View Full Version : Evo X How Tos / Installations
Pages : [1] 2
  1. Bov intallation problems
  2. new guy to evo world + first mod =)
  3. A Pillar removal?
  4. Front wheel studs?
  5. AMS Fan Shield trouble
  6. ETS Evolution X Intercooler Kit Picture Install
  7. Battery Question
  8. Rexpeed R-type ducts (fog light delete)
  9. How to pop open plastic racing harness holes?
  10. Modify stock exhaust to remove flapper
  11. SST Fluid Change
  12. Settings Menu On Gauge. Change to km and liters, etc
  13. PROBLEM: Installing Seibon OEM CF Front Lip
  14. HELP on installing Blox Vacuum Manifold Kit
  15. Installing your own clutch!
  16. help!!! how do I take off the o2 sensor
  17. Help with MBC install
  18. Installing DG Motors EVO 9 Converted Master Cylinder/pedal
  19. Headlight removal
  20. How to take out hood rod?
  21. My trick passport 8500 install sort of
  22. Why no Turbo Swap threads
  23. mmcs question
  24. Help! Takin the back seat off
  25. Help battery completely dead doors wont open!!!!
  26. Passenger headlight won't move along with the dial.
  27. HOW TO: Brake Rotors and Pads Replacement
  28. Go from MBC back to stock electronic boost controllers
  29. Brake Oil Bleeding
  30. What is the best way to change out a front parking light?
  31. How hard to install a regular downpipe ( No O2 housing)
  32. How to test fuel pressure ???
  33. Remove and Polish Valve Cover
  34. HOW TO: Check Fuel Relay with Multimeter
  35. oem navi install questions
  36. HOW TO : fuel pump relay 1 test
  37. HOW TO: Make a distribution block for Gauge Installs/Radar Detectors/Anything else.
  38. Custom Gauge Pod Project
  39. Those who have removed the OEM high spoiler...
  40. zt-2 wire routing
  41. Request: how to wire up sound system on factory headunit
  42. Stock Boost controller question
  43. ets intake install
  44. Radar direct wire install help
  45. Fog Light Disassembly
  46. Airbag light issues/Bride seats
  47. Changing oil on rear diff
  48. How to install Torque Solution Front Engine Mount
  49. How to install front engine mount:
  50. Transfer case drain plug size
  51. Anyone knows how to do wheel alignments the X?
  52. Custom intake install w/ pics
  53. Removing antenna on roof
  54. mount camcorder in car
  55. HOW TO: Remove radiator grill
  56. Cabin air filter ("air purifier filter") change?
  57. Serpentine Belt Adjustment?
  58. how to for wideband 02?
  59. How to Blackout Headlight housing (even though I left a bit of chrome)
  60. Remove front/down pipe (not dump)
  61. Install LICP without removing body
  62. How do i clean evo exterior?
  63. Help on Turbo Removal
  64. how does this happen?
  65. AMS cai
  66. Ams test pipe install pictures
  67. Question about rexpeed Ralliart Style CF Ducts
  68. evo x stock wastegate aculator
  69. Scratches around emblem
  70. installing extended studs on rear hubs?
  71. Curbed my rim
  72. First Oil Change
  73. Has anyone made a custom heat shield for Cobb SF Intake?
  74. seatbelt warning sound
  75. Monday AMS test pipe install. Tips?
  76. Removing the Evolution aluminum shift knob.. AYUDA!!
  77. TurboXS Knock Light
  78. how do you change MR driver side DRL bulb?
  79. APR Vortex generator
  80. where can i get an oxygen sensor socket
  81. how hard is it to install a cp-e exhast
  82. Evo X Front Mount Intercooler (FMIC) Installation Howto (Illustrated)
  83. AEM Tru Boost Install Help
  84. How to make doors auto lock when you move?
  85. How to remove stock Evo X pedal covers?
  86. Interior Rattle
  87. Need Help With Tial Q BoV
  88. Step by step down pipe removal and installation instructions
  89. Whiteline Roll Center Kit
  90. Agency Power shorty antenna
  91. TPS Sensor wiring diagram, or gas pedal?
  92. How to painting twin hood wents?
  93. Need some Help BC RACING BR coilover install
  94. Need Help with AMS Fuel Rail
  95. Flush/Change Coolant Instructions Needed
  96. Anyone Know How To Remove Switch Blank Next to Evo X Steering Wheel (Above Fuse Door)
  97. HKS Uprated Actuator
  98. Seibon Front Lip Install Instructions
  99. Display Speed in the Multi-Function Information Display (MID)?
  100. Quick Install: AMS Shifter Base Bushing
  101. Stock fuel rail removal ?s, Evo 8
  102. AMS Shifter (((Base))) Bushings
  103. How To: Lock/Unlock chime disable/enable
  104. HOW TO: disable non-HID X DRLs (this works :))
  105. Eibach Pro Kit install
  106. apr rad plate n ARC induction box
  107. airbag light
  108. Multi-tool/ tire press equalizer / deflator / boost leak test assist/ etc.
  109. Is this safe/ Will this work?
  110. Help with FMIC install (Pic included)
  111. how to install different ront seats - with no fault codes
  112. How to install SSS spoiler on a Canadian GSR with GTS spoiler...help!!!
  113. Drifting your mitsubishi EVO X - Stability Control Secrets!
  114. HELP!!! how do you remove the X turbo?
  115. How do I connect the SWI-PS
  116. Replacing Evo X steering wheel with Evo 9/8 wheel
  117. How to remove spark plug cover?
  118. Oil temperature and pressure sensors for Greddy Informeter - oil sandwich?
  119. New Gauges Setup! Looks OEM + AC Control Relocation
  120. HOW TO: Make a Custom Heat Shield (SRI)
  121. How to remove SAFC ?
  122. how to install greddy tic on evo x
  123. Hide-Away License Plate Frame (Pictures & Video)
  124. HOW TO: 5v USB + 12v Outlet Power
  125. Apexi turbo timer install
  126. How to change miles in km on ODO and trip
  127. Air spoiler ( Tall Wing) Evo X
  128. New O2 sensor, now won't Start HELP!!!
  129. Fort Myers turboback installer
  130. How to: Install OEM Backup Camera (above license plate)
  131. Evo X Jack Points......
  132. Greddy Type S?
  133. Hks camp 2 & if unit
  134. HOW TO: Stainless Steel Clutch Line Replacement
  135. Unlocked MMCS
  136. wastegate forge problems
  137. hella supertones?
  138. Tapping into cigar lighter?
  139. Chargespeed Evo X Bonnet Center Duct
  140. How many ftlbs for the Brembo caliper bolts?
  141. Motul 600 brake fluid question
  142. Electronic Boost Controller???
  143. Panel Air Filter
  144. Spring Install - Tein S.Tech
  145. manual boost controller
  146. Hoodlatch will not open.
  147. Good place to run Wideband/EGT/etc (pics)
  148. How to take out intake manifold?
  149. Problem With Hks Ssqv Bov!
  150. AMS EVO X O2 Eliminator 3.0" Downpipe Installation
  151. Rear Bumper Removal (How-To)
  152. Fog light bulb replacement
  153. installing AMS Exhaust and test pipe
  154. mechanical boost gauge
  155. DIY Carbon Fiber Interior Trim
  156. Wideband Install Question
  157. Help!! Hardwire passport 8500 x 50
  158. Instructions for Ralliart Lip
  159. Pics of Evo side mounted plate?
  160. Best way to disconnect tranny from engine on floor???
  161. Custom Triple Gauge A Pillar!
  162. Quick Install: Nisei 1PC UICP with Front Bumper on
  163. How to put a test pipe on?
  164. Ralliart Pedals
  165. How would you use a trolly jack?
  166. seat slider-rail dissassembly
  167. UIP Install Question
  168. DIY heatshield for Cobb SF Intake
  169. Ralliart Taillight Install w/pics
  170. GSR Cam install
  171. How to install uprated wastegate actuator?
  172. 350Z intake on an X.
  173. Razin voltage stabilizer done
  174. A-Pillar fabrication Pictures
  175. LED Trunk lights
  176. Aftermarket Steering Wheel Install - eliminate Airbag light
  177. Q: Valve cover removal??
  178. How do you remove front aero lip?
  179. Prosport boost gauge power wiring
  180. How to: Install rear RA UR mud flaps WITHOUT removing rear tires
  181. How to run fogs with no low beam and drl delete on NON SSS
  182. How to take out rear bumper reflector
  183. how to debadge trunk emblems?
  184. Rexpeed Bumper Cover
  185. Headlight assembly
  186. ETS intake install help needed
  187. Lowering Springs on a X???
  188. Help with wiring Greddy Infometer Touch please?
  189. How To: Install Brake Pads on Evo X
  190. How to Replace Fender Plastic Vents with Rexpeed Carbon Fiber Vents (with Pics)
  191. BLOX Racing Counter Weighted 5-speed Shift Knob
  192. Replacing the EVO X wing with lower profile
  193. Installed HKS Catback system, but have a question?
  194. Troubleshooting
  195. AMS intake install with pics??
  196. HKS Racing Suction Reloaded Kit ..
  197. Tow Hook Install?
  198. How to remove the top wastegate solenoid restrictor pill?
  199. Wingless: How to cover the holes?
  200. How to remove rear bumper evo x
  201. Wiring Diagrams?
  202. MBC= service engine soon
  203. How To Install HID Fog Lights
  204. difficult to remove oem fog lights?
  205. Help Forge Unos and Prosport Boost gauge
  206. How to install LED headlight parking lights?
  207. A-pillar gauge pods
  208. Fog lights
  209. Request: HID alignment
  210. Innovate Wideband O2 Sensor
  211. Relocating traction control switch?
  212. How To Buschur FMIC for Evo X
  213. more questions about changing front seats
  214. Frustrating Front Bumper!!
  215. Request: Part Number
  216. How you change your HID light bulbs without removing the bumper?
  217. gauge pods/location of gauge
  218. HKS EVC VI installation instruction
  219. changing my clutch and flywheel and what tools needed
  220. Prosport boost gauge install...help!!!
  221. Aftermarket Seat Install?
  222. How to remove rear seats?
  223. Putting Car on Jack Stands
  224. Rust on exhaust..
  225. Defi Link Unit Wiring Help
  226. how to install AEM truboost controller/gauge
  227. How To: 5-Speed Transmission & Transfer Case Fluid Change
  228. Help with reverse camera on stock navi
  229. COBB AP placement thread
  230. Cobb AP Install pics
  231. Where to tap for gauge lighting
  232. Oil Temp/Oil Pressure Gauges questions.
  233. Lip spoiler installation?
  234. How To Cam installation?
  235. How do you manually adjust the Headlight?
  236. info on how to take out front bumper
  237. Removing center console in EVO X MR
  238. How to: Oil and filter change on the EVO X
  239. sparkplug cover
  240. fuel pump mod
  241. removing front seats?
  242. rear bumper
  243. Rotor Install/Caliper Removal
  244. Gauge Help! Boost & Intake Manifold
  245. Refinishing Titanium Exhaust Tips
  246. flywheel install
  247. Test pipe 02 Sensor Socket Size???
  248. EVO X GSR Clutch Flywheel Change
  249. Second try....
  250. first post
