View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : [1] 2 3 4 5 6 7 8 9
  1. Question about mechanical cel fix for Invidia one piece downpipe
  2. new parts for my x
  3. Proper boost source for Tial WG
  4. Best cams?
  5. Just started car and code p1320 came on.
  6. Clutch Problem?
  7. Blouch Dominator 2.5R
  8. ETS FMIC, few questions
  9. Who has a Greddy Spectrum Elite SE cat back?
  10. So where is our recommended fluid data?
  11. new intercooler problems
  12. AMS 650HP EVO X Fuel System In The Works!
  13. ASC Off Light Turns on on 5th Gear WOT
  14. P0300 code after Cosworth Cam install
  15. P0300 Code after Cosworth Cam install
  16. 4B11T on a Evo IX??
  17. Boost Leak??
  18. Major Problems
  19. Buschur Racing EVOX double pumper fuel system!
  20. Return Fuel Line Install
  21. TurboXS exhaust. Anybody have it?
  22. Exhaust
  23. 20K miles and I'm already hearing belt squeal
  24. Downpipes..Recirculate or Vent To Atmosphere?
  25. AMS twip tip exhaust and SC test pipe vid
  26. Polished ETS Twinscroll 3582HTA Kit
  27. AMS Motor Mount VS. OEM - Confused?&^%
  28. boost tapering
  29. acceleration problems
  30. AMS Widemouth Downpipe Install - is it really this complicated!?
  31. FP Black for Evo X? anyone?
  32. AEM Digital Boost / where to put sensor?
  33. Battery Question
  34. Gsr needed for test fitting billet upgraded clutch master cylinder
  35. AWD Motorsports Built Evo X.. ETS T3 Turbo kit w/ 35r...
  36. You guys ready for mid 10's?
  37. ? pulley ? did anyone get it ?
  38. HKS piping compatible with ets IC
  39. HELP just changed my clutch and now...
  40. Cost for upgrading turbo and tune
  41. Anyone running 380+hp w/stock fuel sys?
  42. Timing Chain going bad
  43. Just installed TBE, Intake, FMIC, but......
  44. next mod
  45. garrett 3076r maxed out at 27psi?
  46. Lose torque to gain hp?
  47. Estimates of the temperature of stock turbo & downpipe?
  48. ACD Control: Howzit work?
  49. New TurboXS Turbo-back Exhaust
  50. Turbo Inlet Diameter
  51. 3582 twin scroll problems
  52. Exedy Twin HD + AMS clutch master ring + AMS clutch line. I NEED HELP!! PROBLEMS!!!
  53. WOT engine cut out?
  54. boost leak test
  55. Gates311 Review - MODE Racing Double Adjustable Short Shifter
  56. Blitz catalog - Evo X
  57. Intercooler design - explanation of why this picture shows this?
  58. SSP & AMI Joint Production - EVO X GSR Billet Aluminum Clutch Master Cylinder
  59. LICP for MR with AEM?
  60. Engine Noise-Grounding Issue
  61. Tilton clutch master review/help
  62. About oil change and engine flush
  63. clutch lifespan?
  64. Radiator upgrade?
  65. Tech Talk - Spring vs. Solid Center Discs
  66. Exedy Clutch= Failed
  67. Full-Race Pro Stock Mani Sale
  68. Fuel Line Recall Concerns
  69. Starting my build, what else do i need? need your advice!
  70. TPMS sensor light..
  71. Valve springs PROs? & CONs?
  72. AP not reading boost? or leak?
  73. The Official: How Many Miles On Your Modded Engine Thread
  74. Complete engine cutoff on the highway
  75. Evo VIII/IX fuel pump sock for an X with E85?
  76. pulley kits?
  77. Meth and NO2
  78. AMS Turbo kit
  79. fujitsubo legalis r anyone?
  80. installing FP Red any additional advice?
  81. who is seeing better gains in what cams. . .
  82. Harman Motive Air box - fit quality...questionable...
  83. X clutch master cylinder and clutch slipping
  84. ETS HTA3586 - Runs 10.8X at low boost
  85. Switching from HFC to TP
  86. Anyone bought a new bare block from Mitsu?
  87. Spec Clutches...
  88. Blitz 2.3L stroker kit
  89. So, while I have the hotside off, anything I should do? Porting?
  90. test pipe design differences??
  91. IS this normal?
  92. ETS Mitsubishi Evolution X - Revs 9k on new motor!
  93. fuel pump and high beam relays
  94. What rods are available?
  95. Dyno request.. what would this setup make?
  96. Anyone With SARD Sports Catalyzer?
  97. GT3076R - Internal WG Failure
  98. clutch
  99. Broke the small plastic cup that holding on the bottom of the shifter
  100. HKS legamax with o2/downpipe combo?
  101. Ultimate Racing exhaust broke in half
  102. cosworth fuel rails
  103. looking for ur test pipe!
  104. Cobb ap question
  105. Greddy TBE on it's way, next mods?
  106. Getting buncha stuff, need lil advice/opinion/direction..
  107. U.K EVO x BuILD PICS
  108. ANY Fp RED FAILURES??
  109. To change or not to change out throwout bearing
  110. Parts verification: OEM Boost solenoid.
  111. OEM intercooler spray kit
  112. Clutch time left???
  113. turbo upgrades
  114. HELP on installing Blox Vacuum Manifold Kit
  115. Test Pipe vs. Mini Muffler
  116. So there's special HKS engine oil for EVO X?
  117. Error code: ACD - U0100 / ACD - C1617 wtf?
  118. Input on custom exhaust
  119. Can no backpressure cause missfire?
  120. To switch or not to switch...that is the question!?
  121. Why does my service require light keep coming on?
  122. Removing downpipe, bolts bound.
  123. AYC Reservoir Removal/Bleeding
  124. 02 Down pipe INSTALL TIPS
  125. 29 psi! Need to lower boost!!!
  126. ETS 02 downpipe dump to atmosphere
  127. Aftermarket Shift Knob That's Not All Metal?
  128. Removing transmission
  129. Clutch slipping at only 4k miles?
  130. Exedy clip problems?
  131. ETS Intake and UICP Review
  132. Blitz Nur Spec C-Ti
  133. Has anyone else had a valve job done on the 4B11
  134. Ways increasing displacement helps with the Evo...
  135. What would you recommend?
  136. Cosworth cam vid on youtube
  137. Dry Cone filter vs. Oil Cone filter
  138. [B]Bar & Plate vs Tub & Fin intercooler[/B]
  139. Pro/Cons of stroking and choices
  140. Can you guess who makes this exhaust???
  141. looking for Resonated Test Pipe
  142. Evo X Fuel Return Pipe Recall
  143. Those running aftermarket turbo manifolds.
  144. Turbo Whine
  145. hard to get in reverse
  146. Mixing midpipes and tailpipes
  147. SS exhaust surface rust up north
  148. Fidanza flywheel's replaceable surface
  149. Pics of my Spec Super Twin P Trim Clutch
  150. uhhh ohh help me my turbo is OUT!
  151. AMS Fuel Rail Noises
  152. BOV kit for this setup?
  153. Engine Temp sensor question
  154. Need to add another resonator
  155. couple of newbie questions
  156. AMS LICP Fitment?
  157. Anyone have the agp hard pipe kit?
  158. bov/dv upgrade to calm Dom2 compressor surge
  159. MXP 3" full exhaust (DP/TP/SP).. *lots of picts!*
  160. Help with Blitz Throttle Controller Install
  161. clutch questions
  162. Water/Meth Kit - Aquamist?
  163. Oil Analysis - 08 Mitsu Evolution 4B11 2.0L Turbo Mobil1 EP 5w-30
  164. Best place to get a clutch installed (Midwest)
  165. Just installed 4.5 Garrett FMIC
  166. ETS Exhaust VS HKS Exhaust System (Tons of Pics!)
  167. AGP Intake Questions
  168. Assistance removing transmission...
  169. Resonators...Do you lose power?
  170. Question about my clutch.
  171. Aluminum MAF Flange? Anyone sell one?
  172. car slipping in low rpms
  173. This is why I love my wife. . .
  174. serious throttle hesitaion!!! HELP!
  175. need retune after switching from straight tp to res/catted one??
  176. sound in gearbox
  177. ACT 6 puck sprung
  178. Billet aluminum fuel rail for EVO X and Ralliart
  179. Artisan performance Street Assassin Turbo
  180. AWC ECU Reprograming campaign
  181. No more quiet exhaust
  182. '03 Evo 8 running warm, possible causes?
  183. High Oil Temps when Tracking
  184. car won't hold boost
  185. Help me with EVO X mods
  186. TF CEL fix v2 review
  187. Engine bogging at high rpm's need help!
  188. Shop for Clutch Install
  189. FP Red Owners Boost Duty Cycles? Boost Creep?
  190. CEL: P0014 Camshaft timing..
  191. To new Evo X owners: Save your clutch (and $1500)
  192. Still undecided: HKS Hi-Power or Fujitsubo RM01A?
  193. Turbo only boosting 13psi at most....
  194. Fuel Return Line - Insane Pressure
  195. want to buy greddy tic tb exhaust!
  196. AMS downpipe question
  197. Cams Break in procedure?
  198. Oil Analysis - Who is doing it here?
  199. Car not hitting target boost
  200. What is the power limit for stock internals and drive train?
  201. Buschur 2.3 block needed
  202. How to tell if mass is bad?
  203. Extremely Low Idle (50-100 rpm)
  204. 110 octane?
  205. Phantom shutting down 08 MR(help)
  206. anyone and vendors that replace or took out the stock turbo come in!
  207. evo x downpipe gains?
  208. Clutch makes whining noise
  209. Evo X Intake Thread
  210. ATP Evo X High Flow Compressor Outlet Pipe
  211. New Parts... FP Red and More
  212. K&N intake kit pics
  213. Bolt came out easy. Went in easy. Now hard ass time coming out
  214. Check out Ryan Gates' Nitto EVO X [Specs and in-car video]
  215. Agency Power DP, Exhaust, Gauge pod
  216. Buschur Lower IC Install
  217. Help, how do I test fuel pressure?
  218. Engine and Transmission Oil
  219. Is there a guide to turbos on here?
  220. Best way to avoid CELs with HFC/Test Pipe
  221. Heat solution for running tubular turbo manifold
  222. ATC Clutch Question...
  223. ASC auto shut off issue due to high torque??
  224. Clutch engagement point changed?
  225. HM Intake
  226. Exedy Twin HD Clutch - Impressions
  227. center differential failures
  228. Exhaust Leak is hard to find
  229. 3rd gear failure, need advice what it could be
  230. Input on this setup?
  231. Ultimate Racing EVO X high flow fuel filter kit - anyone else have leaks?
  232. Downpipes....hmmm?
  233. Did anyone try the 'GUS MOD' on the EVO X BOV???
  234. AMS Master Cylinder ring o-ring install help
  235. No Boost after Agency Power Suction Pipe added?
  236. Nisei install/review
  237. Clutch or turbo problmes, help please.
  238. Destroyed compressor blades on stock turbo.
  239. ATTN Evo 10 E85 users!
  240. vacumm lines pic request
  241. Is there really a difference??
  242. Stock exhaust piece with resonator
  243. 64 mm Boomba Throttle Body VS stock dyno results
  244. Transfer Case oil?
  245. Go Fast Bit: Stealth/Deceptor FX Blow-Off Valve: REVIEW
  246. My Fuel Setup
  247. ETS lower IC piping on a MR
  248. Using the stock pressure plate w/ aftermarket clutch disk possible?
  249. What Could This Be.... A Cage in the X? Track This Weekend? Details Inside!
  250. xtremeboost custom TBE
