View Full Version : Evo X Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 2 [3] 4 5 6
  1. Getting New Works.....Couple questions
  2. Who is not running TPMS Sensors?
  3. Wheel shake at 70+
  4. Springs for EVO X?
  5. Who makes camber plates for the X?
  6. Woo, look what FEDEX brought me
  7. Rear Strut Brace
  8. These tires are F***** up
  9. Yokohama problems
  10. Aggressive setup!! Help!! Help!! Please
  11. Which springs to go for.
  12. Strut boots on KWs?
  13. Help with Coilover Choice
  14. Installed Suspension...Poor Steering Response?
  15. Help with rim damage!
  16. Need help, will this wheel/tire fit without rolling/flaring fenders?
  17. advan rs tire advice
  18. Sway Bars: Hotchkis and Cobb
  19. HKS Adj Coil overs Keys/tools
  20. Squeeky Brakes
  21. Tire pressure for track day
  22. 275/35/18 on 18x9.5 +28. Will it work?
  23. Best Wheel locks for evo x MR?
  24. what kind of rims is this?
  25. spring seating question
  26. need help raising my ride height
  27. RE30's in Formula Silver almost on
  28. DAI wheels
  29. Rota weight
  30. should i keep the strut tower brace on my MR?
  31. PICs needed 5Zigen ZR520 Wheels on WW EVO X
  32. 18x10.5 +15 - 295/40/18
  33. Tire Rotation Pattern
  34. To those with Rota Grids
  35. new evo x caster prob
  36. Work CR Kai
  37. Suspension Help??
  38. eibach mr springs fit gsr?
  39. tire size to go with my 19 x 9.5 rims???
  40. Perrin vs. Cobb Rear Sway Bar
  41. MR BBS wheel touch up paint?
  42. Advan Neova review
  43. Michelin X-ice versus X-ice2
  44. 18x 7.5" +25mm offset wheel fitment
  45. Advan RZ18x9 plus what size tires?
  46. best springs for auto-xing?
  47. Has anyone successfully retrofitted Evo X brakes to an Evo 8 or 9?
  48. Help with new brakes.
  49. coil over setting & adjusting
  50. Volk RE30 and Bridgestone RE-11 on Edmunds project car
  51. The Easter Bunny came early!
  52. What is the hub/bore size of the Advan RZ 18x9 +35 rims?
  53. Performance A/S Tires Recommendation
  54. Anyone with a pic of the factory camber bolts?
  55. Spacer Recommendations?
  56. Anyone with pictures 18X9.5" wheels with 245/40/18 tires?
  57. is it any non brand center cap fits gramlights?
  58. CV Axle
  59. springs in winter
  60. Teins springs for Evo X
  61. 5Zigen ZR+520 EVO X offset??
  62. Advan Rs
  63. Stock tires replaced for free.
  64. Anyone running cobb springs/pics?
  65. A different kind of Lugnut Question
  66. Will these wheels fit on my X with no rubbing?
  67. CE28N Formula Limited 18x9.5 arrived today... so why am I depressed?
  68. Perrin PSRS - anyone tried?
  69. Any good 19x10's out there?
  70. Some new rubber.....
  71. Eibach Pro-Kit for Evo X MR on a GTS?
  72. Wheel Torque Specs and PSI on aftermarket wheels
  73. Cobb sway bars question
  74. Stock Wheel and Alignment Specifications
  75. TPMS Sensor Programming
  76. Fender liner???
  77. Stock tires average life
  78. Fluctuations in Alignment Settings:Causes
  79. Quietest Tires Possible?
  80. Valve Stem Question
  81. Brand Spanking New Apexi S1 Coilovers
  82. what tires should I run on advans
  83. Rear suspension making clunking noise after alignment
  84. Advan Rz/Rs?
  85. Advan + eibach
  86. KW 3 on the X...help.
  87. What alignment to run with Eibach springs?
  88. Tire Sizing?
  89. Brake Noise
  90. Anyone stuff a 265 on a stock X rim?
  91. Eibach GSR Install
  92. New Eibach Springs for X MR
  93. Summer tire recommendation?
  94. How wide can you go?
  95. Topping off brake fluid...
  96. How can I tell if it's lowered?
  97. Suspension Spring Spacer
  98. Please read: This is not a FS forum
  99. E-Brake AKA Hand brake AKA Parking Brake adjustement.
  100. Cobb Rear Sway Bar Installed **PICS**
  101. Will X MR brembos fit other Lancer editions?
  102. What Wheels To Choose On GG
  103. Anyone paint axel nut?
  104. coilover advice
  105. Different colors of OZ
  106. What color wheels look best on RR?
  107. swift springs change camber too much?
  108. Powdercoat or special order?
  109. Would this be considered the lower control arm
  110. MR spring on GSR
  111. Motor Trend snow comparison of Evo X and STI... and how poorly summer tires perform
  112. TSW Thruxton
  113. Toyo R888 vs BFG R1 Fitment
  114. Anyone using Meullerized suspension parts?
  115. Anyone have Eibachs for over 6 months?
  116. G-Games Baracuda Gunmetal
  117. 17x7 215-50
  118. Rear sway bar (Perrin & others)
  119. HKS Hipermax 3
  120. Hubcentric Ring Fitment Observations
  121. Girodisc Stage 4 Brake Kit
  122. Wheel Spacers and vibration
  123. ~OEM replacements - Tire Feedback for the EVO X
  124. Which brake disc should I go with
  125. EVO X GSR - Brakes
  126. stock wheels, spacers, longer studs, and open lugs !!!
  127. Brake Wizards, Attention
  128. So I finally lowered my x
  129. $500 to install Lowering Springs?
  130. Evo X MR Rims?
  131. Do i need spacer?
  132. Camber and toe write up
  133. Blitz BRW profile 08F forged wheels
  134. Rim Size Questions
  135. will these fit?
  136. H&R wheel spacers
  137. Coilover Fitment Chart
  138. Tire reviews
  139. Tires - Is Bigger Always Better?
  140. KW V3 question
  141. TPMS in Rota Grids?
  142. Evolution MR Owners ... considering suspension options
  143. Alignment
  144. work or tanabe springs
  145. vs-xx?
  146. Brake problem after switching wheels
  147. Wheel Offset Fitment Chart
  148. gsr shocks vs mr bilsteins
  149. Camber Adjustment on stock suspension?
  150. 18x9+30 BuddyClub's.. white. on white.
  151. Are your tires safe?
  152. question about tires and alignment
  153. Stock GSR RIMS with 225/45 18?
  154. Rota Grids Gold on WW
  155. tire help 19x10 rims
  156. Evasive Motorsports tests out new Tein Super Racing Dampers
  157. work cr kai's 18X9.5 20MM
  158. Question: lowering springs
  159. Needs brakes and tires soon!
  160. Installed Megan Coilovers on my Evo X
  161. Coilover setup/install in northeast Ohio?
  162. Nitto NT-05 Tires
  163. Anybody run the Sumitomo HTR Z II's??
  164. What Wheels should i go with?
  165. Megan Coilovers vs Eibach Springs
  166. Wheels back from the powdercoat shop
  167. 19 x 9.5" Wheels and 275/30-19 Tires - Wheel Spacers?
  168. Second Set of rims
  169. Squeaking Brakes
  170. Anyone know what wheels these are?
  171. fender roll place or person in the tri state area
  172. 255/40/18
  173. Anything that can be put on wheels to avoid dust sticking?
  174. Advan RS fitment
  175. Anybody really pushed the stock tires in the rain?
  176. Benefits of different offset?
  177. anyone running MR suspension on GSR
  178. Anyone know effective/wheel rate of springs?
  179. Wheel Fitting Room !! Fit whatever wheels you want!
  180. should i put wheel spacers on my mr?
  181. Brakes Grinding?
  182. TPMS question
  183. Rear swaybar upgrade?
  184. Wonder if this is going to fit when on the ground?
  185. Whats the biggest time you can run with Eibach springs?
  186. stance gr+ on my car
  187. eibach pro vs. tein s
  188. how crappy are oem brake pads on evo x mr?
  189. Project Mu brake pads? Any good?
  190. Hawk Brakes
  191. Powder coating gsr rims in nyc
  192. tire pressure sensors
  193. Apexi S1 Coilovers
  194. Tire size question
  195. Do all coilovers squeak and need rebuilding?
  196. Trying to figure out bolt pattern & offset on wheels
  197. mr suspension or coilovers??
  198. Tenzo R Type M info
  199. MR BBS wheel center caps size
  200. Best way
  201. Mr springs
  202. 9" rim tire size
  203. 6mm wheel spacers?
  204. Track Pads
  205. coilover question
  206. Tire questions...
  207. anyone running oem bbs wheels w/ spacers?
  208. +22 Offset – bad for car?
  209. 18x11 +25 CCW C14, doable?
  210. What are the best X brake pads?
  211. GSR vs MR/SSS Wing Performance
  212. Warping of OEM Discs
  213. I think I found my next set of wheels
  214. Advan rs
  215. Some Advice
  216. Intro: BC Racing ER Series Coilovers - 2-Way Adjustable *** Darkside Engineering ***
  217. any evoX has rims with big lip plz post pic here
  218. Stock height rides smooth, but.....
  219. Prodrive 18x8.5 34mm offset
  220. KW Variant 3
  221. Cheapest place to buy wheels
  222. Anyone running Nitto NT01 in 275/35/18?
  223. Gauging interest.....EVO X suspension parts from GTWorx
  224. Enkei GTC-01 Evolution series
  225. Project Mu HC+ brake pads?
  226. Rota Grids 18x9.5 +20 offset Part II (finally lowered)
  227. Does the NT03-M in 18x10.5 +30 require a spacer?
  228. Lexus F Forged Black wheels
  229. Girodisc Has 1pc Slotted EVO X Rotors!
  230. What back spacing with 275/35r18
  231. Stance GR+ Coilovers Review
  232. Finally got the Rotas and Blizzacks.
  233. kw clubsport
  234. Brake Rotors
  235. Anyone has thought of RAYS GT-C FACE 2 on their EVO X?
  236. Tire Sizing Question for 19x10 20mm offset
  237. Urgent wheel spec question~!!
  238. Anyway to check for TPMS Senors without dismount?
  239. wheel & Tire size help
  240. Evo X GSR with MR Bilsteins, Works .9 springs
  241. Aftermarket Springs...on an MR???
  242. Fender Rolling
  243. People with HKS Hiper Max III Sport coilovers....
  244. When/how do new springs settle?
  245. 18x9.5 +22 TE37 - work required?
  246. Center Caps for Advan RZ
  247. How to disable ABS? Removing fuse din't work properly
  248. Robispec in Denver
  249. Stock Alignment settings?
  250. wheel clearance/brake clearance
