View Full Version : Evo X Engine / Turbo / Drivetrain
Pages : 1 [2] 3 4 5 6 7 8 9 10
  1. Agency Power DP, Exhaust, Gauge pod
  2. Buschur Lower IC Install
  3. Help, how do I test fuel pressure?
  4. Engine and Transmission Oil
  5. Is there a guide to turbos on here?
  6. Best way to avoid CELs with HFC/Test Pipe
  7. Heat solution for running tubular turbo manifold
  8. ATC Clutch Question...
  9. ASC auto shut off issue due to high torque??
  10. Clutch engagement point changed?
  11. HM Intake
  12. Exedy Twin HD Clutch - Impressions
  13. center differential failures
  14. Exhaust Leak is hard to find
  15. 3rd gear failure, need advice what it could be
  16. Input on this setup?
  17. Ultimate Racing EVO X high flow fuel filter kit - anyone else have leaks?
  18. Downpipes....hmmm?
  19. Did anyone try the 'GUS MOD' on the EVO X BOV???
  20. AMS Master Cylinder ring o-ring install help
  21. No Boost after Agency Power Suction Pipe added?
  22. Nisei install/review
  23. Clutch or turbo problmes, help please.
  24. Destroyed compressor blades on stock turbo.
  25. ATTN Evo 10 E85 users!
  26. vacumm lines pic request
  27. Is there really a difference??
  28. Stock exhaust piece with resonator
  29. 64 mm Boomba Throttle Body VS stock dyno results
  30. Transfer Case oil?
  31. Go Fast Bit: Stealth/Deceptor FX Blow-Off Valve: REVIEW
  32. My Fuel Setup
  33. ETS lower IC piping on a MR
  34. Using the stock pressure plate w/ aftermarket clutch disk possible?
  35. What Could This Be.... A Cage in the X? Track This Weekend? Details Inside!
  36. xtremeboost custom TBE
  37. Which Exhaust Do You Recommend?
  38. UR Titanium
  39. X GSR Oil Cooler Specs
  40. AEM intake with AMS LICP's question.
  41. Turbo manifold install help?
  42. what ever happened?
  43. Buschur Crossflow CBE install issues
  44. Custom Powdercoated Buschur IC pipes
  45. Vehicle lunging, trans noises, timing chain warning..... help.....
  46. Greddy Spectrum Elite Exhaust /w Ichiba Test Pipe Review
  47. Flutter after intake install, what is it?
  48. A Couple Exhaust Questions
  49. Cross reference number for NGK R2566B9 plugs?
  50. Opinions needed for a blown Evo X Turbo
  51. Tbe installed
  52. ETS Evolution X GT35R w/ Anti Lag and FLAMES!!
  53. opinions needed guys!
  54. Installation questions - any tips for these parts?
  55. UR dp vs ams dp
  56. Do I need to Upgrade my wastegate?
  57. AMS downpipe installed
  58. Adjust HKS BOV SSQV
  59. Distance from Intake ports to valves
  60. Evo x stock boost
  61. Evo X Megan Racing O2 housing
  62. 4B11 Carnage!!
  63. best turbo options for 0-60
  64. Info: Works Evo X *upgraded bov*
  65. vibration
  66. ETS GT35 Turbo Kit Makes 597whp On Bone Stock Motor!
  67. Who has installed cams on a X? Need some help...
  68. Warning! Fuel pressure regulator problem
  69. Atp evo x gt35r easy projet 500 whp
  70. Master cylinder trashed using ACT HD clutch
  71. Help! Clutch pedal all the way down...
  72. New Install: HKS Oil Cooler Kit
  73. Exhaust leak in DP flex section
  74. Question about turbo-back exhuast
  75. What are the best cams for the X?
  76. ATP EVO X GT35R EWG Twinscroll 600HP Bolt-on Turbo
  77. Evo X Big Bore 64 mm Throttle Body
  78. Did my new found torque own my clutch?
  79. Custom UICP
  80. HKS Silent Hi-Power Ti exhaust video
  81. light tap coming from motor
  82. little custom setup
  83. Gt35 on my x
  84. maybe white smoke?
  85. Mitsubishi Lancer Evolution Garrett Turbocharger Products article
  86. E85 in California??
  87. clutch problems
  88. Headers
  89. Review: Spec Stage 2+
  90. Manual boost control on MR
  91. Serpentine Belt Adjustment HELP!
  92. MR Clutch Packs
  93. replacement pill?
  94. Here is part of the map... my car blew up...
  95. Alternative to Front Motor Mount
  96. New Version 2 T1R O2 Housing - Down Pipe and Resonated Test Pipe
  97. Question To People Using Open Filter Intake
  98. HKS Hi Power Exhaust after Break-in /w Vids and Pics
  99. Quad tips on my Evo X
  100. Overboosting!! :(
  101. The Sound of Cobb SF Intake
  102. Twin fuel PUMPs ???
  103. Mishimoto - Universal Intercooler
  104. invidia n1 pics vid
  105. Evo X Buschur Racing Crossflow Cat-Back Exhaust Installed (Pics/Video)
  106. Brian Crower cams
  107. Best first modification?
  108. Weight of Greddy Spectrum Elite and db with test pipe?
  109. Hard to shift between gears?
  110. Stock downpipe material and thickness?
  111. AMS CAI vs ARC air box
  112. Blitz camshafts
  113. EVO 8/9 FP Red vs. EVO X FP Red - Less power, why?
  114. FPRed 11 psi boost creep on spring pressure
  115. HKS High Power 409
  116. Synapse 40mm WG vs. Tial 38mm
  117. Stock Tune...Lean AFR (Fuel pump relay failure could damage your engine!)
  118. Down pipe question
  119. AMS MC ring install help
  120. Anyone using Brian Crower 272 Cams ?
  121. Best way to spend $800, look inside
  122. Full TBE necessary?
  123. 8000 rpms
  124. megan racing exhaust, dows anyone have it on ? or have a video??
  125. Perrin AP Maps?
  126. Biggest stroker ever...2.5L
  127. noise in 1st gear
  128. Hfs-6
  129. Evolution Dynamics first 4b11 build-up
  130. 02 sensor stripped upon removal
  131. Stock Turbo + External Wastegate
  132. Gear problem
  133. Tranny problems
  134. Paint AMS LICP?
  135. Installed Custom made 3" Aluminum Exhaust
  136. New install: Invidia Q300
  137. Greddy Profec B Spec II
  138. need some help with engine oil
  139. Transmission noise ( sounds like loose bolts)
  140. Air intakes and mileage
  141. threw a c161e code
  142. Perrin Drop in Help
  143. COBB Evo X Exhaust - Limited Edition
  144. Has anybody install JUN 272R cams on their EVO X????
  145. Weird 3rd gear
  146. Will HFC pass emissions?
  147. **Product Release**AMS Mitsubishi Lancer Evolution X Trailing Arm Bushings
  148. engine light help
  149. Stock Boost 1.7 BAr?
  150. If I remove my HFC... how much louder?
  151. Blitz Filter fitment question to
  152. Need HELP
  153. Any special bleeding prodecure when R&R'ing evo X rear end?????
  154. Wacky idle
  155. Evo X GSR Engine Rebuild
  156. Evo X Megan Racing OE-RS exhaust
  157. Car's engine shuts down by itself in few seconds
  158. Help with transfer case oil change
  159. custom exhaust shop in la?
  160. Answer: Why FORGE RS BOV (many other BOV's) causes a p1241 Limp Mode!!!
  161. Cosworth Air Filter
  162. Threw Codes C1219, U0428, and C2205
  163. need help with nisei intake pipe install
  164. Cobb SF intake Leaking Air?
  165. oil light problems
  166. boost gauge vs. ECU readings
  167. rre exhaust?
  168. CP-E Down pipe
  169. Installing cams, special tools required?
  170. Meth injec
  171. Evo X motor reliability and tuning potential ?
  172. Redline MTL helped my shift feel, much smoother now
  173. How Much Smoke is Normal?
  174. Bluemax 1450cc for evo x
  175. Exhaust Heat Shield ok to remove?
  176. Is running 4th to the fuel cut off harmful?
  177. Diff problems resolved by oil change!
  178. should i upgrade my waste gate
  179. Custom cold air intakes for your Evo X (proto pics)
  180. New Turbo and Tobz Tune
  181. New k&n intake for x
  182. Benefits of Intercooler Hard pipes
  183. Intake Question
  184. Gear Noise
  185. One mans theory... Just .02
  186. perrin downpipe question
  187. Blitz Nur Spec C-Ti Installed
  188. Oil issue leak after doing cams ....can anyone help???
  189. Question on Works console bushings
  190. ATTN: BUSCHUR *Dipstick Retainer?*
  191. Head issues
  192. REVIEW: MXP Resonated Testpipe
  193. GReddy PE II Ti availability
  194. How do you check fuel pump Voltage
  195. Cat back using an AP?
  196. Anyone using Invidia 100cell Down pipe/Cat ?
  197. ARC parts availability
  198. HKS SQV Kit
  199. Exahaust question????
  200. Exahaust questions??
  201. Clutch slippage at around 12k miles - Replacement clutch options
  202. Does a down pipe make that much of a difference?
  203. Cosworth fortified Evo X MR built and tuned by Dyno Flash
  204. Upgrade Turbo?
  205. nisei intake pipe
  206. Clutch install requirements. Questions.
  207. Catch Can Setup
  208. Boost controller
  209. removing boost gauge
  210. Deatschwerks 800cc injectors without upgrade fuel pump on stock turbo???
  211. Turbo Oil Feed Line WARNING
  212. P1235 damn it
  213. Turbo swap
  214. stock boost problems
  215. any after markey fuel rails that look "stock"
  216. Forge WGA and Cobb Stage 2?
  217. MR with a FP red
  218. kelford 214-b
  219. intake poll
  220. p1240
  221. Help! Evo X Engine Bearing Set
  222. Dipstick Popped Out!
  223. Reasonable exhaust install price?
  224. Best Upgrades for 2000
  225. Boost solenoid nipple required?
  226. Wanted centre differential for Evo X
  227. Fuel Pump
  228. Clutch Issues
  229. I want to build my motor
  230. Bucshar Raching Intake
  231. Boost Controller
  232. My New CBE Drones. Can it be fixed?
  233. AEM Intake Box and Cobb IC Piping?
  234. AMS Intake VS AMS Cold Air
  235. deciding on new parts
  236. What to upgrade for High RPMs?
  237. Is the Injen CAI changing the AFR ?
  238. Attn tranny rebuild specialist
  239. 3-4 4-neutral resistance
  240. Artisan exhaust w/ xtremeboost dp with dump
  241. Mysterious Engine Trouble...knocking and power loss.
  242. Composite engine valves?
  243. Already have the Cobb AP, now I need some help
  244. 02 sensor
  245. need advice on under drive pully
  246. Noise while in gear! please help
  247. Where to buy a stock turbine wheel?
  248. True Cold Air Intake Sucking Up Water?
  249. First oil change
  250. Stock Exhaust Question
