- Garage G Force 80mm titanium exhaust (single outlet)
- Perrin Stealth CBE...
- Just got a new Cosworth dropin filter from RRE
- AMS Intake System?
- Well any DP&Testpipe work w/ Perrin cbe?
- Ever heard of AFE?
- ARC or HKS?
- exedy stg2 4-puck questions...
- EVO X Anyone Making just an o2 housing?
- TBE or CBE
- Buschur Dual Exhaust w/ Quiet Muffler review
- Not the normal missfiring problem
- Cobb Turbo Inlet Hose Gap Problem
- Fluttering Sound Under Hard Acceleration
- Upper intercooler piping
- Compression test
- ams dual exit exhaust
- Evo X Turbo Specs.
- HKS Racing Suction Kits
- Launch Control Problem?
- Perrin Panel Filter
- Changing the tranny fluid in the x
- Buschur Racing EVO X update.
- Hks gt rs bb
- Cat or no Cat
- cobb turbo inlet pipe
- Has anyone blown a motor
- arc induction box
- Intercooler pipe blew out.No boost
- Any COBB Short Ram Users?
- Dry Sump Oil System
- will a 2g eclipse bov work on evo x?
- Clunk in Reverse
- Custom 3 inch single exhaust?
- nisei intercooler piping
- Any new word on the MR's tranny hp capacity?
- Is there a quick shifter available?
- Check those nuts and bolts boys
- Evo X Head. Got porting?
- Interesting weight find & other observations today which swapping the clutch...
- Official Evolution X Exhaust Thread
- good loud but deep exhaust
- Bigger intercoolers
- New part arrived today from Touge Factory
- Down Pipe/O2 housing with Larger Turbo
- AGP exhaust
- evo x mbc help
- Full Race manifold
- Turbo upgrade with stock internals?
- GReddy Spectrum Elite update?
- AEM Intake and LICP Compatability
- Anyone go custom exhaust route?
- AMS How to build a bullet proof 4b11 Part 2.
- Burschur FMIC, IC pipe, shifter bushings installed
- HFC or test pipe in stealth mode
- Trust - Greddy Exhaust
- Tanabe Exhaust for the X...
- Artisan Carbon/ti Exhaust?
- Nisei intercooler piping compatibility?
- Evo X Build
- whats involved in changing a clutch
- drop in filter vs Cone
- Bleeding transfer case?
- 6262 or GT35R Opinion...
- Differenced between HFC and Testpipe
- 5th gear problem
- Noob with some parts questions!!
- Ultimate Racing twin-pipe exhaust clips!!!
- cobb tuning ic piping info ??????
- Help!! CONFUSED!!
- Question re: uprated wastegate actuator
- Cobb ic piping kit w/aftermarket ic
- ultimate racing UICP + single exhaust
- Consolidate turbo options/sites
- HELP: More Codes: P0222, P1234, SAWC Service Required
- lighter flywheel yea or nay?
- Afi turbo billet fuel rails
- dps and testpipes
- Add me to the "clutch go bye bye" club (almost 11k miles on the stocker!)
- Shifter improvements?
- Spark plug replacements
- evo x rs turbo failure
- New goodies
- ETS catback v1 vs V2
- Those with the MR's
- Oiling system questions..
- 3 Cheers for T1R 76s Sparrow!!! HybridR great job!
- Buschur Racing EVOX on the DYNOJET 440+whp.
- What kinda coolant on the X
- Changing ACD fluid... couple questions!
- Buscher vs. Ultimate Racing
- Lets Talk UIC Piping...AMS vs. Nisei
- Wideband Oxygen Sensor on Downpipe or Test Pipe?
- A few exhaust questions
- exhaust question
- Evo 8/9 catback on Evo X
- ETS Full exhaust system review
- Works modified stock exhaust
- Decisions on aftermarket cat-backs
- Running with cosworth cam
- BR EVOX, 400+ whp on pump gas with Cosworth cams
- How much power can the 4B11 handle.....
- Which downpipe?
- Building a bullet proof 4B11
- My T1R 76S Exhaust review (BEWARE)
- Buschur's EVO X, making some nice power.
- Which BOV you recomend?
- HKS Releases Silent Hi Power Exhaust
- What are the advantage and disadvantage of a light weight flywheel
- Surge Tank
- AFI Turbo Project X
- What is an INTAKE really worth when you are TUNED?
- For those EVO X owners who have the AMS 3-inch test pipe...
- How can you tell if your syncros are out?
- Transmission drain bolt covered in metal.
- HKS Announces Oil Cooler Kit
- Evo X TBE Combo
- Air Flow Package
- Perrin Turboback Sound Clips.
- Question on HKS IC Piping
- Redline oil
- SpeedCircuit Cat-Back
- Buschur Racing's EVO X, turbo upgrade/clutch upgrade
- Will an IX exhaust fit an X?
- MoaR CowBeLL!!!
- AEM intake help
- Which turbo you would recommend
- P1870, P1235, P0135. Codes
- AFR gauge help
- will i blow my motor?
- S-AWC shut off/trouble
- RRE Evo X Exhaust
- Spark Plugs
- Boost too high??
- Car wont go into 5th! Help!
- induction pipe?
- Cams and clutch install for X
- Works Axle Back Exhaust????
- stock turbo + O2 housing downpipe = good or bad?
- HKS SSQV Recirc Throwing LIMP MODE HELP!
- gsr/mr launching in boost
- Downshifting an MR
- Cosworth High Performance Head Gasket
- Help: P1870, P1235, P0135
- New intake w/out tune?
- Agency Power
- Turboback exhaust throwing a CEL code
- tanabe full cat back exhaust
- Blitz Nur Spec R Exhaust
- Anyone know anything about this exhaust?
- Injen intake ?
- Ebc
- HELP NEEDED!!!Please Read
- Is there a restrictor in the clutch cylinder?
- CornFed-F.P.Red Evo X??
- AMS 35R X 450awhp!!!!
- New Pick Up: Fujitsubo RM01A Exhaust
- Evo X clutches and Tranny rebuilt
- +1 SE and you should do this too!
- AMS Cold air add on??
- My T1R Exhaust Install Pics (lots)
- UICP?LICP Aluminum VS STAINLESS Steel
- A couple of questions on HKS intake and exhaust
- Blitz i color video in my MR
- Amazing mod for EVO X MR!!! $50=22whp!
- Jun Oil Thermostat
- Those with Cobb Turbo Inlet Pipe
- How do you shift this damn thing?
- Question about test pipe noise
- 1200 cc injectors for the X anybody???
- Finally found a picture of the exhaust "look" I am looking for
- ETS NEW O2 Housing !!!
- stroker kit
- can someone develope an exhaust like this?
- Evo X Clutch Pedal/Cylinder **Heavy Duty**
- Rich tune affecting the spark plugs?
- Fuel dilution in oil problem
- NEW Mobil 1 Racing 0W30
- Different oil
- OFFICIAL: Tanabe Concept G Exhaust Arriving Mid December!!!!!!
- When to change Intercooler and some extra
- Cusco ECO. & Sports Throttle Controller
- cosworth, kelford & Jun which cam?
- When/why do I need a fuel pressure regulator?
- Anybody with KTR exhaust?
- Is LIP worth it?
- First Mr Trans To Let Go?
- Oil filter part numbers
- New setup
- Mbc
- Advice on Red set up.
- Blouch Turbo
- AMS single exit catback exhaust opinions
- ASC service light with stealth fx bov
- HKS SSQV Recirc...
- Gates311: FP Red Review
- Testpipe on stock exhaust
- Best High Flow Cat option?
- Type1 racing CBE - any reviews?
- Visited XtremeBoost this weekend
- exhaust manifold
- NEW Xtremeboost Upgrade Clutch Master Cylinder
- Will these pipes be compatible??
- Supporting mods needed w/FP Red
- high boost
- The truth about BOV's
- Artisan Turbo anyone
- Which bolt-on turbo to get? FP red, Artisan, Garrett, etc etc etc
- RE: Clutch master cylinder
- Damn you o2!!!!!!!!!!
- WORKS Clutch offerings - EVO X
- Works Short Shifter Kit
- hks legamax or buschur?
- Clutch GONE...Mitsubishi wont cover it.
- FP Red for EVOX Turbocharger
- HKS Legamax + Center Pipe + SSQV
- best intercooler
- HKS actuator upgrade kit
- MBC in New England?
- BLITZ Super Sound Blow Off Valve VD Announced
- HKS R Type intercooler dyno
- Stock Turbo Boost management solution - WGA & EBC
- Exhaust Manifold Flange for Evo X 4B11T Motor
- HKS intercooler Pipes
- Coltspeed intercooler now available!
- What oil to use on an X
- AGP X Front Mount Intercooler - Now With Cast End Tanks and Larger Core
- ARC intercooler + airbox dyno
- Unlimited Works Titanium Exhaust
- Intercooler Poll
- Does anybody else notice this???????
- HKS Racing Suction Reloaded Kit
- HKS Evo X step-up menu
- Intercooler: ARC, Blitz or HKS?
- ETS 4" IC with piping, ETS Intake and more to come
- AMS EVO X CNC cylinder head work
- Maximum boost with stock turbo and internals?
- CBRD Evo X Vertical FMIC....
- For those running test pipe, how bad is the smell?
- O2/Downpipe thread by Buschur?
- Anyone have the Ultimate Racing mini muffler test pipe???
- quick air filter question.
- I NEED HELP! Is my clutch worn out?
- Question Gruppe M or ARC intake owners
- Stock vs. Aftermarket MAF housing
- Exedy stage 2 takes a crap!! WTF!!!
- So i just got my UR resonated test pipe
- Problems with clutch slip on high whp MR?
- AEM Intake sound clips?
- Problem....
