View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 3 [4] 5 6 7 8 9 10
  1. Car going back to the dealer
  2. Evo X with Garrett GT3076R Turbo Upgrade
  3. AEM CAI w/stock vac line setup?
  4. New Invidia Q300 for Evo X
  5. Bov question (forge rs)
  6. AMS EVO X Clutch Master Cylinder Reinforcement Ring
  7. would like to know info on exhaust
  8. Rear Bank o2 sensor replacment
  9. Some food for though about the AMS fix for the master clutch cylinder...
  10. New turbo setup
  11. Deatsch Werks 1000 cc injectors
  12. AEM intake gain from 16 to 30whp gain?
  13. Moving to HOT climate! Which air induction method?
  14. Wastegate Actuator vs MBC
  15. Odd exhaust sound
  16. Two choices: HKS Hi Power or Ultimate Racing Dual exhaust?
  17. Motor mounts and Transmission mounts going bad at 16000 miles
  18. ASC off automatically when full throttle pull in first gear if i get full traction
  19. Clutch & Flywheel - Check Light
  20. Evo X Filter Choices...
  21. LICP for EVO X MR
  22. valve cover pic request and info
  23. W5M6A question
  24. ams vs perrin
  25. do i need a tune?
  26. Possible Fuel Starvation Solution
  27. Cp-e single exit exhaust
  28. Garret Bolt ons
  29. I found a way to make MY evo X shift better
  30. Magnaflow Cat-back - More Info?
  31. Accelerated onto expressway then extreme misfiring...
  32. I need...a quiet exhaust
  33. HKS intake install
  34. Bov mess with the MAF sensor?
  35. DIY wastegate is 100% safe?
  36. Cusco front LSD settings
  37. NEED HELP guys.....installed mbc and only 14-15psi
  38. Major Boost loss at 15 lbs
  39. new exedy clutch and funny noises!
  40. HELP! AFR freaking out randomly
  41. Installed ARC FMIC
  42. Anyone experience noise switching back to panel filter?
  43. engine whine after 1st oil change??
  44. 1/8 tap on intake manifold
  45. head studs - has anyone installed a set?
  46. tranny reliability
  47. HKS Drop in filter install question?
  48. what the heck is this
  49. Drop in air filter with the new reflash from factory?
  50. Feels good going back to a stock clutch
  51. head rebuild
  52. Did new clutch fix your Notchiness?
  53. Race gas??
  54. exhaust with a switch from loud to quiet
  55. Wideband issue/troubles
  56. Decent price on shifter bushings
  57. boost increase?
  58. clutch?
  59. Agency Power Exhaust
  60. ~ EVO X : AEM - WORKS - INJEN Intake Shootout: Round 1
  61. Clutch Engagement
  62. 7.2whp gains by adding Royal Purple oil
  63. CP-e Exhaust
  64. FMIC AMS v. ETS v. Perrin (Discussion)
  65. Invidia N1 exhaust on my Evo X
  66. Stock clutch limit?
  67. Best clutch for about 500HP
  68. Braided lines
  69. positive battery terminal question
  70. Which downpipe... MXP or Ichiba ???
  71. drivetrain service required screen????
  72. Cylinder misfire then loudd pop when driving? Helllppp please
  73. Another engine durability question
  74. Ivey, Full-Race BW TS S300 part 2 - woke up the monster
  75. CEL with downpipe and cat-delete
  76. Anyone tried it? MR shift knob on GSR
  77. Drop-in Filter, BOV sound
  78. Megan oe rs sound clip?
  79. Help me decide on CBE *POLL* edited to add more options
  80. Raccoon vs Intercooler... and replacement :D
  81. Help me decide on CBE *POLL*
  82. It was a sad day for me..
  83. take that pos mitsu clutch
  84. What list of mods would you say I should start with?
  85. What is the limit of the stock block?
  86. AMS single tip exhaust owners, how low is the exhaust in the back?
  87. Front Limited Slip Differential
  88. Hesitation after launching
  89. Exedy Stage 2 Cerametallic Clutch
  90. GSR gear ratios?
  91. Forge WGA + HKS EVC EBC
  92. Need help identifying a sound
  93. High Flow cat....
  94. newbie tuner
  95. home made cone filter heat shield
  96. DG Motor's Evo X Cosworth MX1 Cam Idle video
  97. Engine warning light with new TBE
  98. Additional Parts Needed for Clutch Upgrade?
  99. P0420 Code with Speed Circuit Test Pipe??
  100. Boost pill - yes or no?
  101. Eneos 5W-30 Sythetic Motor Oil
  102. Blitz sonic power induction
  103. exhasut leak?
  104. Agency Power downpipe problems
  105. Dumb question. Are there gaskets in the stock exhaust?
  106. 27 PSI okay? With No tune
  107. Need help PLZ w/ hose removal...
  108. Man this blows *pics*
  109. Xtremeboot O/2 dump down pipe
  110. who knows the reason for reverse problems?
  111. AMS Surge Tank kit
  112. post aftermarket install advice
  113. Stock plastic MAF sensor housing > aftermarket metal MAF sensor housing?
  114. Pics Of My FP Red
  115. HKS GT Full Turbine Kit (GT3240)
  116. How much fluid DIAMOND ATF SP III? Equivalent?
  117. couple of goodies
  118. Stiff shifter between 3-4 gears
  119. Pics: Twm short shifter
  120. Blips in throttle. Weird BOV scenario
  121. Injector Dynamics 1000cc injectors
  122. Best Intake/BOV/Exhaust Combination?
  123. WTB (IL) Stock evo 9 rods/pistons
  124. oil light but why?
  125. 272's on the stock valves/head
  126. What is the Best Gear Oil ?
  127. New gaskets for new turbo?
  128. Boost droping fast!!!
  129. Shift Knob ques
  130. Do we really need a TT?
  131. Nisei Intake Pipe Question...
  132. Hydraulic or cable clutch?
  133. Upgraded Wastegate actuator.. what does it do?
  134. oil press gauges... what does yours read?
  135. Return to stock for dealer to address DTC P1320?
  136. Where to get BOV tubing lines and Y/T tubing splitter
  137. Kelford drivetrain question.....
  138. Battery Dies overnight, HELP!
  139. Taking a chance with a new shop/clutch :-/
  140. quick help on the pitch size of a bolt?
  141. Exedy Twin SD or HD
  142. R.i.p 4/16/09
  143. Need advice on clutch, low mods.
  144. Bigger FMIC = More Lag
  145. DG Motor's Evo X Goes Under The Knife!
  146. My goal is 350-375WHP
  147. Ceramic vs Carbon
  148. question for those with uber JDM intakes...
  149. Car won't shift into reverse.
  150. clutch finally took a dump
  151. licp that keeps oem bov location?
  152. size of evo x turbo?
  153. Test pipe = less engine braking?
  154. AMS 02/DP vs T1R 02/DP poll:
  155. down pipe or test pipe
  156. HELP: Probelm with AMS Underhood Shifter Bushings fitment
  157. Anyone have aftermarket factory replacement turbo manifold?
  158. how much hp from o2 housing for evo x?
  159. Just Downpipe and HF Cat? Thoughts?
  160. Resonated Testpipr/Mini Muffler
  161. How does an MR sound with an intake?
  162. Cold Air Intake or not
  163. BAD BAD BAD Front CV axles
  164. Need some opinions please
  165. Agency Power TIP
  166. Buschur or CP-e
  167. 1.3 Bar Radiator Cap For A Daily Driver?
  168. Gear Ratios
  169. How often do you change your ACD/AYD fluid?
  170. who makes resonated testpipes?
  171. Do you know if this is compatible with the MR.
  172. fuel rail question
  173. Whistling noise on idle
  174. Q about fuel rail...
  175. i/c piping help please
  176. Evo Addiction
  177. Spec stage 1 clutch...
  178. 4" Intake on Larger Turbo
  179. Agency Power BOV
  180. How many miles did you wait before a tune?
  181. Shifter Base Bushings & Transmission Bushings: Metal vs. Urethane
  182. Boost Leak
  183. Panel Air Filter
  184. testpipe queation please help
  185. Performance expected with Cosworth cams?
  186. Those with Nisei UICP please help...
  187. All traders/dealers....
  188. Questions related to the Boost Pill, Manual Boost Controller and Forge Wastegate
  189. Sequential Silent R Muffler
  190. Nisei LICP with stock intake?
  191. Ultimate Racing Duel Exit Catback?
  192. ACT Street Disk W/ HD PP Or Exedy Twin
  193. Injen CAI
  194. evo ix clutch vs. evo x
  195. drop in air filter, good choice?
  196. Got my Cobb AP as first mod...now what?
  197. Weird engine idle Evo X
  198. boost problems
  199. AMS or Buschur????
  200. JAZ One Pint Mini Breather Catch Can
  201. Tune for UICP
  202. Megan Racing Cat-Back Exhaust
  203. need help wit clutch?
  204. Valve springs?
  205. AGP Crank Pulley anyone have it?
  206. My Evo X FP red set up.
  207. Problem With Sport and Super-Sport Modes
  208. Just Curious....
  209. best bang for buck - power wise???
  210. Reverse anyone?
  211. Opinions and Suggestions for This Setup...
  212. Mr clutch upgrade
  213. Video of exhausts for the evo
  214. Paranoid episode inducing ticks.
  215. drop ins for the 4b11
  216. Q for UR dual exhaust users
  217. I only have 3rd and 4th , help needed.
  218. Check Engine Light - Code?
  219. Noisy exedy
  220. clutch peddle gone again....
  221. How good or bad is the stock exhaust?
  222. Anyone know T1R exhaust db level?
  223. SS Braided Clutch line
  224. Fuel Pump issue
  225. Aftermarket clutch...???
  226. Need help ASAP! No boost!
  227. MXP Catback Install
  228. AMS Downpipe!
  229. bov question
  230. HPS intake elbow
  231. My CP-E 3" Quick Power Pipe with High Flow Cat Came in today
  232. Shifter shaft thread pitch?
  233. ETS o2 downpipe vs Ult. Racing o2 Downpipe
  234. HKS vs. T1R Piping diameters...
  235. turbo
  236. Question about Down pipe.
  237. Can I change the stock BOV to VTA
  238. who's running Meth? Esp..in DD's
  239. Transmission clunking
  240. Hardware needed for exhausts?
  241. Crush Washer
  242. quick question, the evo shuts off randomly
  243. EGT Gauge Defective?
  244. throttle issues
  245. Intercooler water spray assembly?
  246. Lost boost when I went back to stock BOV?
  247. Buschur Shifter bushings
  248. G3 Innovate gauge?
  249. rough idle and stalllllllll
  250. Intake CAI question INJEN AEM AMS other???? help me out...
