- tuning?
- Gruppe-s / ProDrive / Pierburg 3 port boost solenoid
- Upgraded Internal Wastegate Actuator: EVO X - Gain 40whp?
- noob what flash to get?
- Perrin Stage 1 Map Giving Me Problems...
- GSR ECU vs. MR ECU
- Missed shift
- AccessPort Maps and Mileage
- thinking of adding *more* water/meth
- Seems oddly slow lately... (AP help)
- Evo X 437hp 26 libras
- Intake or Drop In
- Which flash is better?
- Can A Non-Factory Turbo Inlet Pipe be used with ARC Box?
- EvoScan for Evo X Beta Parameter CAN-ID's? Log attached
- WORKS P2 flash REVIEW
- Evo X RS Mivec on Base Evo X?
- Anyone with 53040008 xlm for X ?
- Read CEL code with Tactrix?
- 1000 cc Injectors
- Tuning in Costa Mesa, CA?
- This years goals for tuner for evo x power suspension etc
- EVOX MR EDM definition
- Swapping Roms on the Evo X
- Leaning out under WOT
- How Is This Possible?
- Resetting ECU= Lost Tune?
- Tuning an evo X mr questions
- Evo 10 MFI basic block diagram from FSM
- Aem standalone on evox
- weird: cant see my X map definitions all of a sudden, help !
- overboost CEL
- Best I can do with OTS maps?
- Throttle Body
- Very good read.
- have a problem
- Tune Required?
- 52360016 xml update 110409
- conical cone filter and stock blow off valve...wow
- adjusting mivec on evox
- ecu questions
- Jestr tuning
- need some help?
- Which does tuners do E-Tune for COBB AP???
- AF Ratios
- Kiwi wifi + ECUFlash?
- 100% stock DG motors baseline
- Service Engine Soon, running lean
- Anyone install the buschur mass air pipe?
- drop-in filters -- results from tricking the MAF or less restriction?
- Anyone have any issues with their tuned X?
- Question about the AP and boost
- Question about air/fuel numbers
- Works P2
- ECUFlash Price Ballpark
- methanol injection
- ecu flash or ecutek on my evo x
- Stationary Rev Limiter
- Where to pull Speedo and Engine RPM signal from?
- Evo X OBDII output parameters?
- conservative tweaking with my MR
- What to watch for at the tuning shop?
- Evo X owners: What engine management are you running currently?
- How much boost should I be tuning for?
- WGDC maps
- U0167 code?
- Zt-2 Wideband MAP sensor install
- EvoX solenoids question
- Question for tuned X's?
- rev limit
- AFR very very rich after bolt ons
- z chip problem
- ECUTek for MR
- Evo X with water injection
- Can't tune...running to lean HELP!!!
- Need to re-tune?
- Crappy idle and hitting a brick wall
- What exactly is needed for stage 2...
- evoscan
- So whos afraid to get a tune?
- ECUFLASH for X: Glossary for Dummies !
- What is wrong with my turbo timer!?
- Hbspeed satisfied customer
- ASC light going off under boost!!!??
- Blitz SBC i-D + Cobb AP
- Anyone have Experience with just the AMS Evo X flash?
- P0140 Question
- TephraMODs for the X
- Fuel Cut? What happened?
- What logger can I use for Evo X
- Bolt ons w/ no tune
- Tuner in Eastern North Carolina
- going lean after 2 weeks of perfect AFR
- Z Chip is the ****!
- Auto Enginuity
- What am I missing?
- service engine soon?
- Is MR version of the Evo X undesirable for tuning?
- Cobb AccessPORT 1/4 mile results and review
- Vacuum leak?
- Wierd tuning question
- SES B3813 Undefined Code
- Question about the Cobb AP?
- Will loading JDM SST Rom onto EDM ECU work?
- Interesting find yesterday with the AP @ the track
- who is the BEST TRI-STATE Cobb AP tuner - NY, NJ, CT?????
- quick question abotu intakes with an ecu flash
- boost solenoid replacement evo x
- Head gasket
- cobb AP and boost
- Review of Vishnu Evo X MR Tune
- How do you know your fuel pump is maxed out?
- EDM Evo X SST Rom Definition needed (same as AUS)
- Anyone bought Cobb AP from them?
- ~~~~~~~~Greddy type RS bov questions ~~
- Who Should I Get to Tune My MR via Ecuflash
- You big turbo guys! What load numbers are you seeing?
- Question about the AP?
- share your ECUflash maps!
- very need to know how to recover ecu with ecuflash
- Quick modding question
- EcuTek question?
- Exhaust - Welded vs Mandril Bent
- The PCMScan Thread
- PCMScan Boost Logging, negative boost?
- DTC codes ? free program
- What are the HP differences between an X running 91 and 93 octane?
- vent to air bov
- Has anyone on here made their own maps for the AP with ATR?
- Questions about Cold Air intakes
- How many miles on car before reflashing?
- ECUFLASH + MBC or EBC
- Cobb AP 91 or 93 map for 92 gas
- ECUFLash speedcut on JDM
- Cobb Accessport Problem
- Just installed ZChip, so now what??
- TQ limit Info
- Where can i find a good shop in MD?
- Need to tune again after FMIC install?
- What upgrades to get / remian a Daily Driver
- Ecuflash with a JDM evox rs
- Cobb AP Tunes...
- Evoscan question
- Jestr Tuned
- Cobb AP Digital Speedometer.
- Ecu tune in south jersey
- EcuFlash - Mivec Tuning 101
- Cobb Access Port review and where to put it !
- Anybody have the Stage 2 93oc Map?
- Idle problems...Will a Cobb AP HELP???
- Gems ECU for the Evo X
- HKS F-Con V Pro just put on my Evo X
- ACD error after ECUflash
- Evo X RS rom Ecuflash help
- MR with MBC
- ECU Reset Help ASAP
- ECU Flash on P1245 code
- Few tuning questions...
- Oil catch can Install help!!!!!!!!!!!!!!!
- tune causing engine light
- Just got the Vishnu reflash.
- ECUFlash 1.41 released
- Limp mode [merge]
- Oil Type Question
- Just had my ECU flashed by mail in AMS
- Zchip/ZT-2 installation questions
- Was there a factory reflash in the US?
- Remote Tuning Request
- AccessPort the problem?
- Tuning questions
- ap maps
- First Open Port 2 data logger released
- Innovate Wideband
- Someone Please Help me With my AP
- Software gauges: HKS Camp 2 vs Magden M.1b vs ...
- installing the Apexi AVC-R in my X
- drop in intake ?
- OEM reflash or Cobb Stage 1 for fuel/oil problem
- How well does a custom tune on the X work?? Look Inside!!
- How much power can be had?
- What is a Pill
- Tuning/ECU/Reflash
- Mivec advantage?
- anyone have a picture of the MAT sensor tip?
- OEM Tune Revisted
- Cobb AP: ?s on product, features, and various maps incl Perrin maps go here [merge]
- Anyone know the locations of the intake air temp sensors?
- Stupid Tune Questions
- How does the ECU determine load?
- Disable Day Time Running Lights using Engine Management
- Poll: What intake maps for your AccessPORT? AEM avab now!
- EcuEdit logger don't see EvoX RS Ecu
- Z chip or Cobb Accessport for the X
- What kind of tune do I need for my current setup?
- HKS EVC VI mapping for EVO X SST
- Anyone know/found the speed sensor on EVO X?
- Evo X tuning day at Buschur Racing Mid January
- Want to tune but do I NEED gauges?
- How the Zchip works
- Perrin Stage 1 AP Map
- AMS Test Pipe.
- Is there any way to get rid of the annoying "rev hang" with a tune?
- popping??
- MBC boost peak settings for Evo X w/Zchip
- My Zchip on an independent dyno
- Evo X ROM disassembly/interpretation discussion
- I want to learn how to tune
- Tuning suggestions? Zchip or AMS tune for my car?
- AccessPort Accessmanager Stock question
- stock Flash
- To all X owners using the Profec B
- tuning question
- Wide band logging questions
- i need to tune my EVO X ? plz help me
- JDM MIVEC Map results?
- Cobb AP data log - knock retard?
- Optimal and maximum EGT levels for Evo X?
- Can the Cobb AP?
- AP from Dynoflash, did not receive maps (resolution in progress)
- Noob AP question
- Any way to tell if running too lean?
- Using Tactrix Cable to load Cobb Maps onto EVO X
- need help with evo x edm PLEASE
- CEL from overboosting on part throttle
- Purchasing a car with an Ecutek, want to reflash to stock
- Smoke
- ABS module working in an RS EVO X?
- HKS drop-in filter with AP...
- Tune recommendation
- Zchip gains in the MR
- AP, Evo X MR, stage 1 CA map, HKS drop in
- ECUTEK or Cobb AP?
- When to Tune
- How much boost can a stock turbo take?
- How Much Power Will The Stock 'X' Air Flow Sensor Handle b4 reaching max Voltage?
- Its cold and dry beware of static
- Cobb Access port question
- Beta Jestr Evo X tune .....
- Do we Still need an Intake mod with ECUFlash
- What's Cobb cooking up?
- Tactrix OpenPort 2.0 Connection Instructions
- Warranty Issues With Tuning
- ECUFlash I think I Bricked my ECU
- Suggestions for Access Port Evo X Install and Use
- EcuTek and Z chip compared on the same dyno
- EcuFlash 09 Ralliart tables Vs. Evolution 10 tables
- Aem Ems ??
- EVO MR Tune Q's
- The definitive EcuFlash Evo 10 thread
- bov/intake
