sound when throttle on/off...?
  60. Extreme Jerking when doing a rolling stop in normal mode...
  61. Reverse problem (SST)
  62. SST Rev limiter bounce
  63. Another SSP oil cooler installed
  64. launch control ......misshap or blown tranny >>
  65. Clamping Sound & Jerky Movement RA
  66. quick takeoff, but not outright launch with SST?
  67. Anyone have a blown SST for R&D purposes?
  68. is my sst going to dead ?
  69. SST missing a shift?
  70. MR - car won't move in drive
  71. I have an Evo X Mr w/ ~1k miles on it..
  72. Discussion of Slippage/Heat in TC-SST
  73. Blitz SST cooler kit
  74. When to change SST transmission fluid?
  75. Launch Control???
  76. SST with 330 HP and a warranty
  77. Tranny forgetting to shift into 2,4,6
  78. MR problem somethings not right i think..
  79. Boost Controller question for the MR
  80. HELP! My TC-SST is Freaking Out! Symptoms and Remedies...
  81. Difference?
  82. Thinking about getting a tune...
  83. Another TC-SST likely shot
  84. Evo X SST mapping.....
  85. SST not for big modding
  86. hpa motorsports dsg reflash for vw dubs
  87. MR Trans Cooler Fan
  88. My car freaked out after a brisk drive
  89. Spy Pics SST Cooler
  90. Max Torque?
  91. Just bought a mr. have a few question on tuning
  92. shifting in Normal mode
  93. About this forum
  94. Ssp sst upgrade press release
  95. Attn ralliart & mr owners
  96. TC-SST Gearbox
  97. Sst upgrade mr owners must read
  98. SST - Down shifting
  99. Most powerful sst evo x
  100. MR SST: shift delay in manual mode
  101. SST Tranny Work
  102. Mr sst upgrades underway
  103. MR SST and high WHP
  104. First MR Trans to go...
  105. Can anybody help me with any JDM SST EvoX
  106. Characteristics of TC-SST.
  107. SST trans fluid made of GOLD!!
  108. replacing the SST with a 5spd manual?
  109. Most Hp on the SST
  110. SST tranny and RA = Evo compatibility
  111. MR owners, what`s your driving habits?
  112. What's wrong with my X? SST jerking at low rpms
  113. EBC on SST
  114. video for the SST guys :)
  115. SST Holds 400+ Hp/TQ
  116. Project SST with Blouch Dom2 and cossie cams
  117. Another SST Thread...
  118. just curious, how much power can sst safely handle?
  119. Does your SST shift to neutral when braking hard?
  120. HKS oil cooler kit for the SST
  121. Will the SST transmission become serviceable?
  122. TC-SST only handles 331 lb-ft
  123. How to stay in SST manual mode
  124. Tech Video On Sst And 4b11t
  125. Performance enhancements with the TC-SST?
  126. Evo X MR TC-SST shift knob
  127. MR SST Engine Start Grinding
  128. SST Gear Whine Noise
  129. SST tranny overheating at the tack! Mitsu need to find a fix!
  130. sst tranny overheating problems!
  131. Weight of the JDM Evo SST
  132. SST Pics
  133. Characteristics Of W6dga, Twin Clutch -sportronic Shift Transmission (tc-sst)
  134. AMS Tunes another EVO X MR with SST transmission!
  135. 373 Hp Sst
  136. How does the SST respond to left foot braking?
  137. Still more cool TC-SST info: Shift Mechanism
  138. More cool TC-SST info: Control Mechanism
  139. SST - Diff. Modes = Diff. Boost??
  140. TC-SST TSB (info, not problems)
  141. do the clutches in the sst need to be changed?
  142. Evo X & SST
  143. How does the TC SST sound with an exhaust
  144. Does the SST ever shift itself?
  145. Quick question bout TC-SST
  146. SST-Tranny settings
  147. SST First Impressions?
  148. DSG modified to handle 575hp - TC-SST too?
  149. First defective SST?
  150. New SST real max torque.
  151. SST Questions
  152. SST clutch longevity
  153. Rumors about SST confirmed!
  154. Evo X MR SST Launch Control Video!
  155. Any updates on the MR with SST?
  156. EVO X SST in U.K.
  157. SST - how does it stop?
  158. Evo X Mr Sst Or 5-speed?
  159. SST Tuneability
  160. SST Info
  161. Rev match for the SST??
  162. do GSRs come with sst?
  163. SST Operation Explained
  164. SST production delayed
