View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 2 [3] 4 5 6 7 8 9 10 11
  1. Spec Clutches...
  2. Blitz 2.3L stroker kit
  3. So, while I have the hotside off, anything I should do? Porting?
  4. test pipe design differences??
  5. IS this normal?
  6. ETS Mitsubishi Evolution X - Revs 9k on new motor!
  7. fuel pump and high beam relays
  8. What rods are available?
  9. Dyno request.. what would this setup make?
  10. Anyone With SARD Sports Catalyzer?
  11. GT3076R - Internal WG Failure
  12. clutch
  13. Broke the small plastic cup that holding on the bottom of the shifter
  14. HKS legamax with o2/downpipe combo?
  15. Ultimate Racing exhaust broke in half
  16. cosworth fuel rails
  17. looking for ur test pipe!
  18. Cobb ap question
  19. Greddy TBE on it's way, next mods?
  20. Getting buncha stuff, need lil advice/opinion/direction..
  21. U.K EVO x BuILD PICS
  22. ANY Fp RED FAILURES??
  23. To change or not to change out throwout bearing
  24. Parts verification: OEM Boost solenoid.
  25. OEM intercooler spray kit
  26. Clutch time left???
  27. turbo upgrades
  28. HELP on installing Blox Vacuum Manifold Kit
  29. Test Pipe vs. Mini Muffler
  30. So there's special HKS engine oil for EVO X?
  31. Error code: ACD - U0100 / ACD - C1617 wtf?
  32. Input on custom exhaust
  33. Can no backpressure cause missfire?
  34. To switch or not to switch...that is the question!?
  35. Why does my service require light keep coming on?
  36. Removing downpipe, bolts bound.
  37. AYC Reservoir Removal/Bleeding
  38. 02 Down pipe INSTALL TIPS
  39. 29 psi! Need to lower boost!!!
  40. ETS 02 downpipe dump to atmosphere
  41. Aftermarket Shift Knob That's Not All Metal?
  42. Removing transmission
  43. Clutch slipping at only 4k miles?
  44. Exedy clip problems?
  45. ETS Intake and UICP Review
  46. Blitz Nur Spec C-Ti
  47. Has anyone else had a valve job done on the 4B11
  48. Ways increasing displacement helps with the Evo...
  49. What would you recommend?
  50. Cosworth cam vid on youtube
  51. Dry Cone filter vs. Oil Cone filter
  52. [B]Bar & Plate vs Tub & Fin intercooler[/B]
  53. Pro/Cons of stroking and choices
  54. Can you guess who makes this exhaust???
  55. looking for Resonated Test Pipe
  56. Evo X Fuel Return Pipe Recall
  57. Those running aftermarket turbo manifolds.
  58. Turbo Whine
  59. hard to get in reverse
  60. Mixing midpipes and tailpipes
  61. SS exhaust surface rust up north
  62. Fidanza flywheel's replaceable surface
  63. Pics of my Spec Super Twin P Trim Clutch
  64. uhhh ohh help me my turbo is OUT!
  65. AMS Fuel Rail Noises
  66. BOV kit for this setup?
  67. Engine Temp sensor question
  68. Need to add another resonator
  69. couple of newbie questions
  70. AMS LICP Fitment?
  71. Anyone have the agp hard pipe kit?
  72. bov/dv upgrade to calm Dom2 compressor surge
  73. MXP 3" full exhaust (DP/TP/SP).. *lots of picts!*
  74. Help with Blitz Throttle Controller Install
  75. clutch questions
  76. Water/Meth Kit - Aquamist?
  77. Oil Analysis - 08 Mitsu Evolution 4B11 2.0L Turbo Mobil1 EP 5w-30
  78. Best place to get a clutch installed (Midwest)
  79. Just installed 4.5 Garrett FMIC
  80. ETS Exhaust VS HKS Exhaust System (Tons of Pics!)
  81. AGP Intake Questions
  82. Assistance removing transmission...
  83. Resonators...Do you lose power?
  84. Question about my clutch.
  85. Aluminum MAF Flange? Anyone sell one?
  86. car slipping in low rpms
  87. This is why I love my wife. . .
  88. serious throttle hesitaion!!! HELP!
  89. need retune after switching from straight tp to res/catted one??
  90. sound in gearbox
  91. ACT 6 puck sprung
  92. Billet aluminum fuel rail for EVO X and Ralliart
  93. Artisan performance Street Assassin Turbo
  94. AWC ECU Reprograming campaign
  95. No more quiet exhaust
  96. '03 Evo 8 running warm, possible causes?
  97. High Oil Temps when Tracking
  98. car won't hold boost
  99. Help me with EVO X mods
  100. TF CEL fix v2 review
  101. Engine bogging at high rpm's need help!
  102. Shop for Clutch Install
  103. FP Red Owners Boost Duty Cycles? Boost Creep?
  104. CEL: P0014 Camshaft timing..
  105. To new Evo X owners: Save your clutch (and $1500)
  106. Still undecided: HKS Hi-Power or Fujitsubo RM01A?
  107. Turbo only boosting 13psi at most....
  108. Fuel Return Line - Insane Pressure
  109. want to buy greddy tic tb exhaust!
  110. AMS downpipe question
  111. Cams Break in procedure?
  112. Oil Analysis - Who is doing it here?
  113. Car not hitting target boost
  114. What is the power limit for stock internals and drive train?
  115. Buschur 2.3 block needed
  116. How to tell if mass is bad?
  117. Extremely Low Idle (50-100 rpm)
  118. 110 octane?
  119. Phantom shutting down 08 MR(help)
  120. anyone and vendors that replace or took out the stock turbo come in!
  121. evo x downpipe gains?
  122. Clutch makes whining noise
  123. Evo X Intake Thread
  124. ATP Evo X High Flow Compressor Outlet Pipe
  125. New Parts... FP Red and More
  126. K&N intake kit pics
  127. Bolt came out easy. Went in easy. Now hard ass time coming out
  128. Check out Ryan Gates' Nitto EVO X [Specs and in-car video]
  129. Agency Power DP, Exhaust, Gauge pod
  130. Buschur Lower IC Install
  131. Help, how do I test fuel pressure?
  132. Engine and Transmission Oil
  133. Is there a guide to turbos on here?
  134. Best way to avoid CELs with HFC/Test Pipe
  135. Heat solution for running tubular turbo manifold
  136. ATC Clutch Question...
  137. ASC auto shut off issue due to high torque??
  138. Clutch engagement point changed?
  139. HM Intake
  140. Exedy Twin HD Clutch - Impressions
  141. center differential failures
  142. Exhaust Leak is hard to find
  143. 3rd gear failure, need advice what it could be
  144. Input on this setup?
  145. Ultimate Racing EVO X high flow fuel filter kit - anyone else have leaks?
  146. Downpipes....hmmm?
  147. Did anyone try the 'GUS MOD' on the EVO X BOV???
  148. AMS Master Cylinder ring o-ring install help
  149. No Boost after Agency Power Suction Pipe added?
  150. Nisei install/review
  151. Clutch or turbo problmes, help please.
  152. Destroyed compressor blades on stock turbo.
  153. ATTN Evo 10 E85 users!
  154. vacumm lines pic request
  155. Is there really a difference??
  156. Stock exhaust piece with resonator
  157. 64 mm Boomba Throttle Body VS stock dyno results
  158. Transfer Case oil?
  159. Go Fast Bit: Stealth/Deceptor FX Blow-Off Valve: REVIEW
  160. My Fuel Setup
  161. ETS lower IC piping on a MR
  162. Using the stock pressure plate w/ aftermarket clutch disk possible?
  163. What Could This Be.... A Cage in the X? Track This Weekend? Details Inside!
  164. xtremeboost custom TBE
  165. Which Exhaust Do You Recommend?
  166. UR Titanium
  167. X GSR Oil Cooler Specs
  168. AEM intake with AMS LICP's question.
  169. Turbo manifold install help?
  170. what ever happened?
  171. Buschur Crossflow CBE install issues
  172. Custom Powdercoated Buschur IC pipes
  173. Vehicle lunging, trans noises, timing chain warning..... help.....
  174. Greddy Spectrum Elite Exhaust /w Ichiba Test Pipe Review
  175. Flutter after intake install, what is it?
  176. A Couple Exhaust Questions
  177. Cross reference number for NGK R2566B9 plugs?
  178. Opinions needed for a blown Evo X Turbo
  179. Tbe installed
  180. ETS Evolution X GT35R w/ Anti Lag and FLAMES!!
  181. opinions needed guys!
  182. Installation questions - any tips for these parts?
  183. UR dp vs ams dp
  184. Do I need to Upgrade my wastegate?
  185. AMS downpipe installed
  186. Adjust HKS BOV SSQV
  187. Distance from Intake ports to valves
  188. Evo x stock boost
  189. Evo X Megan Racing O2 housing
  190. 4B11 Carnage!!
  191. best turbo options for 0-60
  192. Info: Works Evo X *upgraded bov*
  193. vibration
  194. ETS GT35 Turbo Kit Makes 597whp On Bone Stock Motor!
  195. Who has installed cams on a X? Need some help...
  196. Warning! Fuel pressure regulator problem
  197. Atp evo x gt35r easy projet 500 whp
  198. Master cylinder trashed using ACT HD clutch
  199. Help! Clutch pedal all the way down...
  200. New Install: HKS Oil Cooler Kit
  201. Exhaust leak in DP flex section
  202. Question about turbo-back exhuast
  203. What are the best cams for the X?
  204. ATP EVO X GT35R EWG Twinscroll 600HP Bolt-on Turbo
  205. Evo X Big Bore 64 mm Throttle Body
  206. Did my new found torque own my clutch?
  207. Custom UICP
  208. HKS Silent Hi-Power Ti exhaust video
  209. light tap coming from motor
  210. little custom setup
  211. Gt35 on my x
  212. maybe white smoke?
  213. Mitsubishi Lancer Evolution Garrett Turbocharger Products article
  214. E85 in California??
  215. clutch problems
  216. Headers
  217. Review: Spec Stage 2+
  218. Manual boost control on MR
  219. Serpentine Belt Adjustment HELP!
  220. MR Clutch Packs
  221. replacement pill?
  222. Here is part of the map... my car blew up...
  223. Alternative to Front Motor Mount
  224. New Version 2 T1R O2 Housing - Down Pipe and Resonated Test Pipe
  225. Question To People Using Open Filter Intake
  226. HKS Hi Power Exhaust after Break-in /w Vids and Pics
  227. Quad tips on my Evo X
  228. Overboosting!! :(
  229. The Sound of Cobb SF Intake
  230. Twin fuel PUMPs ???
  231. Mishimoto - Universal Intercooler
  232. invidia n1 pics vid
  233. Evo X Buschur Racing Crossflow Cat-Back Exhaust Installed (Pics/Video)
  234. Brian Crower cams
  235. Best first modification?
  236. Weight of Greddy Spectrum Elite and db with test pipe?
  237. Hard to shift between gears?
  238. Stock downpipe material and thickness?
  239. AMS CAI vs ARC air box
  240. Blitz camshafts
  241. EVO 8/9 FP Red vs. EVO X FP Red - Less power, why?
  242. FPRed 11 psi boost creep on spring pressure
  243. HKS High Power 409
  244. Synapse 40mm WG vs. Tial 38mm
  245. Stock Tune...Lean AFR (Fuel pump relay failure could damage your engine!)
  246. Down pipe question
  247. AMS MC ring install help
  248. Anyone using Brian Crower 272 Cams ?
  249. Best way to spend $800, look inside
  250. Full TBE necessary?
