- wondering if there is a problem
- Great Job TTP
- JUN 4B11 Piston Kit
- Exedy Twin Clutch Disengagement
- S-AWC % of torque split
- rear diff failure anyone?
- Aem Cai + Hks Ssqv Bov
- HKS catalytic convertor
- AEM Cold Air Induction System
- FP Red Tuned
- agency power exhaust??
- MXP exhaust anyone?
- JUN High lift camshaft kit
- HKS Actuator Upgrade Kit For Mitsubishi Lancer Evolution X
- Whining Noise??
- Picture/dimensions of stock Injector?
- Evo X Walbro Fuel Pump installation is possible without making a mess!
- Fuel Pump upgrade Help
- Evo X bolt on Garrett GT30R turbos
- Twin Solenoids...
- anyone know where to have turbo kit installed
- EVO X needs advices for more power
- Nisei Engineering's Evo X Line Up!
- APR carbon fibre radiator cover pictures requst and help
- Head Stud help
- Pistons and gasket Questions.
- CBRD Radiator for X- some pics..
- Spark Tech's EVO X C.O.P/CDI Ignition at SEMA
- ?Catback with o2 downpipe combo and high flow cat
- EVO X Intake Manifold
- Advice on Intake choice
- Stock intake "scoop" is USELESS?
- oil catch can
- Greddy TI-c question.
- Another exhaust option
- What do you like best
- Mivec engagement?
- Meth inj vs. Upgraded turbo
- ams mbc
- Looking for quiet 3" inch exhaust
- TWM Short Throw Shifter
- Which Port for EGT?
- EVO X MR Transmission
- Idling problem after a exhaust install.
- Performance vs Reliability
- IC piping kit & Synchronic BOV for X
- Warning Light
- Cosworth MX1 Camshafts for Evo X in Stock and Shipping!
- PSI our block can handle?
- BVP Evo X 10.7 @ 124
- Drivetrain vibration?
- Request: GOOD Video of Buschur Catback
- Go Fast Bits (GFB) Turbo Fuse
- EVO X MR lower i/c pipe release
- Anyone Running the Artisan SA-X 50 Turbo?
- Problems with Turbosmart Eboost2 on EVO X
- Pedal Engagement high after clutch install???
- Wastegate Mod/Boost Creep Help!!
- AFI EVO X Stock Replacement Manifold!!!
- XtremeBoost Evo X turbo kit
- Tester wanted for RPS Billet Carbon Clutch!
- AEM Water/Meth Injection FailSafe.
- did I get this right? where the boost pill goes
- AMS fmic?
- HKS Legamax Exhaust loose power?
- Greddy Ti-C or Buschur Dual Exhaust with quiet muffler
- Ultimate Racing downpipe with o2 housing
- New APEXi EVO X RS Cat Back
- RWD evo?
- Tranny or clutch problem? Help?
- Turbo Help!!! New turbo system from Peakboost
- Pipe compatibility..?
- [HELP] my evo x under power problem.
- HKS type 0 turbo timer installed
- Any news for T1R dual exhaust?
- Looking for Aluminum LICP
- 12"x12"x2" Enough cooling?
- Direct fit High Flow Cats for Evo X
- What is stock turbo dyno record?
- hows my dyno number
- clutch master cylinder
- Why am i the only one with this problem :(
- Buschur Motor Mount Impressions?
- What does a EVO X MR make at the wheels stock
- '08 GSR - Trouble Shifting into Reverse!
- Injectors help!
- Gear problems
- Nisei Pipe Kit/AEM Intake help!
- My engine tick
- Help with boost
- ****clutch is gone**** need serious advice
- AFI GT Series upgrade kit
- What Clutch do you recommed
- HKS EVC EBC works great on the X
- Intercooler
- 114 mph on the stock turbo and a blown clutch!
- Intake, UICP and exhaust...
- Fuel Pressure Regulator Help
- Hallman Boost Control
- Preferred Differential/Transfer Case Oil(s)?
- ICS Evo X with Forge WGA - 376 WHP 384 TQ
- Harman Motive Intake Review
- AMS's EVO X makes 480whp on pump gas and prototype turbo kit
- factory reflash on MR
- Installign stroker kit
- Evo X Initial Cam Testing--Agency Power Kelford Cams
- Manley Forged I Beam Rods Now Available for the EVO X!
- X Turbo kit outside the car
- Forge WGA testing
- CBRD dyno testing with exhaust..
- AMS EVO X Fuel Rail
- Gasket and Head Stud Help
- Swap 5 spd into MR????
- Now Stocking Buschur Racing Evo X Stage 1 - 3
- Harman Motive Evo X Products Shipping!
- Forge WGA
- CBRD racing radiators PICS!!!
- MR Who will answer????
- EVO X TURBOS , What has the titanium ?
- Midpipe/Testpipe??
- fp red turbo
- HKS SSQ for EVO X - not the bov but pipes
- Hooking up a Blitz SBC
- Car stalled today twice!!
- Cosworth gasket for X
- No Power Take Off?
- Stock Clutch Sucks
- EVO X with Cosworth Cams (Before and After Dyno Graph inside)
- upgrading w/o voiding warranty
- Intake filter selection.
- Evo X O2/DP with external dump
- P1241 Code
- Stock Evo X: BOV? Turbo Timer?
- Cold Air Intake & Cool Tape for Turbo
- Harman Motive EVO X Airbox
- so if you only did these mods, what size IC would you use???
- What do you prefer??
- Mishimoto Radiator
- Lithium batteries for our EVOs?
- I have a slight problem please help
- intercooler painted black safe?
- Found oil leak!
- T1R intercooler pipe pic request
- SES light. How to check for codes?
- where are all the turbo kits?
- HKS Exhaust for EVO X
- Evo X engine upgrade hint part 1
- Turbo problems / Compressor surge?
- DP/TP combo , should be done by end of day. :)
- Snowperformance or AEM Water/meth Kit?
- Exhaust and Intake
- NEEDED! High HP EVO's to help test new Carbon Clutch Technology
- CBRD Radiator for the evo X!!!
- Forge Actuator on a Stock Turbo
- Poor idle WITH heatshield?
- AEM Cold Air Intake Systems for EVO X is now C.A.R.B Certified!!
- T1R 76S Exhaust Pics (production version) and T1R 90R Exhaust Pics (prototype)
- complete Nisei pipe kit
- Just received my Harman Motive Turbo back exhaust!
- Cusco Twin Disk Clutch for EVO X Coming Real Soon!
- P0420 antifouler question & code clearing?
- 4B11 < NVH than 4G63 ---NO!
- EVO X Current Clutch Options
- AMS vs ETS Intercooler
- How Much Vibration......
- Grease sprayed all over brakes after clutch job
- Oil Change
- Wastegate Mod
- Greddy Spectrum Elite Exhaust for Evo X
- TurboXS FMIC
- Approximate Power increase from IC and IC Piping upgrades?
- Best bang for buck Intercooler kit?
- Works or AMS
- Buschur Racing exhaust products
- GSC Power-Division S-Series Cams
- where can i get trust exhaust for X?
- injen intake vs. aem intake
- Harman Motive releases their Evo X Exhaust!
- Reverse Gear Hard to engaged
- EVOX sleeved block
- NEW! Cobb Tuning EVO X short Shifter!
- Rear Diff
- Which Gear Oil?
- Quad tip exhaust
- Any MR with LICP?
- *Breaking News*: Spark Tech And BVP's Evo X...
- Ultimate Racing Dual Exhaust= Excellent
- DOM II Turbo data lots of it too.
- Fp-red!?
- engine problem, I think
- Dyno
- Just finished installing the new UR dual Turbo back
- Upper Intercooler Piping????
- oil looks black before the recommended time change
- drop in filter for the X
- DTM/Blouch DOM II Dyno Results
- oil change
- Clutch
- JUN Turbo Actuator anyone?
- Buschur Racing Evo X BR350
- NEED: **Stock Boost Lines**
- 408whp on a mail order tune
- NEW JUN Oil Baffled Oil Pan
- Street Assassin 50 Trim Trubo
- Low Temp Thermostat? - No need!
- AMS Shifter Bushings
- Dual Exhaust-needs some advice
- Neat Mario 1up Coin BOV
- Milltek Exhaust. Anyone running one, linkie inside
- ETS Intercooler installed
- EGT , Oil temp and air fuel ratio???
- Aem/Artisan Combo
- Any MR's with tubo kits yet?
- evolution X FIA homologation
- Catback, Test Pipe, Mid pipe, Downpipe
- SST vs 5MT video
- AFI Turbo- Evo X Front Mount Intercooler Release!
- New MIVEC camshafts from HKS!
- lot of carbon builtup on rear trunk from exhaust
- any twin plate clutches out for the x??
- Harman Motive Releases Inttake and more
- The Artisan Carbon/ti Exhaust Review
- installed egt probe
- Request: Intake with Air Box
- Electronic Boost Controller
- Transfer case trashed after 3500 miles on STOCK GSR. Why?
- which intercooler pipe kit should I get?
- reverse block
- Extreme Turbo Systems - EVO X Intake Shield Completed & Included!
- 2003 Evo 8 exhaust help
- Which Front Mount To Get?
- Buschur Catback Review by SilverEvoX
- MR bounced off rev limiter in Sport auto mode
- Blouch Dominator 1 rough in tune
- BVP 11.0@120 DSM/EVO shootout Ohio
- New Cobb Tuning EVO X Test Pipe and Down Pipe
- evo x with MBC and boost gauge not throwing CEL?
- attn: Ultimate Racing Metal HFC owners!
- HKS products in development for EVO 10
- MR's twin clutch vs. GT-R's
- Nisei Install Question?
- Exedy twin install... help?
- Coolent advise
- LBS. of Boost recommendations?
- My X's problems!
- BOV question
- The Injen Way
- intecooler pipes to work with the ams intake
