- Question on Intake (AEM, Injen, K&N Typhoon)
- AEM intake ok with AMS base ECU tune?
- Need some help with reading stock rom
- Got P1870 after tuning, what gives?
- Dimensions of stock compressor-side boost pill?
- Decisions.... Decisions.....
- My car Hiccups!
- WGDC High Gear vs Low Gear
- Official Injector Scaling and Latency Values
- Where to buy 3 PORT Solenoid Harness Connector?
- misconception about tunning e85
- COBB AccessPORT Challenge!
- Stopping the fuel trims affecting WOT fueling
- Cobb AP: Best way to solve this without Custom Tune
- LTFT/STFT question
- Hesitating of course
- Quick AP question...
- What can you do with the Cobb AP?
- Tactrix not working, Help!
- DW 1000cc's injector scaling needed
- Question Regarding AFRs....
- Does anyone know how to fix/cause of my idle issue?
- knock problem - Cobb stage1 -93 map
- New to tuning, what is a good starting map or starting point?
- Difference between '08 and '10 GSR stock tune (ROMs 52680020 and 55570005)
- Tuning a 2010 JDM Evo X
- can i switch from 53040007 to 52360018
- Does the AP lock the ECU so ppl cant look at it?
- Help P0107
- Help, Cobb Stage 2 breaking up at high RPM
- Anyway to disable P0300 misfire after cam install?
- Has anybody tried this
- how to tune e85
- Help! COBB & ARC~~~~~~
- AWC Reflash = service light??
- Re-scalling maps
- Cobb Stage 2 Map and Perrin Stage 3 map logs.
- How long did you wait for your link to download COBB Access Tuner Race???
- Boost Solenoid Table for a GM BCS & MAC Valve...
- 2010 EVO X and Accessport?
- Cobb Stage 2 map stronger than Perrin Stage 3????
- Zeitronix widebank installation
- MIVEC tuning for aftermarket turbo?
- LANCER 2009 GT can reflash?
- Downshift Synchro Rev Control
- Internal EGR
- Cobb the way to go for my purposes?
- Perrin Ecutek ECU Reflash question
- Manual boost controller Question?
- Which ECUflash maps need to be changed for running bigger injectors?
- The vishnu map on a cobb accessport ? ?
- Evoscan beta software
- I want the latest factory tune for the mr help?
- Stock evo x ECU
- Wrong definition and address of some tables in the Ralliart
- Can EvoScan Be loaded into This???
- Locked ECU?? ECUTEK??
- EVO X b411t going into a baja, need help with ECU
- Largest scaling limit for Evo X injectors?
- Using ecuflash got a check engine?
- How To remove 120km/h ding-dong sound warning
- Rookie Evo X MR Tuning question and opinons
- Newbie question on Wideband - why would you want/need one?
- is this to much knock
- Which brand Boost Gauge is the best?
- Aspiring Tuner
- factory ecu map + fp red and boltons, will my car start?
- Problems using map tracer in EvoScan.
- Increased in boost due to weather/temperature changes?
- quick question about AP
- cobb_ will it work on other car
- Defi gauge showing 28-29 boost spike
- How to: Cobb tuner race bypass: Get atr to work w/o driver install
- Question about COBB AP Maps
- Mode23 help!
- Question about the ECU
- kelford stage 2 and 1241
- Hks ssqv3 evo x problems, help please!
- Bad Flash? Knock?
- ASC light still comes on after DTC codes disabled, any ideas?
- Cobb AP can only read up to 22.3 psi correct?
- Help me I need rom definition (xml) for EVO X
- ECUFLASH tuning Evo X with Mac using Bootcamp
- Dom 2.0 Early Impressions
- Finally got the evo x to the dyno
- Enabling mode23 question
- Need help / suggestion
- LM-2 with ecuflash & evoscan
- ECUFLash + Fastkey
- How better is an aftermarket ecu compared to ecuflash ?
- ECUFLASH: Which table/map do you modify to raise your idle rpm?
- (PICS) KNOCK when your LTFT's lean out...check it out
- Need URGENT HELP ! ROM definition needed.
- If you have a Cobb AP please read and respond
- Please Help, Bricked Evo X ECU via EcuFlash
- Tactrix Cable 2.0 - Who has em in stock?
- Question about Knock
- I need help! Looking for tuner in New England!
- looking for a good shop in the dc area
- car going into limp mode
- why is evo x not in ecuflash list?
- Flashing Cobb AP in Winter
- 2008 MR AMS tuned @ 303HP and 311 TQ
- Is it possible to modify your own stock map via Cobb ATR?
- Blitz SBC i-color A/F Box II Question
- TunerPro RT
- Disabling the boost cut?
- How to find that MUT table & others
- JDM Speed Limit
- ecuFlash noob questions
- Injen Intake Cobb AP Maps are out
- Boost Gauge q.
- GM solenoid question
- Two odd behaviors I have observed
- Injector scaling for DW 1000?
- Limp mode P1241 with big bore throttle body.
- Definition XML for 52360018 ROM ID
- Dangerously lean / Hesitation
- Boost psi peak with Cobb AP?
- Speed density
- New EvoX MR
- Best Cold intake System for evo X
- CEL... any ideas?
- EDM EVO X ROM specifically 53040010.XML
- ECUFlash and EvoScan problems with Asus Eee PC
- help with tuning to eliminate p1235?
- P0300 multiple cylinder misfire..wtf
- editing 2-step for no lift to shift
- COBB PROTUNED for 11.5 AFR ECU Slowly leaning car out to dangerous AFR???? Help!!!
- P0133 & u0184..??
- Knock on stock X - WOT ~6k RPM
- MAFs gone bad!
- mode23 load innacurate?
- boost limiters+ rpm/mph crossover
- need to nerf/valet mode my evo
- def file needed for 08/09 jdm sst! pls help,,
- Anyone in Houston area with tactrix 2.0 cable?
- Causes of knock retard
- Works air filter vrs. OEM air filter using DLL.
- Tuning within warranty?
- Checksum error? Afraid to reflash using 1.42
- Stock gsr data log
- FP RED or AP GT35R kit
- Grimspeed EBCS Testing
- Cobb Stage 2 AP to Stage 1 AP something is acting up?
- Manual Boost Control
- evo 10 EDM 53040007 - need help
- Source for Tactrix Cables
- speed limit
- on stock boost control.. yea again! :-(
- COBB AP & tuned Evo X
- Perrin in Europe
- Evoscan: documentation for bit fields?
- evoscan
- Using a wideband with AccessPort?
- Need TEPHRA mod info for Aquamist setup on EVO X
- Greddy Informeter Touch boost sensor option question?
- LCD / touchscreen carputer options??
- shortcut to set LTFT Idle
- Will EvoScan monitor fuel pressure?
- Innovate OpenTune IPhone Interface
- Need help with boost control....
- just wondering if anyone here got there X tuned my DGMOTORS ?
- Need the full Definition for 5304007 EDM
- Boost solenoid question
- air/fuel ratio on initial boost?
- Tuned by Tobz in Colorado
- Can't Decide
- Evo X Map Giveaway
- can't decide
- at what point in modding is Tuning NECESSARY?
- AMS 02 Sensor spacer
- Cobb AP & FP Red turbo
- Evoscan or Cobb?
- What would cause this kind of randomness?
- Who's a good tuner for E85 in NYC area?
- Cobb AP plus K&N Typhoon
- Question for ppl who had gotten a tune.
- Boost values logging in Evoscan read higher than reality?
- 54070007
- Purchased Motec
- Throwing a p0139 with MXP testpipe??? Any fixes???
- Formerly EcuTeK tuned car, can I overwrite with Ecuflash?
- How to up MAX boost with ecuflash?
- help!!!! thermostat location?
- Knock Retard values from my AP datalog, are these of concern?
- low gear boost...
- Updates to EVO X AccessPORT and AccessTUNER
- evoscan via mmcs
- 2010 USDM Evo 10
- EVoscan Maptracer ???
- Methanol injection?
- HowTo: Logging Wideband AFR via Rear O2 ECU ADC Input (Logging AFR without serial)
- Cams for the Xs
- Official COBB Racetuner (EVO X) Discussion
- Resetting codes
- WORKS reflash
- are the torque limiters tables used on GSR ?
- Getting Best MPG during Cruise
- LTFT question
- Any Tuner can read my log and tell me ?
- limp mode
- Low Timing and hesitation during cold start
- Training on Tuning the ECU and Anti-Lag
- Stock Boost Pressure?
- Evoscan: Custom Display Gauge Layout
- Cobb and Injen
- How to permanently disable the ASC ?
- Launch control problems
- injectors not closing on deceleration
- Tuner advice in MD
- The DTC Disable thread (P1235, P1241, P1238, etc)
- Newest factory ECU reflash?
- Quick WB Question
- Cobb AP Question
- Fighting Hard Limp Mode with Airflow Mod
- Can't find the MAF table anywhere in ECUFLASH
- Fuel Trims for a stock X?
- Wideband Positioning in Stock Downpipe?
- Best pump gas brand
- cel fix for downpipe/testpipe help
- cobb stg 1 93oc runs rich?
- Is there a way to get a custom tune by mail?
- Cosworth drop in cams for evo X
- What would cause a tune to need to be changed pretty substantially? (Unchanged mods)
- Throwing P0137 and P1235 after EBC
- I know this is a stretch but....
- 97/98 Octane Pros and Cons
- Q:Idea: EvoScan Alarms function?
- AMS Intake Install. Flutter Sound help
- Boost Map Difference
- Tune preferences
- Higl load - low knock - is ti OK?
- problems tuning fpred
- Evo Scan Updates?
- Mini service at 11250 miles....
- NC Tuner Needed
- EvoScan 2.6
- Install now, or wait?
- car tuned finally
- Noob using 91oct CA gas, tried out Gunzo's base maps w/ success
- Best Guess HP Calculator
- Downshifting the X and going into Limp Mode
- knocking at low RPM
- Good widebands?
- Rev Limiter vs Throttle Limiter
- Removing Pill
- Alaskan DGmotors Email Tuned X
- MAF Scaling Table in grams/second
- Logging Wideband AFR via Rear O2 ECU ADC Input
