View Full Version : Evo X How Tos / Installations
Pages : 1 [2]
  1. Gauge Help! Boost & Intake Manifold
  2. Refinishing Titanium Exhaust Tips
  3. flywheel install
  4. Test pipe 02 Sensor Socket Size???
  5. EVO X GSR Clutch Flywheel Change
  6. Second try....
  7. first post
  8. Brake Pad Change
  9. How to install a downpipe or TBE??
  10. HKS type 1 tubro timer
  11. Hood Scoop Removal??
  12. Headlights uneven. Any way to level one?
  13. How To Cam installation
  14. Quick question: GReddy Profec B install
  15. Request: How To Take Off Fender Vents
  16. How to install a Forge Unos MBC????
  17. How to replace HID on the MR
  18. Request: EGT Gauge Writeup
  19. Coil trigger tap
  20. Apexi AVCR install help Please
  21. Installing an aftermarket steering wheel
  22. Install tip on Synchronic BOV on EVO X
  23. For Those Installing new turbo
  24. Evo X Mishimoto Radiator Install
  25. How To Install a TWM Performance Evo X Short Shifter
  26. Mits thread shift knobs work on MR
  27. X fog light installation
  28. Breaking in an EVO X
  29. Request: FMIC Install
  30. REQ: Cartridge Block Heater Installation How-To
  31. Dash Removal?
  32. Ipod
  33. Racing belts???
  34. Evo X Boost Gauge Install ,No splicing, No firewall drilling,Pics+Vid= Clean As Hell
  35. Evo X "Standalone Gauge"(Defi Racer) Install w/ Pics&Vid
  36. REQUEST: High Torque Take Off
  37. Request: Hella Supertone horn Install
  38. AMS coldair intake with no vacum inputs???
  39. clutch??
  40. O2 Housing removal is easy. . . .
  41. how to : Smoke
  42. how to change diff and tranny fluid
  43. How to install Parrot CK3100 Bluetooth?
  44. Hks Ssqv Bov
  45. removing spoiler?
  46. Request: HIgh res pic of a decal
  47. neep installing turbo timer hks type 1
  48. How to install coilover suspension?
  49. Shorty Attena on SSS X
  50. How to take tail lights out???
  51. fogs with parking lights?
  52. Fuel Pump Modification
  53. disabling daytime running lights?
  54. Ipod / MP3 player cable installation question.
  55. JDM Push Start
  56. Install Racing Harnesses AND Stock Belts
  57. How To - Aem Tru Boost
  58. How do you hook up Defi Controller?
  59. AMS small battery kint install
  60. Request: How to remove center console?
  61. Who installed this O2 sensor?
  62. sidemarker help
  63. Transmission Fluid Change.
  64. Request:How to remove the black door pillars
  65. How to remove and where is the ECU located?
  66. iPod integration into Evo X Navi
  67. AEM intake
  68. Where Can I Find A Tach Signal / Shift Light Install
  69. Anyone sell just MAF plate adaptor?
  70. Wiring into the tach signal (tach recall shift light)
  71. how to on walbro install???
  72. Bluetooth
  73. DYI oil change
  74. How to Install an EVC
  75. aem tru boost for your X
  76. Battery relocation project....anyone has wiring diagram?
  77. My CAI With custom heat shroud
  78. GTS wing removal, Evo wing install
  79. how to install a mbc
  80. Request: EBC installation.
  81. Buddy Club secu timer install questions?
  82. burnt exhaust tip look
  83. Request: Removing Rear Seats
  84. ams mbc?
  85. Where to obtain switched/accy 12V supply from
  86. How to Install a Front License Plate without drilling the Bumper
  87. Cigarret lighter fuse help
  88. Request: How to install AMS Intake pipe?
  89. Auto Signal
  90. TPMS - Anyone know how to disable it
  91. Homelink on EVO?
  92. ipod capable in sss/nav gsr?
  93. How to Install TT in an Evo x?
  94. MR 2-step?
  95. how to increase boost pressue for actuation of factory wastegate
  96. Tools Needed for Headgasket Replacement
  97. Video camera mount
  98. a/v
  99. Request:How to MBC install...again
  100. HID conversion on GSR non-SSS
  101. How to: Paint engine cover.
  102. PB with Mud/Splash Guards
  103. Front Clip Removal with intercooler pipes installed.
  104. How to paint rims?
  105. emblem removal and reinstallation??
  106. Nav wiring diagram
  107. Idles like crap!!!!
  108. Vaccum level for EVO X???
  109. Cone filter install - fixing the spinning bolt problem
  110. How To Use Factory 2 Step
  111. Factory Aero Kit Installation Instructions?
  112. EVO X Headlight Electrical Mod Question
  113. Unlocking Mitsubishi MMCS
  114. What kind of Paint?
  115. timing marks
  116. Gauge Locations Evo X ???
  117. IPOD on evo X
  118. a/v jacks
  119. HOW TO PAINT FOGS--- for those who dont know
  120. How do you lose weight on the X?
  121. How to insall a bov on the evolution x
  122. Play dvds while driving
  123. Help help help!
  124. Front Bumper removal
  125. HID retrofit has anyone done ityet?
  126. RPM signal wire
  127. clutch install
  128. Works Short Shifter for Evo X'
  129. How to install wideband O2 sensor bung
  130. Three more access points to go into the passenger compartment
  131. Oil Pressure gauge
  132. How-To Guide
  133. HOW TO: ETS Exhaust Install
  134. How to Red out the Tail lights on Evo X
  135. Looking how to remove AC cover panel?
  136. Is The MMCS Back-Up Camera Capable?
  137. mounting the license plate
  138. need a how Turn off or reset "PERIODIC INSPECTION"
  139. Anybody have the ECU Pinout yet
  140. Seat Change
  141. Canadian Rear Bumper PROBLEM
  142. Installing BC Racing Coilovers on your Evo X
  143. Aem Tru Boost Setup
  144. Trunk spolier, non SSS
  145. HOW TO: Firewall Access
  146. HOW TO: Install Cone Filter
  147. Vortex generator for the X?
  148. Anyone know how to kill the seatbelt beep?
  149. AMS Shift Bushings
  150. Zeitronix Help....
  151. Hid headlights??
  152. How to disable the factory 2-step
  153. Racing Pedals Install
  154. HID How To????
  155. replace stock air intake w/ cone style
  156. Removal of Rear Subwoofer.
  157. Boost Gauge and MBC install
  158. EVO X Front Spoiler Installation Instructions
  159. HOW TO: Install Factory Bluetooth into Evo X GSR
  160. Good Place For A Boost Gauge???
  161. HOW TO: Install factory Navigation into a NON-NAV Evo 10
  162. Lancer Evolution X - Service Manual
  163. How to turn off Daytime Running Ligths
  164. How to: Make your own shift boot
  165. How to: make an EVO X look good in one easy step
