View Full Version : Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 2 3 [4] 5 6
  1. Dealer front and rear air dams
  2. SS1 Suspension Package is Here!
  3. What's wrong with my brakes? Anything?
  4. Brake pad options (Definitive List Thread)
  5. TPMS Sensor Lag
  6. Evo X Time Attack CE28, Where to buy?!?
  7. Best Performance Tires that LAST
  8. SSR Type-F
  9. eibach sportline?
  10. Weds TC105N
  11. 285/30/18 a6s or V710s -- what's required to fit?
  12. RE30 fitment on X--18x9.5 +35 ?
  13. Everyone Does Black
  14. HB Speed / RobiSpec suspension setup day
  15. Front brakes seized after car sits-problem or normal?
  16. spring help!!!
  17. Enkei RPF1 .....what size?
  18. Model Name of these 1990s Enkei Wheels?
  19. Road Course Times with stock vs aftermarket spring/shocks
  20. Q about sway bar swap
  21. rear DBA 5000's for the evo?
  22. i have a qusition for Advane rims
  23. endless brakes endro spec
  24. What is a good size tire for 18x9.5 +28?
  25. Gram lights 18X9.5 +12???
  26. 19x10 +33 Offset Sunken or Flush
  27. soild strut tops
  28. Fender rolling
  29. Coilover Hunt!!!
  30. Stock wheels what tires??
  31. KW3 vs Hipermax sport
  32. Forgeline ZX3R wheels
  33. T1R Coilovers
  34. Intalled: SWIFT Springs / 15mm spacers / Z1 Star Specs
  35. Which is the best offset for 18x9 wheels for my application?
  36. Custom iForged NEO Wheels For Sale
  37. 18x10.5 E25 with 275/35/18's
  38. OEM Evo X GSR wheel price?
  39. Aragosta Suspension
  40. Cusco Front Lower Arm Bar and Braces
  41. Best alignment for spirited driving?
  42. Volk ce28 or Volk gtf ???
  43. Cusco Announces Sports Zero 2E Coilover
  44. new rims ,but can't decide
  45. SNEAK PEEK: New Nitto NT05 Tires *PICS*
  46. what do you need to program TPMS for 2nd set of wheels?
  47. Wheels offset question~
  48. is +35 offset ok?
  49. Evo X Tire/Wheel Vendors - Winter Packages
  50. Stock Spring rate?
  51. These tires can't be real!
  52. Stock Advan tires wander
  53. PSA Evo IX to Evo X Tires Will not fit
  54. Black CE28N
  55. alignment spec ok for street set up?
  56. First serious snow test on Yoko ADVAN S4's
  57. noob needs help
  58. Nyc winter
  59. Finally got Winter Tires!
  60. Tein Mono Flex Coilovers...
  61. What size rims
  62. Help: Oklahoma Evo X springs/sway bars
  63. What tire to buy after Yokohamas wear out?
  64. EVO X RS AU Model need ABS working
  65. Crossbalance and Alignment Questions.
  66. AutoSock question.
  67. 3mm spacers...need hub centric?
  68. Help with lowering X
  69. Federal Tires -595 RS
  70. Axxis pads scream why!!!????
  71. Installed my coilovers, car is bouncy
  72. 18x9.5 +38 vs +15 Enkei RPF1
  73. Anyone running 265/35/19?
  74. AYC and progressive springs
  75. Responses Needed ASAP!...
  76. Rotora Big Brake Kits
  77. Best winter tires for montreal type snow
  78. Evo X Drag Race Rims and Tires.
  79. Correct Tire pressure?
  80. Thoughts on 19x8.5 +42?
  81. Performance Winter vs Studless Ice & Snow
  82. YOU ASKED FOR IT, WE MADE IT!!! 19" Rota P45 Wheels
  83. Can I run 245:50 R 18
  84. One tire loses 10psi weekly
  85. Coilover advantages/disadvantages
  86. What whould i be better off doing?
  87. Stock wheels in white?
  88. need help with bc coilovers
  89. All season tires Need help will 245's be too stretched on 9.5" rim?
  90. Brembo color code
  91. any hope for repair with patch/plug ???
  92. Wheel Size Question.
  93. Tanabe Sustec Under Brace In Stock Now!!!!!
  94. Need opinions on winter tires
  95. HRE Wheels Clearence
  96. Eibach or Swift Springs Help me decide
  97. Rota SVN-R 18x10 +20 for the Evo X Huuuuge Lip!
  98. Vredestein Wintrac Xtreme
  99. winter wheels off a 350z?
  100. Swapping brake pads?
  101. Rota P45r!!!!
  102. Be careful if you are dropped a lot and hit big bumps!
  103. Any opinions on Falken Ziex ZE-912
  104. wheel spacers
  105. 275/35r19?
  106. Track Wheel and Tire Width Comparison
  107. Stance coilovers
  108. coil-overs - drop height?
  109. Dunlop SP Winter Sport 3Ds
  110. NEW Brakes from BREMBO
  111. 19" Wheel/Tire Combo Spec
  112. New Evo X and front right strut is clunking/rubbing!!!???
  113. So Gram Lights doesn't provide (HC) rings?
  114. Are these to heavy for a x?
  115. volk le28n gold
  116. Vishnu Wheels
  117. 18x10 +35
  118. Factory Brake Duct Guides
  119. News: Dunlop's for new 2009 Lancer Evo
  120. All season tires? What are you running/getting?
  121. Cheapest EVO X Rim?
  122. Eibachs installed, clanking noise from rear
  123. Camber bolts??
  124. advan rz
  125. Tire pressure monitor?
  126. Offset for X MR BBS?
  127. Aftermarket Lugnuts/lockes For Factory Mr Rims
  128. choosing wheels
  129. Throwing off the AYC is it true?
  130. Love this wheel/tire combo... but what is it?
  131. Damage To Acd From Different Tire Tread Depths
  132. Will Evo VIII wheels fit on an Evo X?
  133. Track day left turn fuel starvation
  134. 245/45/18 rubbing slightly on front sides
  135. evo x camber
  136. Pics of bbs x wheels on a 9?
  137. RPF1's on a X in 18x9.5 +15?
  138. new rotors - whatcha think
  139. tyre lettering...
  140. please post enkei gtc01 pic
  141. Stock GSR Rim
  142. Stock wheel size & offset?
  143. Pad replacement procedure
  144. PROPER tire inflation pressures/rules of thumb
  145. Brembo PDF Avail
  146. Winter Tires
  147. Ralliart Front Sports Strut Tower Bar
  148. Performance Alignment
  149. TE37 Generation II a.k.a TE37 G2
  150. The X can pull some G's
  151. Need winter wheel ideas
  152. Stock US vs Stock Japan Ride Height
  153. M+S rated tires?
  154. lug nut torque?
  155. Powder Coated Gsr Rims
  156. will GRAM LIGHTS 57 MAXIMUM 18x9.5 +22 fit evo X ?
  157. ENDLESS Swivel Racing & Steel Type Brake Lines Announced
  158. Getting CE28N, would 19x10.5 +22 fit without spacer or fender roll?
  159. Pics, please!?...
  160. T1r S-coil Lowering Springs
  161. Tpms
  162. Tires for Rain?
  163. Clacking from rear right shock
  164. Swaybars: Cobb vs Works
  165. Cusco Coilovers...
  166. 19x10 +25 in front and 19x9 +22 in the back
  167. Robispec to FL
  168. inside fender measurement
  169. Is there any difference? in these 2 wheels, works and rota wheels
  170. Cobb sway bars
  171. sway bar and alignment question
  172. need wheels
  173. Just got My Eibach's Installed
  174. volk gt30 offset
  175. BC coilovers vs Megan Racing coilovers
  176. Help S-AWC Service Light On.
  177. What do you think of this on a WW EVO X?
  178. Active Yaw Control and alignment
  179. Volks CE28N needs center hub rings for Evo X?
  180. All-Season or Winter Tire?
  181. Winter Tire Size
  182. Girodisc EVO X 2pc Rotors are here!
  183. Which Vendor for Eibach Pro Kit for 08 MR
  184. Tire size Question
  185. most aggressive rim on stock tires?
  186. Graspic DS-2 DSST CTT - Decent??
  187. <> Rim Spec <>
  188. need help :: with the rally art evo x, specs. for my evox
  189. How to fix squeal from OEM brakes?
  190. wheel wear question?
  191. Yokohama w drive or Dunlop wintersport m3
  192. 1/16" deep cut in sidewall - ok to drive?
  193. looking for some bvillens wheels
  194. Yoko Advans S4 all-seasons
  195. Tein S-tech springs
  196. Does lowering cause uneven tire wear.
  197. Help pad recommendations PLZ
  198. Springs Evo X "MR"
  199. Any MR owners w/ Tanabe lowering springs?
  200. Best wheel spacers with stock wheels?
  201. What would your Ideal Evo X Build Consist of
  202. Coilover
  203. New Tires
  204. noob question on tires and alignment
  205. OFFICIAL: SSR Type F Aggressive Fitment Available now!
  206. RPF1 or NTO3-M?
  207. NEW Release Cobb EVO X Sway Bars
  208. Evo8/9 struts on EvoX
  209. Ordered new rims and tires!
  210. Will fit 235/50R18 winter tire to EVO X?
  211. Will eibach prokit springs with aero-kit be too low?
  212. thoughts on 225/45-18 tire size
  213. Drag Racing Wheels & Tires......
  214. RA1s vs. NT01s vs. V700s for HPDE use?
  215. OFFICIAL: Tanabe GF210 Springs Available Now!
  216. Rota Grids 18x9.5 +20 offset (courtesy of wheeldude)
  217. Works VS Fitment
  218. OFFICIAL: Tanabe Sustec Under Brace Available Now for Evo X!
  219. Blue Mag TE37s on PB EVO X
  220. Winter tire options - best recommendations
  221. TPMS on the Track Question
  222. Anyone have experience with these coilovers???
  223. Coilover Install Cost...
  224. springs install?
  225. new DIY brake pipes?
  226. Sanding down Rotors? takes squeal away?
  227. Second Set of Wheels
  228. Anyone tested if Evo 9 BBS wheels fit the 10?
  229. Alinements
  230. Tire Question
  231. spring type?
  232. Rota P45F 18x8.5 +25 fits evoX good?
  233. wheel center bore?
  234. Evo X rotors on an Evo VIII/IX
  235. Will this offset clear the 08 MR Brembos?
  236. KW's V3 advice?
  237. Stock Alignment Spec for Evo X???
  238. looking for the best springs or coil overs for evo x
  239. Stock Tire and Rim Questions...
  240. rims for winter
  241. are these offset too agressive for evo X
  242. Evo X stock offset?
  243. AME FS-01 replicas?
  244. Girodisc Has New SS Lines for EVO X!
  245. JIC and Stance
  246. I Need Brake Ducts Cooling For My Evo 8
  247. 12k miles, 1 tire shot..wtf
  248. Time for a brake upgrade, guide me!
  249. Is is safe to use 5mm?
  250. Tire size recommendations?
