- Alaskan DGmotors Email Tuned X
- MAF Scaling Table in grams/second
- Logging Wideband AFR via Rear O2 ECU ADC Input
- Evo X MR EBC question
- i need a mobil tuner for montreal canada( from the us)
- Service Engine soon-light on a stock evo
- Access Tuner question
- Wideband and multiuse guages
- To those with Forge WGA and MBC
- Cobb AP EDM maps ?!
- Stage 1 Boost?
- AEM Analog Wideband Gague 30-5130
- ecuflash?
- Question for COBB.
- cat back effect on tune?
- Race Gas Timing?
- How Long Does it Take to Tune a Evo X?
- HELP: CEL after installing UR Test pipe and o2/dump??
- COBB Stage 1 JDM Tune
- Petition: Evo X EcuFlash Forum
- AP tuner and 64- bit operating syatem
- Intake mivec map does not line up with evoscan datalog?
- Help me tune my evo x
- Overboost while Datalogging w/ Cobb AP
- Pulling DTC codes: any option other than PCM Scan?
- Intakes, Fuel Trims, and AFR
- Dyno's hp numbers, how much is a lot?
- Help, Car going into limp mode only on roadcourse
- Which WB02?
- New Evo owner + ECUTek
- Cobb guys...
- Tuning help
- Calling all self tuners...
- Question regarding stock turbo efficiency and boost control (X MR)
- Anyone use the HKS panel filter with the AP's map for it?
- need some help on tuning options...
- Do I Need To Flash Back To Stock...
- HBspeed on Socal
- CMD - Dynojet Combustion Management Device
- Evo X JDM Map! HELP!!!
- Shooting Flames
- Enabling mode23 illustrated
- P103 (or was it 107) MASS VOLUME AIR somethingsomething SES light :(
- CBE and Drop In Without Tune =?
- cable for evo x tuning
- cobb AP for 2009 MR?
- Safe to drive untuned?
- Boost Spiking/Cobb AP Stage 2?
- accessport vs. rre tune
- Need Help asap .. while reading Ecuflash error, engine stop
- Cobb AP: Can I...
- DTC Scanner for the x?
- EvoScan, Innovate LM2, and tuning the Evo X!! few questions help pls :)
- O2 Sensor Disable
- Someone want to test airflow check disable mod?
- Want to take my car to get tuned by an AP tuner... WHO near San Diego?
- Low-Load High Knock Explained
- problems after pushing the car a little
- There is official reflash for 53040007 rom?
- cannot get rid of knocks above 6000rpm
- how to Vibrant Performance O2 Sensor Spacer???
- Vishnu Tune
- **Is there anyone in Westchester, NY that can do a tune??***
- 2009 Lancer Ralliart CJ 4B11 (AuDM, OzDM, AusDM, Aussie, Oz)
- Recommend shop? Initial research...
- gains from Aftermarket Exhaust
- 09 evo x. Cobb ap vehicle not supported issues
- Evo X & E85?
- injector scaling for RC 750?
- Is a 4.2 second 0-60 normal for this tune?
- Need Definition File for JDM Evo X
- Latency & Scaling for DW 800cc for COBB AP???
- Custom E-Flash For EVO X
- We are at it again!
- SES light fix?
- Knock when slipping clutch from a stop? Up to 6 knock sum at 1200 rpm's
- Perrin Stage 1 92+ w/ 91oct?
- Stock log
- Has anyone blow an engine with the Cobb AP stage 1 or 2 ?
- Tuner near WV?
- Knock after shifting no next gear
- reflash problem on Evo X GSR JDM version .. Help .. Thanks
- Xo2 racing? Anyone heard of them?
- What kind of TBE do you have for your X?
- Ecuflash reading prolem
- EVO X HKS FCON PNP Harness: FINALLY
- Headers
- Cobb AP w/ Cone Filter
- someone with a SST test something for me
- E85 mileage question
- after tune
- Greddy Oil Catch can placement....help!!
- Stock evo x mr using dataloglab...
- Evoscan + AEM UEGO
- Testpipe+Downpipe+Dropin airfilter(Without Tunning)
- ECUflash "ECU options" What do they do?
- Conditions for ECU to switch from High to Low Octane Maps?
- Tunning basics for the X
- While trying to play with a GTR
- nvidia n1 exhaust
- Evoscan WB log ?
- New to the community
- Anyone adjust the stationary rev limiter..?
- $400 what to get?
- How can I get more power from a stock car? What timing are you running?
- COBB Stage 2 vacuum hose diameter
- Anyone know who has the AP on sale
- Warmup and Aggressive MIVEC Maps
- How to make 300/300 on Evo X?
- Lost both smart keys
- Torque limiter #1-#4 in ECUflash for EVO X MR
- P1235 code after tuning... need some help!
- Stock Cat with Catback Exhaust and Stage 2 AP?
- Flash Tune in Winston Salem area
- If I have aftermarket already installed with AP work ok ??
- 15K service w/ reflash problems?
- Disable DRL in ETACS
- Should I tune yet?
- Anyone use the new AEM Needle style Wideband gauge yet?
- Boost Spike @ 4+ 2nd 3rd 4th gear.
- dyno tune vs road tune
- Modded EVO X's, normal to smoke under WOT?
- How does my log look?
- Cobb Stage II AMS Map, AFR's 12+???
- Cobb AP vs. Vishnu flash for MR
- New ECUFlash 1.422595
- P1241 CODE questions
- Altering X and Y values in EcuFlash
- Ecuflash error on X
- Cobb AP - How accurate is built-in dyno?
- soft modding for MR
- open port2.0 w/ evoscan
- Can someone clarify the difference between maps A, B, C, D in the EVO X?
- Misfire causing car to run lean and smell like fuel?
- Should I worry about 1 knock sum between 6000-7500 rpm's?
- OBDII Code Reader Compatible with the X
- Evoscan aem wb logging ?
- Question about EcuTeck and Cobb AP
- Tuning File for Evo X with SST Transmission
- Boost Tuning
- On vacation and need a tuner that's close
- Mivec Maps
- tuner in my area
- electronic throttle
- stock pump capability
- p0122 & P1233
- Limp mode problems
- P1241 Torque Limit Exceeded (COBB AP)
- Lookin for Tuner
- Flashing with ECUFlash....warranty work?
- EGT or INTAKE temp
- Evo X Mode 23 Logging/Dashboard/Gauges (hey tephra!)
- Problems with ECUFlash in parallels
- UICP with Cobb tune
- 91 octane HP/TQ
- need some input on how to smooth out my boost curve
- Tanabe Exhasut EVO X MR testing
- EvoScan EvoX Datalogger now supports 2byte Boost/Load/IPW
- plz look at my log
- Most Important Gauges
- Who does e-tuning for the evo X?
- Where to tune in Houston Area.
- Anyone running Cobb AP stage 1 w/ K&N drop in
- O2 location for logging
- X GSR ICS Waterspray ?
- turbo and torque
- Stage 1 + cobb ap = pill removal?
- Help, can someone identify which reflash I need, just bought Evo X
- How to finetune z-chip?
- Is boost determined by BTEL or Wastegate Duty Cycle maps in ECU?
- Has anyone bought any AP maps from any reputable tuners online?
- Which map for this intake?
- AFR Tuning Tips?
- Mut III?
- Code p1241 using Cobb Stg2 + SF
- cobb AP stage 1 real numbers???
- Opinions wanted, Where to get tuned?
- Question About COBB Stg. 2 w/Forge WGA & Boost Pill
- Holy balls the stock tune sucks
- Pro-tune to kill off any unwanted service lights/error codes?
- How do i log my evo with evoscan?
- 1/4 mile tunes vs stock
- Thrust Bearing!!!
- Evo X Logging
- Stock tunes input
- Newb question - WORKS Mail in Flash
- p1235 & p1238 @1000rpm
- Harmon Motive intake installed. Cobb AP maps road tested.
- Knock Retard Amount Question?
- Noob boost read question on cobb AP.
- new car 2k in mods while keeping the car quiet ;)
- cobb AP for two?
- 3 - Port Boost Control Solenoid and Harness
- East Coast Tuner
- For the Cobb guys... question on intake maps and hp numbers..
- Cobb AP help: New computer doesn't recognize when plugged in
- Cobb AP reading low boost
- CVN!? Tuners feel free to chime in..
- Sigh. P1235 4 days in a row now.
- What should I do about tuning my X?
- AMS Intake Maps for EVOX Now available!!
- Any reliable tuners in wetern PA or eastern Ohio?
- looking for a tune md/va area
- Recommended tuner in L.A.??
- evo x mr , how much should i be paying for a tune and dyno?
- TBE upgrade improvement to gas mileage
- AP owner; Question about factory reflash
- ECU Flash XML Definition Needed for EDM EVO X GSR
- correct stat rev limit ECUFlash definitions for USDM Evo 10 GSR
- Evo X MR Factory Reflash
- Anything that can be done to override traction control?
- Help On Going To Straight Pipe
- 2-step fail
- Trying to determine software for gauges...
- Lf 52360018
- Quick ? Need help!
- Boost Controllers and such...
- Limp mode again...
- Some Ideas to share
- EVO X MR Pro-Tune {no issues whatsoever} updated
- Help!! P0302
- Car acting weird when exhaust got installed
- Anybody Running The New Evo X Cobb AEM Intake Stage 1 Tune Yet?
- Help can't adjust stationary rev limiter
- Tune without adjusting boost levels?
- Funny Idle, Wierd Sounds when shifting
- MR ROM Definition
- cobb map boosting too much??
- How much knock is too much knock
- ECUflash and WORKS flashed ECU
- Evo X gauge setup pics
- IMPORTANT NEWS for MR Owners! READ!
- Will I lose my Custom Tune...
- Injector upgrade
- Stock Boost Pill Size?
- Tuning w/o wideband?
- Using Evoscan to determine why I pulled CEL (P1235)
- 08 EVO X MR noob Q regarding Cobb AP maps
- Cobb AP or other Tune - Issues with reliability?
- Tune with intake?
- Anyone running HKS VCON?
- Noob question about different maps
- Greddy InfoTouch or Traditional Gauges
- How to get ECM updates for USA Evos in Europe
- HKS drop in filter
- Intercooler Spray?
- evoscan and open port 2.0
- evoscan datalogger/gps display unit
- ATTENTION: EVO X AccessPORT Stage 2+AEM Intake Map Recall
- tuning?
