View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 3 4 [5] 6 7 8 9 10
  1. Intake CAI question INJEN AEM AMS other???? help me out...
  2. New sound coming from under the hood.
  3. BOV Fluttering sound
  4. check engine when cone filter fell off
  5. Heat wrap turbo? Good? Bad?
  6. Need help! No reverse!
  7. Need 2.5 in resonated test pipe
  8. NEW: Blitz EVO X Surge Tank
  9. ABS checklite code: c102a
  10. Ebay intecooler pipes
  11. Is my clutch going or does my X have other issues?
  12. BVP/Darton EVO X sleeve block
  13. Blitz New Nur Spec C-Ti
  14. Anyone have the Garret GT35r twin scroll turbo on their evo X?
  15. MR transmission, REV limiter
  16. GReddy Competition Ti-C Full Turbo Back System is OUT!!
  17. HKS Filter?
  18. Exhaust hanger solution
  19. HKS EVC for EvoX
  20. What should i do first?
  21. What exhaust is this??
  22. Bov?
  23. Garrett Turbo
  24. Stock muffler mod {how to} for increased flow?
  25. Factory Boost Controler
  26. HKS Valcon cam kit pro
  27. Borla Exhaust...does anyone have this?
  28. ic install help
  29. clutch and flywheel install, Question?
  30. Lucas Synthetic Oil Stabilizer
  31. is this normal or do i have a boost leak?
  32. turbo timer
  33. Motor blew up :(
  34. Stock Exhaust Weight of the X
  35. RRE exhaust
  36. Reverse failure in transmission in evo x
  37. X rs gearbox....
  38. Greddy Spectrum exhaust video / pics - *TF Evo X*
  39. vacuum pressure at idle???
  40. Evo X Backfire.. Help.
  41. Just got my CP-e Catback with Catted Testpipe!!
  42. CP-e Dual Cat-back
  43. ARC Super Induction Box
  44. Cel p0171b
  45. Long term review Ultimate Racing Exhaust
  46. PERRIN Oil Catch Can Placement
  47. any one using the hks suction reload kit
  48. trans/diff broke
  49. Manual or Electric boost controller
  50. Where is TurboXS?
  51. Spark Plug Non foulers
  52. Perrin Highflow Cat Downpipe
  53. Is a crush washer absolutely necessary on the drain plug?
  54. vishnu catback
  55. INtercooler Install question.
  56. ETS Intake
  57. Powder Coated GReddy SE
  58. EVO X guys.. what weight oil do you get?
  59. To test pipe or not to test pipe?
  60. Edmunds Project Evo X dyno comparison of AMS exhausts
  61. gas leak?
  62. Wow. Just wow. If you don't have a UICP.... shame.
  63. So my O2/dp and test pipe/mini muffler showed up today :(
  64. check engine light????
  65. Test Pipe VS Resonated Test Pipe
  66. Anyone with the WORKS REFLASH?
  67. blitz
  68. What to do first...
  69. Car won't move.
  70. Common coolant leak?
  71. Exedy Twin Plate
  72. Any info on UR FMIC??
  73. Anyone Upgrade The Turbo or Cams in an X MR Yet?
  74. New JUN engine parts!!
  75. ETS Intake Question.
  76. Boost Controller vs Tuning and some other question
  77. Clutch WENT OUT
  78. Boost problem or gauge problem?
  79. Almost too nice to hide away!!!
  80. Aftermarkit FMIC weights vs stock
  81. Best test pipe?
  82. noise during turbo spool
  83. Boost Pill hurting performance on 91 octane??
  84. engine problem!!!!help me
  85. AMSOIL changed recommended oil??
  86. Amsoil
  87. Code P0234 after Jun wastegate actuator install
  88. Does anyone have cams installed on an MR?
  89. Agency Power Down and Test pipes
  90. synchronic bov
  91. HELP: EBC with Boost Creep!! Apexi AVC-R
  92. My car is cursed (aka a 2 hours job becomes a 2 day job)
  93. agp pipes
  94. Hks bov
  95. boost pill question
  96. head studs, head gaskets?!?!
  97. AMS Cold Air Intake
  98. HKS Racing Suction Reloaded Kit
  99. Tomei
  100. So does anybody know how to warranty a clutch from Exedy
  101. help!!!!
  102. So has there been any other problems with long downpipes?
  103. Help on preloading Jun/Forge wastegate actuator
  104. LICP; Is it worth it?
  105. Service engine light
  106. Time to test those customer service skills....
  107. gutting stock muffler
  108. Is this going to damage my MR trans?
  109. cel code???
  110. SS Braided Clutch line
  111. ETS Open Dump Downpipe and Intercooler Piping/3.5" Intercooler
  112. What are the Signs of a clutch going bad?
  113. Gsr 5 speed clutch pill removal?
  114. Evo X Clutch options.....
  115. 3" midpipe?
  116. P1238 and C121C after cosworth cam install
  117. FMIC upgrade, sure it makes power on the stock tune, but what about after a reflash?
  118. Help Spark Plug re-Gap needed?
  119. How's T1R product?
  120. Getting a THUD noise *help*
  121. BLITZ Nur Spec-R Review
  122. Blitz upgraded actuator
  123. vacuum hose size?
  124. ETS V2 Exhaust Review
  125. hks legamax with 3" midpipe
  126. Who has the "Harman Motive" Intake?
  127. Question about part/brand compatability.
  128. Selecting engine upgrade help
  129. "Check Tarmac" on the HUD
  130. Monster Sport parts for Evo X
  131. Intercooler size??
  132. 2 Cone filters, Which do you recomend?
  133. Okada Plasma Direct?
  134. ok so i need help quick
  135. I want more torque!
  136. HTA86 Twinscroll
  137. Which boost gauge?
  138. ARC blow off pipe?
  139. Engine Service Warning
  140. Where to buy the boost pill?
  141. Stock Block, Stock Turbo
  142. Diameter for EVO X Radiator Hose??
  143. UR FMIC for Evo X!
  144. best intake question
  145. installing apexi avcr need help on locating the sensors
  146. Quad Exhaust for the X
  147. Mods with Carb #'s (we should have a sticky thread with this info)
  148. Agency Power Intercooler Pipe Kit question
  149. HKS Super SQV Recirculation Kit
  150. Boost Level
  151. Anyone sell aftermarket OEM spec intake pipe
  152. Where can I get a recirc kit for HKS BOV?
  153. HKS Silent Hi-Power exhaust
  154. Performance Parts Sheet
  155. help me pick: exhaust poll
  156. need help!!! code P0140
  157. Downpipe with Buschur SS Dual Catback Exhaust
  158. Nees Help! Engine oil inside the PCV hose?
  159. !!HELP!! Clutch question???
  160. So my clutch finally went......
  161. Cat vs. hollowed cat vs. testpipe
  162. ETS intake elbow issues?
  163. Need Help... CEL P0171
  164. TMW Short Shifter & Bushings...AWESOME (w/pics)
  165. Ultimate racing downpipe.
  166. Crankwalk/Clutch issues
  167. Anybody recirculate the HKS SSQ BOV?
  168. sick of HKS SSQV setup...
  169. Upgrading Fuel Pump??
  170. upgraded valve spring?
  171. P1238 Help!
  172. Distance to Empty
  173. Experience with Works Stage 2 clutch?
  174. Buschur Racing LOUDER then chambered LS1!!!!
  175. Ultimate Racing Exhaust review
  176. Stock FMIC / upgraded turbo?
  177. Blitz R-Vit i-color on MR?
  178. check engine light
  179. clutch install near Tacoma Wa.??
  180. oil change at the dealership
  181. Anyone try this Exedy Clutch?
  182. Wait on Downpipe?
  183. firmware
  184. Works VS. Cobb Short Shifter
  185. HeadGames/Big Valley team up to make the fastest X..even faster!
  186. HKS Hi-Power Exhaust
  187. UICP and Turbo inlet pipe? is it worth it?
  188. what's needed to power my red?
  189. Bad smell
  190. Short Shifter?
  191. Perrin Exhaust
  192. Blow off valve: Where is it at.
  193. Weird WOT CutOut? Any explaination?
  194. any issues with HKS foam drop in filter?
  195. JUN modified intake manifold kit
  196. JUN big bore throttle body
  197. EVO X Auto Tranny upgrade?
  198. Test pipe or no test pipe?
  199. Turbo manifold
  200. Turbo install w/o tune?
  201. X mod pricing... are you serious??
  202. kelford 214-b vs cosworth mx1
  203. help! drivetrain niose.
  204. Homemade Cone Shield
  205. Works Drop In Air Filter?
  206. intercooler hard pipes??
  207. Help transmission
  208. clutch job
  209. Turbo install pics.
  210. Help With Exhaust
  211. 5th Gear vibration on shifter = rattling
  212. New HKS GT3240 evo Ⅹ
  213. best EVO X exhaust question
  214. aquamist meth injection
  215. Can a 4B11T block be swaped with 4B12s?
  216. Blouch Dominator II vs FP Red - Pros/Cons
  217. EVO X ETS V2 cat-back exhaust installed w/rattling noise
  218. Tranny gone (manual)
  219. hks legamax catback/ur 02/dp combo
  220. Harman Motive Single Exit Exhaust
  221. Buschur Bullet Vs. Quiet Muffler
  222. Recipe for over 410 whp on pump gas
  223. Buschur Quiet vs. ETS dual catback
  224. deepest sounding cat back?
  225. Stock X Injector Size and Fuel Pump
  226. CBRD evo X turbo and bits...
  227. Any LICP fit the stock airbox?
  228. difficult to install cams?
  229. The Upper Intercooler Pipe Reducer
  230. Burshur Racing Catback???
  231. SSTF Fluid, Transfer Oil, Rear Axle Oil
  232. Poll - downpipes
  233. oem intercooler
  234. Boost and vacuum numbers ??? WHat you guys have?
  235. Bye ACT hello Exedy
  236. Blitz panel drop in filter
  237. New Deatsch Werks 800 cc injectors.
  238. Engine knock after exhaust and AccessPORT install
  239. Turbo Boost Hose Help ASAP
  240. Evo ECU
  241. Different Trans fluid
  242. Apexi Power Intake Release Date?
  243. FORGE WGA? pros cons
  244. benefit to muffler with 2 exits?
  245. QTP cutout?
  246. Stock Boost Question
  247. Noob question about Evo exhaust components
  248. Grinding noise
  249. Parts combination?
  250. Any good flowing exhausts that don't drone?
